Question about InFocus Lamp Projector Lamp for LP240 [ SP-LAMP-005
Infocus LP280 Shuts down
This projector will run for a half hour and then shut down. After it cools, the cycle can be repeated. All the fans are working up to the point that it shuts down. When I take the cover off and start it up, it runs forever. I am thinking that either the thermal switch is bad or the fan motors are old and not pushing much air. Could someone please shed some light?
  • blawrence Jan 27, 2009
    I have the same exact problem on two seperate units.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
The lamp's quality is not good ,the lamp is too hot to work,
We Offer all the Original projector Lamps (bulb).Good quality good price.
Jerry Zhong (China)
Skype: hw998.com
E-mail: hw998.com@126.com
Posted on Apr 19, 2012
3 Suggested Answers
Marrie
  • 563 Answers
SOURCE: InFocus LP280 problem
Hi there
I'm afraid this might be a faulty Mainboard.
Your lamp will never make the Projector show funny stuff on the image.
Must warn you that a new Mainbaord is quite expensive
Posted on Apr 02, 2008
SOURCE: infocus LP280
Not mine but a friend's. Found a manual online, read it, fixed it. One must wait a while when pushing those buttons. One must have patience and read the manual before crying "it don't work".
Posted on Jul 17, 2008
Infocus LP530 will turn on and work great for 15 minutes then shuts down and the green light turns orange and blinks. The Bulb only has 283 hours on it.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work get a small fan and place it near the projector ro provide extra cooling. The projector is running border line on high temperature and just needs a little extra cooling.
Jul 20, 2010 | InFocus LP 530 Multimedia Projector
The lamp on my Infocus Screenplay 7210 shuts down
the projector thinks it is overheating. you may need to replace the temp sensor. it located near the lamp plug. also make sure the fans are both moving.
Jan 24, 2010 | InFocus ScreenPlay 7210 Multimedia...
How to Clean the lense on a Infocus LP280
outside- lint-free microfiber cloth and canned air. inside (projector)- canned air.
Nov 09, 2009 | InFocus LP280 Projector, Factory...
Infocus LP 280 runs for 1 min then shuts down, runs again then
are the leds on the top lit or blinking? it could be the lamp, the ballast, or the fans. check the lamp. if there are black spots or bulges in the lamp, replace it. if not, make sure the fans are running. if they are, replace the ballast.
Jun 09, 2009 | InFocus LP 130 Multimedia Projector
Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Mar 12, 2009 | Panasonic PT-AE700U Multimedia Projector
Infocus LP280 projector will shutdown itself
The Lamp cooling fan is not working or the fan speed control chip/circuit has failed. Do not run the projector until it is repaired as this condition rapidly destroys the lamp!! If the cause of the problem is simply the fan itself. It can quite easily be acquired and replaced by someone who is electro-mechanically savvy.
If the problem is on the main board (also very possible) it is substantially more difficult to repair and should only be done by someone who is an order of magnitude above just electro-mechanically savvy.
Also if the problem is in fact the main board an authorized service center would just replace it!
(hang on to your wallet)
Cheers
Feb 26, 2009 | InFocus LP280 Projector, Factory...
Fan stopped
Its internal circuitry might be telling it to not run--a remnant request during the last cool down. Hopefully it is the fan itself. Try the master reset command. If you do not get an image before its shuts off, look in your owner's manual, count the way you manipulate the menu buttons to get to the reset, and try it between the moment you first turn it on, and it shuts off. Unfortunately some units will not let you input commands untill it is 'up to speed'. My Eiki is like this--nothing untill it is fully bright. Depending on your 'exploration' desire, short of going to a repair place, or buying a new one, you might try seeing if your unit is dirty, see if you have power to the fan (voltage meter--maybe 5-7 volts), or something is jammed in there. Depending on its age, the fan just might be dead, Jon.
Feb 24, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Intermittent Power up / dn
HI-
The projector is overheating, try cleaning the filters for the fan.
Hope this helps
Oct 29, 2008 | InFocus LP 600 Multimedia Projector
Hi there
Mar 11, 2008 | InFocus Lamp Projector Lamp for LP240 [...
Shuts down
how many hours on bulb take it apart clean it dust it out nice
Feb 05, 2008 | InFocus Proxima DP1000X Multimedia...
370 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
