Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Need help. my tv was working fine this morning but got home fr work turned it on and it looks like 3 different colors and the pic does not look clear. the 3 different colors are way off. can u please help me. my tv is a 52 inch rca.
  • 1 more comment
  • rhon3320 Aug 28, 2008
    i turned my tv on and it showes 3 wavy lines at the top green red yellow. when the picture comes up it looks like 3 d with green and red and the picture is oval
  • Anonymous Aug 31, 2008
    picture looks bowed in and blured like 3d
  • barkeatingoo Jan 14, 2009
    screen looks 3d and concaved
  • RCA Master
  • 8,617 Answers
You need the ITC222 convergence power supply board. You can get a new replacement board at the following link.
Posted on Aug 27, 2008
Clear picture, then rainbow colors, then fuzzy, then clear again.
logitech cams only work in UVC mode not drivers
unless you have 10.3.x software on the mac. then you can run 8.0.1 on the mac. otherwise you need to upgrade the cam.**
here is a list of mac complaint cameras.
Jul 09, 2009 | Logitech Quickcam Chat Webcam
Distorted Picture
Could you explain a bit more clearly by what you mean by "shifted"? A pic here would help..
Jun 27, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Toshiba 50hp16 pop than crappy pic
Might be the bulbs.. try replacing it, or call toshiba support line/ service line.
Apr 29, 2008 | Toshiba 50HP81 50 in. Plasma Television
My projection tv has ghost pic you can see three dfferent color lines
Go into the tv menu and look for "convergence" this is a setup issue that can sync your colors. Projection tv's have 3 projectors inside, each a different color, if they get out og sync it can cause a blue or red ghost. In your tv menu you can look for noise reduction and turn it on also scan velocity modulation turn that on as well. These can all be found in the menu under picture or setup.
Jul 01, 2009 | Televison & Video
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Tv will not come on
  • check to see if tv has sound when you turn on, then check menu for color, check if tv might be on timer. this might help!!!
Mar 19, 2009 | Sanyo DS27510 27" TV
CRT TV Screen Colors Off
The tv needs degaussing (demagnetizing) unplugg the set tonight and then plug it and turn it on in the morning. You should hear a a "bonk" noise when the set is first turned on after being cold- this is the internal degausse circuit working and it should fix your problem if you don't hear the "bonk" sound or it does not fix your problem call arepair shop to have the degausse your set and possibly fix the internal degausse circuit.
Dec 23, 2008 | Panasonic CT-32HX42 32" TV
Blue,red,green lines on top of screen for couple months. Now tv wont work.
The foldover is because of a bad capacitor in the vertical circuit. Given the "new" sympotom of a dead set, I would suspect that the vertical IC has failed. This should be a relatively simple repair for a TV shop. If you wish to attempt a repair of this yourself, update this and confirm your model number and I'll post more details and instructions.
Nov 10, 2008 | Philips 32PT5441/37 32" TV
Help with tv
does your tv make noise the bearing usually go out on those color wheel sets so do the lamps on that model if you are confident go for a repair at home here is a shortcut if this is the year click the link above
Feb 16, 2008 | Televison & Video
Picture Looks Like a 3-d Movie
This is bad convergence. Try self focus and if still not ok is hardware problem. The STK are leaked and need to be replaced. It's not easy, you have to remove the all deflection board and for sure you'll have some resistors to replace too. I sugest you to call a tech, but first try the self focus.
Sep 17, 2007 | Samsung HC-P4741W 47" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
