Question about Kitchen Ranges
Viking problem I cannot get to the house to try your fix until tomorrow. Can you tell me what caused this problem and if I need any additional repairs to prevent it from happening.
    President:
  • 1,952 Answers
No need.temperature ll release pressure
Posted on Aug 27, 2008
Viking professional VGRT
faulty dsi or maybe cooling fan issue
as i do not have mod and ser # can not see what you have
some vgr have cooling fan for bbq/griddle if not turning to speed causes dsi to fail
Nov 18, 2017 | Viking Kitchen Ranges
I have been to the repair shop twice for the same problem. When I hit the foot pedal, I hear the motor spin, but the foot does not move. They told me the belt slips off. I want to try and fix this...
Ok...take the machine BACK to the dealer and show him what you are doing when this happens and have him show you how to fix, tell him your NOT paying him again because obvisouly they haven't corrected the problem
Aug 07, 2010 | Husqvarna Viking 1
I have my samsung almost for 3 years. and cahnge the original lamp after that i replaced the lamps 3 times more.i dont kwon is normal. but i think is something else. thank god i dont pay anything for the...
use only original samsung lamp with the housing and socket attatched.
The lamp door switch may be intermittent,so you are temporarily fixing it by open and closing the door. The ballast can cause the failure as well. Avoid short period off and on times as turning the set back on in intervals less than an hour will cause microscopic cracks in the glass because the lamp needs too cool down to room temp before it is restarted for ultimate life........I hope this helps!!
Jun 03, 2010 | Samsung DLP HL-P5663W 56" TV
My LG 50'' has Black vertical lines after only 3 weeks
The Vertical Amplifier has failed in some section, or a faulty power supply to that section, it is almost impossible to tell, until one looks at the set. a Symptom, like this can, and does have a number of "Causes". This must be fixed first,and then any damage caused, must be repaired.
Apr 04, 2010 | Televison & Video
Viking VDSC3656 oven relay (PM010129) failed again
Try to find a relay that has higher contact ratings. Grainger hardware might have one that would fit. It sounds like a design problem and requires a bit of re-engineering to fix it permanently!
Sep 09, 2009 | Viking DEDO205 Stainless Steel Electric...
I have a very old viking - feed dog problem
The older 6XXX series are the best machines Viking ever made. But they have one flaw - if the button hole mechanism is not regularly serviced and used, it will eventually stick and the machine will only sew in reverse. This can also happen if you turn the knob backwards when in button hole mode.
I always tell my customers to make a few button holes every time they use the machine. This helps to keep the mechanism free and working between servicing.
Unfortunately the fix is not a DIY consumer project. It requires knowledge and expertise in disassembling the machine and re-aligning the parts. Expect to pay anywhere from $25 to $75 in addition to the regular servicing fee.
Steve P
Minneapolis
aka "The Bobbin Doctor"
Oct 05, 2008 | Husqvarna Viking 1
Viking all refrigerator
I just started having the same problem with my 48" frig/ freezer Viking Designer series 2 years old- this has been a hot summer, we were not home much and the AC in the house was set higher 78 degrees so the frig I guess had to work a bit more - when I open the door to the frig water droplets acually run down the interior of the door and the box insde is always damp - I also have stress cracks in the interior shell of the frig - repairman is trying to get Viking to fix it- it has been a year now and it still is not fixed- the stress cracks were caused by improper insulation application to the inside of the frig according to the repair people- Also my handles have pealed - like the stainless steel is not really stainless steel - Any ways could the temp in the house changed - does not mean the frig should not work well - For what it costs, I expected better
Sep 11, 2008 | Viking 42 in Built In Professional...
Viking sewing machine programmable card
Programable cards do eventually pack up. Test it with your reader writter.
Jun 17, 2008 | Husqvarna Viking 1
Viking electric range
There is another fuse or circuit breaker inside the range. House fuse is at least 50 amps which would be way too large for 110 volt things. Your instructions will tell you where it is. Frigidaire used to hide it under one of the burners. I don't know where it is on a Viking.
Jun 11, 2008 | Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
