Question about HP LaserJet 4L Printer
HP Laser Jet 4L fuses
I have the same problem with my 4L. Where are the fuses physically located. I took the cover off the 4L but could not find them. Thanks for your help.
  • scot4282 Sep 11, 2008
    I found the fuses with the help of your HP manual. Unfortunately, the fuses are just fine. So I have to look elsewhere for the problem (if flashes the panel lights briefly after plugging it in and then it is dead - no fan, nothing) or take it to a shop.
  • 138 Answers
The fuses are located on the DC Controller (main bottom board). Getting to the DC Controller Board on a 4L printer is a very significant disassembly. Best left for a pro but if you really want to do it, I have attached below a link to a scanned copy of the service manual. Please keep in mind that the scanned copy is not a nice fresh PDF as most manuals as the 4L was made in 1994 and HP has physically scanned the printed manual for distribution. Just look up the removal and replacement of the DC Controller Board. Once removed, the fuses are glass buss style, readily available at any Radio Shack.
Gotta love that old technology.
Hope this helps you. :)
http://www.feedroller.com/Store/Service%20Manual/LASERJET%204L,%204ML,%204P,%204MP%20Service%20Manual.pdf
Posted on Sep 10, 2008
H P laser jet 4L will not turn on after a long disuse
When its not using so many months,mechanical jam may occured, in this condition its draws more power when its switched on, fuse may blow off, check primary power section in power supply board, replace the fuse with same rating then try it...best of luck...OLD IS GOLD..
Sep 06, 2011 | HP Office Equipment & Supplies
HP Laser Jet 4L jammed at rear.Cannot release paper
Open rear cover. Press green release lever upward. Push paper backward (out of top toward back) When all paper out of upper roller, pull remaining paper straight back. It will move easily.
I'm sure this is too late for the original post, but it might help someone who comes along later (like me)
May 08, 2011 | Office Equipment & Supplies
HP LaserJet 6p Printer Drivers Downloads for Windows 7
Go to hp.com. Select the support/driver link. Put in your model and hit enter. You will then see a menu with all of the operating systems. select the full download.
Jan 03, 2011 | HP LaserJet 6p Printer
The Out of paper light on my HP Laser Jet 4L is flashing even though the printer has paper. Can this be fixed?
The pickup roller most likely needs to cleaned. Normally paper dust causes this condition. Put the printer off and try again. If you still have the same problem then you probably have paper stuck in the printer somewhere, the paper sensor under the printer is broken. This is quite an old printer and spares might be a problem.
Good Luck
Apr 13, 2010 | HP LaserJet 4L Printer
I just bought a Compaq Presario computer and need an adapter cable for my HP Laser jet 4L. Where can I find one?
The HP Laserjet 4L uses a standard 25pin parallel printer cable.
These can be purchased at your friendly computer shop or on the Internet.
Mar 29, 2010 | HP LaserJet 4L Printer
HP 4L laser printer - no power indicators showing -
there is not a fuse in the printers main board but i can say that there is circuit breaker on the board like fuse only instead of fuse there is a ic that ic has to be replaced if major damage the cost may vary other wise the ic is just under 1$ THATS IS.IF ANY ENGINEER DOES HE WILL CHARGE HIS SERVICE FOR THAT.BUT CALLING A ENGINEER IS ADVISABLE AS HE WILL ALSO CHECK OUT ANY OTHER PART GOING TO BE SHORT IN NEAR BY COMING DAYS.
Mar 02, 2009 | HP LaserJet 4L Printer
Hp laser jet 4L problem
try holding the "online" button down when turning on the printer release when you get "cold reset" message
Jun 26, 2008 | HP LaserJet 4 plus Printer
LASER JET 4L PRINTER PROBLEM
Dear pamswab.
there is an interrnal fuse in the printer you most open it and found the power bourd the fuse there
HP Laser Jet 4L Printer Model #C2003
Try lowering the toner density using the printing software or the printer menu.
Feb 03, 2008 | HP LaserJet 4L Printer
On & off switch
I don't think there is one.
Jan 17, 2008 | HP LaserJet 4L Printer
HP LaserJet 4L Printer Logo
815 people viewed this question
Ben Johnson
