Question about Lexmark Office Equipment & Supplies
Lexmark all in one wont print or connect to the computer
Please help i got a new computer and i cant use my printer which is an all in one lexmark can you please help me i tried to contact the help line and gave them the model which is 4420-064 and they said there should be a numbr on the front of the machine but there isnt so they just kept going on and on about another non existant number i cant use my printer at all can you help thanks lauren ottewill
Soulvisitor
  • 1113 Answers
SOURCE: connect no disc
OK , I'll try to help you...
Unplug the USB Printer cable, delete any previous installs
Click on THIS and download the correct driver to suit your system be that XP,Mac, 2000 or Vista please note Win 98 is not supported..
Run the file you downloaded.
Plug in USB when program prompts you to.
Wish you luck you determined lady!
S.
If you are having trouble downloading the file after pressing download, then you must quickly click on writing in right bottom of box like pic below (marked with red text)
Posted on Jan 13, 2008
  • 159 Answers
SOURCE: Canon MP530 U052 Error
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Posted on Mar 22, 2008
jmeredith
  • 417 Answers
SOURCE: lexmark 8350 won't communicate with computer
hi.
maybe the usb cable went completely, you can try to replace it with another, also Ive heard lexmark power supplies can go bad without notice, can you copy standalone with it? you should. if not then check power output with a multimeter. Is your new dell running on vista? you may have to download a driver specific for vista and lexmark from lexmark website NOT the XP driver the VISTA driver, I had to do that with mine. just a couple ideas. good luck
good luck
J
Posted on Aug 01, 2008
SOURCE: Lexmark X7350 InkJet printer & Vista
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Follow this link to Lexmark site, uninstall your old driver before installing this one to see if it corrects the problem
Posted on Aug 06, 2008
marked
  • 6487 Answers
SOURCE: i lost my lexmark x2600 installation disk
You can go to this link and download the software for your printer, just select the operating system that you're using on your computer http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:92:0:0
Hope that helps..........
Posted on Oct 07, 2008
My lexmark 5650 wont connect to my computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eVzv1x. Select your operating system, download and execute the file.
Feb 25, 2012 | Lexmark X5650 AllInOne InkJet Printer
Does not print from my computer
Try to do a test print using the printer utility installed on your computer and also check if the driver is properly installed on your computer and if not make sure that your printer is using the printer driver from your setup CD.
Hope that helps...........
Jul 17, 2008 | Lexmark Z640 InkJet Printer
My lexmark will only print from Wi-Fi . When we try to print from my main computer it wont print unless you restart the computer and then it prints.
If the communication problem happens when the printer is on power saver mode, a firmware update should help fix the problem. A firmware update for your model addresses the problem where the printer is having trouble waking up from sleep mode. Please visit the Lexmark website to download and install update at http://bit.ly/p905fw. Please make sure the printer is awake and the USB cable is connected from the printer to your computer when updating.
Jan 15, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
My printer want scan to pc
printer wont scan to pc - Lexmark X5650 ALL-IN-ONE PRINTER
Dec 05, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
My lexmark 2600 is ON and rdy but my comp doesnt see it after making a USB connection so i cant use it to scan and print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aNGYmW. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 30, 2011 | Lexmark X2600 InkJet Printer
MY LEXMARK 1270 CANT PRINT NOR SCAN BUT ITS STATUS IS READY
2. Unplug and re-plug the printer into the power source to reset it.
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file.
Aug 15, 2011 | Lexmark X1270 All-In-One InkJet Printer
Cant get my lexmark 4270 series going on my computer help
Go to Control Panel -> Printers. Is the printer listed here? Is the printer Online (It will say Online or Offline next to the printer tile)? If it says Offline, the computer cannot currently see the printer so check to make sure it is plugged in and turned on and that the cable is connected from the computer to the printer. If it is Online, right-click on the printer tile and select Properties. On the General tab, click on the Print Test Page button. After a few moments, the printer should spit out a test page. If this prints out, your printer is working properly. If not, let me know what error messages (if any) it displays or the overall printer behavior (blinking lights, beeps or other noises, etc).
Apr 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x3330 for linux
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 22, 2009 | Lexmark X3330 All-In-One InkJet Printer
Cannot print on my lexmark 1150 using Windows Vista.
lol. i have a Lexmark x125 and it wont 'communicate' with the computer !!
May 04, 2008 | Lexmark X1150 All-In-One InkJet Printer
Printer will not print
i cant print it wont print anything.can you help
Nov 12, 2007 | Lexmark Z640 InkJet Printer
94 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
