Question about GE RCA 4-Line Speakerphone
GE 2-9451 I recently received the above mentioned phone. Everything is great except the intercom button keeps blinking both red and green. I can't see anywhere in the manual that this is normal. I also can't find out why it is doing this and how to correct whatever is causing it to happen. HELP?? email is jrr58@yahoo.com
You need to have the phone join the network that you are in by assigning a station address to the phone. If this the only phone that you have like this, simply remove the plastic cover where the station addresses are to be printed. Beneath this cover there is a small button labled "PROGRAM BUTTON". Use a pen, press this button, then press "INTERCOM" and then label your station (01-16) followed by pressing the # key. This will make the intercom button flash on and off red and then it will stop flashing.
I hope this helps!
Posted on Dec 31, 2008
Meridian M7310 intercom key not working on anyphone
Do Feature **CONFIG, go to CONFIGURATION, select the second option, should say Line something, keep scrolling and it will say I/C: #,. press change, you can have a max of 2 Intercom keys, if you need other info, go to youtube.com and search for "thenortelguy"
Aug 28, 2009 | NorStar Meridian M7310 Phone
Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Lee
Jun 17, 2008 | GE RCA 4-Line Speakerphone
Intercome ringing
It sounds like the HFAI button on most of the sets is turned off. the HFAI (hands free answer intercom) button is located to the right of the SPKR key. With the handset down press the HFAI button. The green light next to it should light indicating that it is active. If the power goes out or if the phone is unplugged it will return to HFAI off status. hope that helps.
Feb 06, 2009 | AT&T Lucent MLS-12D Phone
Intercom light stuck on and no dial tone on GE 4 line phone
You may need to assign an intercom ID for that unit by pushing one of the intercom buttons at the top.
Dec 05, 2008 | GE 2-9450C Corded Phone
Intercom flashing
I didn't fix it myself. We had a phone technician come out to fix the line outside and that must have solved my problem. Thanks
May 27, 2008 | GE Lands Phones
2-9450c telephone will not setup
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set. Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Sep 26, 2007 | GE 2-9450C Corded Phone
TReset for GE Pro Series Model 29451A
Remove the plastic speed dial card covering and the speed dial card. Press "program" with a pen tip. Press the intercom button. The lcd display says "address-xx" (probably out of range). Type in a new 2-digit address within range (the number of phones you have), probably 01, 02, 03 or 04. Then press the # key. The intercom light should turn green, and there you have it.
Sep 10, 2007 | GE 25413RE3 Corded Phone
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Remove power cord with no backup battery
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set.) Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
May 17, 2007 | GE 2-9450C Corded Phone
GE RCA 4-Line Speakerphone Logo
538 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
