Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Mac makes loud sound when burning cd in itunes
It doesn't happen all the time but sometimes my mac when buring a cd in itunes it makes this loud sound and vibrates the whole laptop! I always stop it and sometimes have to maually take the battery out or turn it off to make it stop. I thought maybe it is a fan issue so I bought one of those pads to spread the heat out. Maybe there is something wrong with my disc drive?
  • derksa Sep 01, 2008
    I have only had the laptop for a year. I would say I have only burned 5 cd's tops. I haven't burned any dvds. I was thinking about bringing it to the genius bar but it doesn't do it all the time, but maybe I will.
  • 44 Answers
How old is the MacBook? Have you done a lot of CD/DVD use? I would say the drive maybe going. Take it to an Apple store and the Genius bar to confirm.
Posted on Sep 01, 2008
When I sync my Iphone with my mac I lose the internet connection on the mac. Sometimes for 3 days. I shut everything down and it sometimes comes back right away.
i think your i phone driver or software are not installed properly. install it carefully and check the connectivity again.
May 06, 2012 | Apple Mac OS X
How do I copy a CD, playable on a CD player?
1. First make sure you have some blank CD-R's. 2. Put one in the drive and load iTunes. 3. Make a playlist and select the songs you want and add them to the playlist. 4. When you have the songs you want (no more then 70min worth) highlight the playlist by clicking it 5. Now press the iTunes File Menu and select burn playlist to DISC. 6. In the disk format make sure Audio CD is selected. 7. Press Burn.
You can now use this disk on a CD player.
Regards, Chris
Jul 01, 2011 | Apple 27" iMac 2.8GHz Quad-Core Intel Core...
Hi- I've just inserted a CD into my MacBook Pro
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Oct 13, 2009 | Apple MacBook Pro Laptop Computer with...
Mac Book Pro won't burn cds - spits out the cd
try a real music cd to check drive.
some blanks are no good try another brand or try a dvd to check drive
if it plays real and records on dvd then drive is ok
Sep 12, 2009 | Apple MacBook Pro Laptop Computer with...
Same CD burning problem
You can try a firmware update for that drive or it maybe the discs your using are low quality.You can try using a Qtip with very little alcohol on it and clean the eye a couple of times.But be gentle when doing it.Also clean the shiny rails on what the eye moves back and forth on.Also make sure the software you are using to burn with is compatible with your drive.You can download Ashampoo Burning Studio free and use it i think for 30 days free.Also CD BURNER XP is free and very compatible with most drives.
Jul 09, 2009 | Apple MacBook Pro Laptop Computer with...
Cd burn error apple mac mini
Did you use the same Maxell blank CD's in the other mini?
If so, it sounds like your drive may be failing/failed. Try another brand of CD in the superdrive just in case. I have found that drives that are beginning to fail will have problems with some brands but not others. Sometimes they'll go totally dead a while after that point, others will still be ok with another brand that they "like" more.
Apr 18, 2009 | Apple Mac mini G4 Desktop
Mac too loud
Did Logitech provide any software with the keyboard? Make sure you have the most recent version of any Mac software for this model of keyboard.
It's possible that 10.2.8 may not have all the right hooks in it to fully support a recent model Logitech keyboard. But my Apple-brand keyboard has volume control buttons on it that have worked since time immemorial, so I'd think 10.2.8 understands the basic concept.
I hope it's just a matter of getting the right software.
What model keyboard and Mac do you have?
Sep 22, 2008 | Apple Mac OS X 10.4 Tiger for Mac
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
767 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
