Question about Sony Ericsson Walkman W810i Cellular Phone
Phone turns itself off
The battery is fully charged..When I turn on phone the battery meter slowly goes to dead then the phone powers off. I purchased new battery and the same thing occurs..
  • LesB Sep 02, 2008
    My W810i also has the same problem it shows 100% charged and when the phone it switched on the battery indicator jumps between 0%-50%-100% and then after a short while the phone complains that the battery is low and then switches off!
    I have tried a new battery with the same results, I have also tried installing new software on the phone with the Sony Ericsson update software but still have the same fault, I have also done a factory reset on the phone and have the same result!
    Please someone help?
    Problem Solver:
  • 17 Answers
Hello jdavi187 and LesB ,
                                    This problem sounds like a hardware fault to me ,on the mobiles motherboard .
                                                   The tiny surface mounted capacitors on the board that control the voltage and current from the battery get shorted out or simply stop working properly or if you drop the mobile it can create a dry solder joint on these components, sounds like you will have to take the mobile to a professional mobile technician,trying to replace tiny surface mount capacitors or resistors is nearly impossible without the correct tools and equipment.
Posted on Sep 04, 2008
My galaxy r don't open again after the battery drained. When I charged it there's sign that it is charging but I cant open once I hold the power button
I don't have that particular phone, but my phone has a small LED in the front that turns to red when it's in the charger with a fully drained battery, yellow when it's above 20% charge, and green when it's fully charged.
If the phone is fully charged, but it won't turn on when you press the power button, there's probably a problem with either your charger or the battery itself. I suggest replacing the battery, or when it's built into the phone itself visit the store where you bought it. They might know what to do.
Nov 26, 2014 | Computers & Internet
What To Do When Your Phone Does Not Turn On
The simplest reason causing a phone not turn on is a dead or drained battery. It happens when the phone gets immersed in water, dropped or allowed to fully drain the battery. The symptom is phone not turning on and not charging the battery. When that happens, make sure first that the battery is not just dead or drained before you send the phone to the service center for repair or before you buy a new battery. You may decide to send it right away only to find out the battery is simply dead/drained or buy a new battery only to find out the phone is dead.
The first thing you can do is borrow a friend’s known good battery similar to yours and try it in your phone. If the phone turns on, you are pretty sure your battery is dead or drained; otherwise, it's time to send it for repair.
When it is verified that the battery is dead or drained or if you don’t have someone to borrow from, try to revive the battery before you buy a new one. You just need a 9-volt battery, a 6-12 volt power supply, or a DC adaptor (6 or 9 volts) and a set of wires.
Connect the set of wires to the terminals of the 9-volt battery, power supply, or DC adaptor whichever is available.
Look for the polarity markings on your battery and connect the other ends of the wires to the battery terminals in the same polarity as the source above. The positive terminal is marked (+) while the negative is marked (-). Do this for 10 to 60 seconds or until the battery gets slightly warm. Do not use this procedure to fully charge the battery.
Insert the revived battery in your phone and charge it until it is fully charged. If the battery works well and does not discharge easily, you don't have to replace it.
In the event that it is not verified whether the phone still turns on or not using a known good battery and the battery is revived but the phone is still not charging the battery, the phone is dead; send it to the service center for repair.
on Dec 06, 2009 | Cell Phones
Power Problem Samsung Exclaim
You can try running the battery completely dead and then recharging, but it sounds as if you have done that already. I would recommend purchasing a new battery as it sounds like it is dead.
Apr 03, 2010 | Samsung Exclaim M550 Cell Phone
Garmin 530 doesn't turn on
if the light goes off it would indicate that the battery is fully charged.
does the unit function like a phone when charging as in showing a chg indicator even if it is off? If so there are more serious issue than maybe just a bad power switch.
Oct 22, 2017 | Garmin Rino 530 GPS Receiver
Mv acer aspire 3623WXCi turns off when i unplug the power cord with battery attached, is the battery dead and do i need a new one?
when you plug the power cord check and see if the battery shows that its charging ,if the charge level is low allow it to charge fully ,after its fully charged remove the power cord and see if it will go of again .if it goes off then you know the battery is dead if not it might be of low charge or not properly fixed.hope this helps
Sep 17, 2009 | Acer Aspire 3623WXCi (NBACERC1500XX1) PC...
Phone shows full battery then goes dead in an hour.
If you turn your phone on the very first time you use it you are suppoesed to charge it for ten hours. or not quite ten but what I do is i charge it all night and turn it off. this way you get sleep and in the morning your phone should be fine. if not reset the settings this should do it.
Jul 21, 2009 | RIM BlackBerry Curve 8310 Smartphone
LG VX5400 cell phone power problem
try replacing your battery
Jul 29, 2008 | Cell Phones
Is there a generic fault???
its not dead it crashed. try taking the battery out of it and put back in it should turn back on and alow u to charge it.
Jun 25, 2008 | LG KU990 Viewty
Sony Ericsson Walkman W810i Cellular Phone Logo
48 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
