Question about HP iPAQ hw6515 Pocket PC
Hard Reset HP 6515
Can anyone tell me how to hard reset the HP iPaq 6515. I don't have a mannual. Thanks
  • Anonymous Mar 25, 2014
    hard reset
    Master:
  • 450 Answers
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
Posted on Sep 07, 2005
I have an ipaq 6515 it gets switch off quit often i have to remove the battery and restart only then i can switch it on i triyed hard reseting but its not working please help me out
Posted on Dec 23, 2008
  • Lornet2010 Sep 17, 2010
    I have the same problem with my ipaq 6515 . Dis you find the solution ?
  • firepug Oct 01, 2010
    I've had the same problem with two 6510s. I've concluded its either the battery cover (which has some sort of crazy detection system) or the sim card coming loose.
I have a hp ipaq 6515 I want to know how to find reset button in my pocket pc
Posted on Apr 04, 2009
After hard reset . hp ipaq phone became laaga [very slow running state]
Posted on May 17, 2009
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
Ipaq 111 hard reset
Soft reset Perform a soft reset
NOTE: Be sure to close all running applications before performing a soft reset.
To perform a soft reset:
1. Locate the recessed Reset button on the HP iPAQ.
2. Use the stylus to lightly press the Reset button.
Hard reset
To perform a hard reset and return the HP iPAQ to factory settings:
Press Win + OK + Record together.
While doing that, press reset button and hold for 3-4 seconds.
Release reset.
Release buttons.
NOTE: Do not release the buttons until CLEAN REBOOT appears on the screen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 18, 2011 | HP iPAQ 111 Classic Pocket PC
How do i do a hard reset on HP ipaq X11-21204?
u have given a wrong Model number this is not a model number infact a part number pls try to find the correct model number from HP site thru photo identification if u dont find ur model other wise i am providing u detail below to try the hard reset on various series of HP IPAQS kindly be sure that ur ALL DATA WILL BE ERASED pls rate me FIXYA if i fixed ur problem
How to Perform a Hard Reset on an HP iPAQ
Performing a hard reset on an HP iPAQ is relatively easy, but is a dramatic step in the management of your handheld organizer. A hard reset will completely clear the memory of your device and restore it to the state you received it in from the factory. A soft reset, on the other hand, simply closes running programs and restarts your pocket PC.
Instructions
Difficulty: Moderately Easy
Step1
Read the owner’s manual. If you don’t have to do a hard reset, you shouldn’t, and you definitely don’t want to do one by accident. So familiarize yourself with the hard reset protocol offered in the manual.
Step2
Make sure you want to clear all personal settings, saved data and personal files from your PDA. If there are files you wish to retain, save them to a removable disk, or send them to your computer’s hard drive to be retrieved at a later date before performing a hard reset.
Step3
For the HP iPAQ h1900 series, hold down the power button while you use your stylus to hold down the reset button (on the left side of the iPAQ). Hold these buttons for a few seconds until the screen fades to black.
Step4
For the HP iPAQ h2000 Series, press down on the far left and right buttons (calendar and iTask, respectively). While you do this, press and hold the reset button on the back of the iPAQ until the screen fades.
Step5
For the HP iPAQ h5000 Series and H3800 Series, the procedure is the same as the h2000 Series with the only difference being on some models the Today button is used instead of the iTask button.
Step6
For the hw6500 Mobile Messenger Series and hx2000 Series the procedure for the hard reset is precisely the same as for the devices in step 4.
Step7
For the rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.
Step8
For the rz1710 and rz1715, follow the same procedure as the devices in step 7, with the difference of pressing the Today button (on the far right) instead of the iTask button.
Step9
To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Tips & Warnings
* If you’re iPAQ is simply slowing down or having problems, try a soft reset (reboot) before resorting to a hard reset.
* Read your iPAQ’s instruction manual to familiarize yourself with how to do a hard reset, and the effects of performing one.
* Do not perform a hard reset unless you are okay with or intend to erase all non-factory installed data and settings from your HP iPAQ.
Mar 17, 2009 | HP Computers & Internet
HW6515d Ipaq Sound with TomTom Sat NAv
The ipaq 6515 has a microswitch that will turn off the pda if the battery cover is removed. When you remove the cover and try to turn it on even with the external power supply plugged in, the red led will light up.
Jan 29, 2008 | HP iPAQ hw6515 Pocket PC
My hp ipaq hw 6515
Try soft resetting your ipaq. If that didnt work then try hard resetting it, note that you will lose all the data in your ipaq
Oct 23, 2007 | HP iPAQ hw6515 Pocket PC
Hpipaq 6515
get ur msg centre no. from service provider enter it in ur msg settings or else try your sim in other handset good luck !!!
Sep 20, 2007 | HP iPAQ hw6515 Pocket PC
Ipaq RX3715 hard reset
hard reset: Button 1 and 4 and press reset button with stylus
Jul 11, 2006 | HP iPAQ RX3715 Pocket PC
My ipaq won't open!
if you have inserted SD or other cards and devices in your IPAQ try to stay IPAQ without them.... if ypu don`t have it ---- then go to the service center....
Sep 08, 2005 | HP iPAQ RZ1710 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
5,296 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
