Dehumidifiers
Problem for Dehumidifiers
Generic problem for all Dehumidifiers
Not working
By annerhard on Aug 27, 2008
My dehumidifier runs but does not collect water. And believe me, it should be. Before it quit collecting water, it would not shut off when it was full and would overflow if I didn't keep an eye on it Have cheap GE dehumidifier and fan runs but picks up no water
Comments:
Aug 28, 2008
- Dear MNtech
Could you break that down.
I'm clear on the filter,coils being clean.
But if fan is running fan motor is good.
Now how to determine if
1.defrost control
2. dehumidistat
3. compressor is bad?
I'm really interested since there are so many dead dehumidifiers around I can get parts.
How interchangeable are they in your estimation?
Angelika
annerhard@yahoo.com
Best Solution
posted on Aug 28, 2008
Very Helpful)
MNTECH
Rank: Guru
Rating: 94%, 894 votes
Hate to tell you, but it may be a goner. Many units have a rectangular air filter that may be clogged, but I would still expect to see some moisture removal. Without exact model I'll have to be general,.... remove cover (front or back, depends on model) to see cooling coils. If the compressor is running, these coils should be wet or may have a light frost on them for a time. Not = refrigerant leak. (not economical to repair) If you see one small area of ice,... it's also a goner. If the compressor does not run you could have a bad compressor, a bad defrost control, or a bad control / humidistat. Other than the filter or possibly a fan motor, these unit are rarely economical to repair.
Comments:
Aug 29, 2008
- Sometimes it is difficult to even tell if the compressor is running due to the fan noise. Whithout a clamp on amp meter or a direct test cord for the compressor, you may be able to ascertain that the compressor is running by touching the compressor to feel for vibration and/or heat. Fan and Comp running + no moisture on coils = leak in sealed system. (NER: not economical to repair) Fan running but not comp: disconnect power and remove 3 wires from top of comp. check resistance between terminals. should not be any "open" readings. "open" = bad comp(NER). should be no resistance (open) from terminals to case. any resistance there = bad comp. If comp tests OK, you can try to find defrost control or board from another dehumidifier (there are no easy tests for these components), but there are many different ones, some of which look identical but are not, plus how do you know these used parts are good? If you can find a used dehumid of the same model with a known sealed system leak you can try the parts from it.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Dehumidifiers
Questions and Unsolved Problems for Dehumidifiers
Answer
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if... (More)
Answer
small basement efficiency that is not occupied during cold months, and accumulates mold and paint... (More)
Answer
Humidifer is not taking out water. Is there a start capacator for the compressor?
Answer
Attached a pump to drain collected water so it can be pumped into a sink to avoid emptying the... (More)
Answer
wont work. water indicator light blinks red
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dehumidifiers:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
