Question about Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 dryer wont run
+- 2yrs old clean out vent . drum light stays on door closed. front panel accept drying program . will not start .front door is closed does not lock.
  • Anonymous Mar 16, 2014
    dryer door light stays on when i close dryer
    Scholar:
  • 121 Answers
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
Posted on Aug 27, 2008
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
The dryer isn't drying properly. It gets hot its not drying. Its a Kenmore Elite. Also the coil has been cleaned and its not catching lint.
Make sure the drum is turning and the blower is functioning. Vacuum out all air passages including the hose going to the outside vent. Remove the lint trap, and wash it in hot water and detergent to clean away fabric softener deposits from the screen. If the motor is not running, find out why.
Nov 20, 2009 | Kenmore Elite HE4 Electric Dryer
Cloths not drying all the way
if you have heat and the clothes take to long to dry you need to clean out the dryer the lint duct and blow out the vent line,also go outside and make sure there isn't a cage or something acting like a lint catch stopping air from blowing out where the flapper is
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Hot side wall and staus lights stay on
repl/ hi limit and safety thermostat,, will solve prblems
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
He4 gas is turning off after 5 seconds.
hi . thanks for the question i would check the dryer venting the problem could be there remove venting from dryer to outside and clean thanks the appliance doc
Sep 29, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer won't start
Manual might be available on line type in your make and full model. Could well be the bulb that blew. Sounds like the door switch thou i see by other postings some times the filters can cause a similer problem
GUEST. 1. start switch is faulty...oops is it eletronic?it so disregard that. 2 drum is to tight 3 motor or switch on motor faulty
smitty123. Will drum turn by hand??? Can you hear the motor hum when you close the door???
Oct 27, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Aug 04, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
331 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
