Question about Frigidaire CWS3600AS Top Load Washer
Frididaire Washer Works but wont auto advance
My washer works but it is stuck in one cycle and i have to manually advance it. what is the problem?
  • 943 Answers
Hi thanks for the question The problem appears to be the timer change it thanks THE APPLIANCE DOC
Posted on Sep 13, 2008
My washer will not switch from one cycle to the next
I understand that your washer is not advancing and stuck on one cycle. If you provide a Model and serial number, it will be helpful.
Jul 22, 2016 | Washing Machines
I have a Frigidaire FTF530FS washer with a problem. The Timer gets stuck in between the drain and the spin cycle. It occurs when the timer dial is about 3 o'clock. I replaced the drain pump, the door...
Good Morning kvojik, thanks for your post!
From my understanding your Frigidaire front load washer is getting stuck between the drain and spin cycle. I noticed that you have replaced many components within your washer and continue to experience this issue. I would not advise to manually advance any part of the washer because this could cause issues within your washer. It could be a potential issue with the motor. At this point you may want to reach out to a technician for proper diagnosis and repair. This will help you to avoid any further part purchases. -Matt
Feb 21, 2015 | Frigidaire FTF530FS Front Load Washer
Washer stays in wash cycle will not spin out i changed control board no help
Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
Aug 01, 2012 | Electrolux Washing Machines
My washer has filled up with water and then just stopped and wont begin the cycle...
Try manually advancing timer . If washer starts , timer motor is bad or gets stuck , or water level switch is bad and not sending power to timer.
If washer doesn't start ,the lid switch is stuck not sending power to timer or god forbid, timer is shot.
In some models , lid switch controls everything which may be your problem .Try manually operating lid switch or jumping it with jumper wire.Or just replacing. Its' the easiest to fix and most likely problem.
Good luck
Aug 15, 2011 | Maytag PAV2300 Top Load Washer
Washer is stuck on wash cycle,,wont fill wth water and wont go to any other cycle.
Can you manually force it to go to other cycles? If so then the timer or control board is the issue. If you can't even make it advance then the control board is most likely. Check your pump and make sure it is not clogged and therre fore njot allowing the waqter to drain out =as it ias supposed to. If the water is not pumpiong out the washer will not advance
May 11, 2011 | GE WJRR4170E Top Load Washer
My washer gets stuck on a cycle
if you can manually move the timer to the next cycle and all works fine then you have a bad timer on unit... there are sevral gears in the timer usually made of plastic and over time thaey can get worn and not allow the timer to advance... if all works when you move the timer then most likely this is your problem (the timer) good luck to you
Jan 13, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Cycle dial doesn't advance automatically anymore. I saw some listed problems that sounded similar, but not exact. Washer will work in all cycles, but only when I watch and move the dial manually.
Hello & Welcome to FixYa
Its seems that the Timer is stuck, as everything else is working fine in the unit and the dial ust gets stuck and so won't complete the cycle so the problem is with the Timer motor going bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 24, 2010 | Kenmore 15522 Built-in Dishwasher
Washer stuck on agitate cycle, with no water. if time is manually advanced to rinse spins cycle, you can hear the pump but it will not advance to spin
Pull the front panel off the machine and check the small hose running from the tub to the control panel ( left hand side of tub). Pull off the hose and you might see a build up in the end of the hose . Clean and re-attach .
Nov 30, 2010 | GE WDSR2080D Top Load Washer
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Timer only works on heavy cycle not on normal model #11024632300
Could be a bad timer or loose contacts.
Unplug the washer.
Open the control console.
Remove the wire harness connector from the timer and re-insert it.
Also advance your timer manually 360 degrees around several times. This can cause stuck contacts to work correctly.
If this does not correct your problem you will need a new timer.
Feb 14, 2010 | Kenmore 24632 Top Load Washer
Frigidaire CWS3600AS Top Load Washer Logo
41 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
