Question about Palm Tungsten T5 - Multilingual Handheld
Saving adresses How can I save all of my addresses etc. from the old version 3.0.1 if I uninstall it before installing the new Treo 650 Palm software? Thanks
    Master:
  • 903 Answers
You can install and uninstall Palm Desktop without affecting the user data stored on your PC. That is one of the beauties of the Palm OS system. The uninstaller only removes what it installed - that does not include your data.
Posted on Sep 07, 2005
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
Unable to Synchronize with Vista 64 bit
Treo 650 can't be synced to Vista 64 via the cable, but Bluetooth works OK. Details later (I hope).
Apr 28, 2009 | Palm Treo 650 Handheld
Frequent hanging of my new palm treo650
If it's new, it's under warranty, get a new one.
Also, if you have tons of add-ons, this can cause frequent hangs. Uninstall some of them.
May 25, 2008 | Palm Treo 650 Handheld
Hot sync treo 650 Zip-Linq cable
i have the same F***** probelm
Mar 27, 2008 | Palm Treo 650 Handheld
Outlook Calendar synchronization failed in palm treo 650
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
cropp
Feb 24, 2008 | Palm Treo 650 Handheld
Syncing a 600 and 650??
I have Treo 600, 650 and old Handspring Visor -- all sync perfectly well using Palm Sync Ver. 4.0.1 software.
Sep 22, 2007 | Palm Treo 600 Handheld
Complete uninstall of palm desktop?
How I uninstalled Palm Desktop for the 7135: Suggest this step: 1) Find your Palm files, all of them, most likely /Program Files/Palm, and make a copy of the folder, call it Palm Backup. That should leave all of your existing information as is, just in case 2) Using the control panel, find and remove Palm Desktop (Start, Control Panel, Add/Remove Applications) 3) Suggest you optionally reboot. 4) Now do the install of your new Palm Treo 650 software. This is what I did, and all is well. I had different problems when I decided to go back to my 7135. Seems that using the same techniques does NOT remove the PalmOne software, lots of residual modules, and even if I did a delete of the entire Palm directory, there must be links everywhere. The 650 has extraordinary capabilities, but in the end, I went back to my 7135.
Sep 12, 2005 | Palm Treo 650 Handheld
Retrieving Back-up contacts/phone book
Try Desktop overwrite HH. I've lost everything on my HH a couple of times and had to set the conduits to 'Desktop overwrites HH' in the hotsync manager - Custom settings for the next hot sync. If what you have on desktop isn't what you want, you should copy your saved folder info back over whats in your palm folders (i.e) where you copied it from.. Before you complete this step. Then your old data will be copied to your HH. Note - I assume you "copied" , not "archived" the data.
Sep 11, 2005 | Palm Treo 650 Handheld
Synching treo 650 with 600
In a nutshell, make sure you have a recent synch to your PC of the 600. Install the Treo 650 desktop software Synch to the username of the 600 Your are done. You should rename the Treo 600 or hard reset it (you will get data corruption if you synch two devices with the same username to one PC). If you are paranoid, you can make a backup copy of your c:\program files\palm\ folder to begin with. This contains most of your settings and extra software on the 600. As you are an Outlook user, your personal data is probably in a PST file or it is stored in Exchange.
Palm Tungsten T5 - Multilingual Handheld Logo
66 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
