Question about HP iPAQ RX3115 Pocket PC
Storage question for Ipaq
I have a 1 gig storage card for my RX3115 but when I attempt to load up music files I am getting a message "There is enough free disk space. Delete one or more files to free disk space and then try again". I have only used 244.74 mb. What am I doing wrong. Can anyone help? THanks
    Master:
  • 450 Answers
You have too many files in your root folder... Create a subfolder and copy the files into it...
Posted on Sep 07, 2005
SOURCE:
Why do I get you tube error loading messages when trying to access you tube videos on my I pad
Most likely your iPad is full... of pictures, videos, music, etc. Visit the Settings app, tap General, then Usage. In the STORAGE section at the top, you'll see how much of the storage is available on your iPad and how much is used. If the available number is small, you need to remove stuff until you have enough to handle incoming video streams (YouTube, for example).
The STORAGE section also identifies the apps that are using your space - if Music, Photos & Camera, or other apps seem to take a large portion of the space, either remove some of the data associated with those apps (pictures, movies, music) or remove apps themselves (apps you don't use don't need to be taking space on your iPad).
Portable devices aren't meant for large permanent storage. You should save things you intend to keep forever on your desktop device or in the cloud.
Oct 18, 2014 | Apple iPad 2
HTC 3125 Star Trek No memory
There are 2 different sets of memory - the built-in "Storage memory" & the microSD "Storage Card".
You can see how full they are:
1: Run "Task Manager".
2: Choose "Menu", choose "System Info".
I'm guessing that your Internet Explorer cache is large, filling up the "Storage memory".
To clear it:
1: Run Internet Explorer.
2: Choose "Menu", choose "Tools", choose "Options", choose "Memory"
3: Select "Temporary Files" & "Clear". This will run a minute or so.
Jan 05, 2009 | HTC 3125 Smartphone
Compaq Ipaq 3955
to backup your files contacts and everything you need to have a backup program.
spb has high quality software
http://www.handango.com/PlatformProductDetail.jsp?linkShareSite=linkShareSite&productId=182078&siteId=1
more of their great programs and games can be found here
http://www.spbsoftwarehouse.com
You can put your programs on the storage card by selecting another install location in the setup.
as I've explained in this tip
http://www.fixya.com/support/r659379-installing_games_software_pocket_pc
You can also use the file explorer to copy and move your files into the storage card for save storage note that the programs might not work if originally installed into main memory and then copyed into a storage card.
Comment by Ekse, posted on Jun 20, 2008 use this link instead of the handango one.
http://www.spbsoftwarehouse.com/products/backup/?en
Jun 20, 2008 | Compaq iPAQ H3955 Pocket PC
Compaq ipaq 3955
Jun 20, 2008 | RIM BlackBerry Pearl 8100
HP IPAQ POCKET PC
1st approach (Quick one!)
1. Soft reset your device
2. make a backup copy of the folder \SD-MMCard\MSMETADATA if exists.
3. delete the folder \SD-MMCard\MSMETADATA.
4. Soft reset your device once again.
2nd approach (Long one!)
If 1st approach did not work, restore the MSMETADATA folder and try the following:
Step Zero: BACKUP
- Make a full backup of your device (including storage cards). If you don't like to do a full backup keep at least a backup of all files and folders we are going to delete as indicated below:
Step One
-In the main device directory delete the file WMPInfo.xml
-Delete the \Application Data\Microsoft\Media Player\ directory and all of
the files in it including the WMDRM folder.
-Delete the \Music folder
Step Two
-Go to your SD card main directory and delete the file WMPInfo.xml
-Delete the folder \SD-MMCard\MSMETADATA
-Delete the folder \SD-MMCard\WMDRM
-Delete the folder \SD-MMCard\Music
Step Three
-Repeat step two for any other storage cards.
Step Four
-Refresh devices in WMP and the storages card should show up in the left tab
and in the sync window you can click "Next Device"
Hope this helps...
Feb 25, 2008 | HP iPAQ rx1950 Pocket PC
What's max mem size for ipaq 1950
Mem cards are added as storage cards and do not add up to your iPaq RAM.
You can use mem cards to add up space to install applications. (ie. it is something similar to installing a new Harddrive on your PC). However the physical RAM of your iPaq cannot be extended.
PocketPC programs have small RAM requirements so your PDA's built-in RAM will suffice.
As far as the maximum card size if I understood your question right, if your iPaq comes with Windows Mobile v5 or earlier, it supports SD cards up to 2GB and perhaps some non SDHC standard SD cards up to 4GB. If you can upgrade to WM6, then WM6 supports SDHC cards, so you can install >4GB cards.
Hope this helps.
Feb 16, 2008 | HP iPAQ rx1950 Pocket PC
HP ipaq 5550 - Bluetooth error
The error message is telling you that there is not enough memory to load the BlueTooth driver, try moving some of your files from My Documents/My Music etc. to your memory card. Also try uninstalling some of your programs and reinstalling them to your memory card, this will free up a fair bit of space in main memory and hopefully resolve the problem. Also; Tap Start, tap Settings, then tap the System tab and tap Memory. Tap the Main tab to see how much space is available in main memory, you should see a total of around 115-120MB available (128MB - the lie of storage device sizes - the file system) divided in to storage memory and program memory, if you see considerably less then you're iPaq has a hardware memory problem and will need repairing. Lastly keep in mind that Windows error messages cannot be trusted and the actual problem may be absolutely nothing to do with memory, so if this doesn't help post back.
Aug 22, 2007 | HP iPAQ H5555 Pocket PC
HP iPaq Rx3115 ...Please Help..
It depends what quality you need. If you need top quality you will have to go for something else like a dell axim x50v. This PDA should be ok for watching a movie as long as it is encoded properly, at a low resolution that is.
Sep 15, 2005 | HP iPAQ RX3115 Pocket PC
Downloading pictures
With pictures, since they're large, it's desirable to copy them to your storage card. And since they're large, it's much easier to copy them to the card with a card reader, rather than ActiveSync. As or viewing them, IPaq Image Viewer can read almost all fornatc of docs.
Sep 11, 2005 | HP iPAQ RX3115 Pocket PC
Storage Memory
memory card isn't really memory it's more like a disk drive. it's not like when you add memory to a PC and the new memory is automatically used. To make use of this card you need to transfer some of your larger files to the card.... You can move files from within the ipaq... Click and hold on file. Select Copy Click and hold Select Cut Navigate with File Explorer to the SD card.... Open File Explorer Select My device Now select SD Card You can create a new folder or select an existing folder Click on Edit at bottom of screeen. Select Paste. You can also move files directly from PC to Storage card...... While IPAQ is connected, go to My Computer, then double-click on Mobile Device, then double-click on Pocket PC. Now you will see your Storage Card, and you can use this just like a folder on your PC. You can create folders within it. You can click and drag files to it or to any of it's folders.
Sep 07, 2005 | HP iPAQ H4150 Pocket PC
HP iPAQ RX3115 Pocket PC Logo
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
