Question about Electrolux Dishwashers
Electrolux ESL63010 integrated dishwasher 10 months old- works for a few seconds, then stops and beeps continously. & the End indicator light flashes once. I turn it off, cancel programme, set it again, shut the door -it starts and goes on to complete the programme and washes the dishes perfectly. It has been doing this 'performance' for a week now -every time I use it- can you shed any light please
catriver
  • 878 Answers
SOURCE: Dishwasher sticking half way through cycle
Crawlmom, it sounds like your door latch assy. and switches are not making properly sometime during the wash. Therefore the two dashes. You want to make sure that the dishwasher is level and securely mounted. Another thing is, on this model, if a key pad is stuck, the dishwasher will stop and flash the stuck key. Im not sure where the red light is coming from. Without being there, I'm leaning on the door switch assy. Check this out first and post back. Catriver.
Posted on Apr 16, 2007
  • 58 Answers
SOURCE: Kenmore Elite Dishwasher clean light ind flashing and won't start
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Posted on Jan 09, 2009
  • 188 Answers
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
  • 338 Answers
SOURCE: Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Posted on Apr 10, 2009
  • 228 Answers
SOURCE: Neff Integrated slimline - Programme does not complete.
IT SOUNDS AS THOUGH ITS NOT HEATING DETERGENT AND RINSE AID INTRODUCED INTO COLD WATER WILL GENERATE A LOT OF FOAM,IS APPLIANCE WARM INSIDE AT END OF CYCLE?OR IT COULD BE TOO MUCH RINSE AID IF IT IS FILLED WITH RINSE AID AND YOU ARE USING A TABLET WITH RINSE AID COMBINED IT WILL HAVE TOO MUCH TO USE IN ONE WASH.
Posted on Aug 05, 2009
Why does my Electrolux dishwasher keep beeping 20 continuously?
call electrolux i cant find anything that is free,they all want money
May 09, 2015 | Electrolux Dishwashers
How do I fit a door catch Electrolux dishwasher esl63010
Usually with door open there is 2 screws holding the locking assembly in place! Undo all screws and remove whole assembly! Refitting is reverse!
Oct 13, 2014 | Dishwashers
The light that indicates the dishes are clean will not go off
I have had nothing but problems with Electrolux appliances, the dishwasher especially. Have you tried disconnecting power at the fuse box? You should be able to set back to factory reset by pressing the two buttons (about 1" apart just left of the far right, you may have to try pressing a few positions for a few seconds each spot along the pad and it will beep and "welcome" you again - that should reset it, unless there is an issue with your main board, in which case you will have to get it serviced.) Mine is no longer under warranty so none of the recent problems will be fixed, and many of the original problems are back after being serviced. I would never buy another Electrolux product ever again!
Dec 13, 2013 | Electrolux Dishwashers
Avery Berkel 1770 shop scale is continually beeping
Any time you let something set you should check the battery backup it might be low power beep telling you it is bad.
Jan 29, 2013 | Office Equipment & Supplies
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
Oct 13, 2012 | Electrolux EWDW6505GS Fully Integrated...
913T Dishwasher Stops after 10 seconds
913T is a very old model (1996), I have one, I'm not a repairer, I have the same fault. It doesn't have drawers or infrared or a display.
I've just shortened the ribbon cable, which had pinch damage at the door close pinch point. I used a male & female ribbon squeeze connector pair to make a good clean joint. With the cable fault it wasn't even starting the drain cycle. Now it does start, but then long beeps, and I suspect it's detecting a fault with the motor or a sensor or faulty wire, and is halting.
I've found running the rinse cycle first then allows the main wash cycle to run, no longer stopping at 10 seconds (after the initial drain), just as the first power wash commences.
May 24, 2012 | Dishwashers
Hi, My Dishlex dishwasher DX 302WB ia showing 10
check this
1)blockage in boiler tank.(cleaned)
2)water pressure is less.(check solenoid filter)
if it's programmed in timer mode within the period it must reach the water level in the tank due to this also it may happen.
Jan 06, 2010 | Electrolux Dishwashers
Dishlex dx302 keeps beeping after every 2-5mins of operating..i hold down the start button for a few seconds then push the programme button and it starts operating again for only a few minutes
I had this problem, also. I just persisted with it for a week (re-initiating the start) & eventually it came good. Was very frustrating for a while. Your post was over two months ago; did it spontaneously resolve for you?
Chris
Jun 27, 2009 | Electrolux Dishwashers
Dishwashers Logo
294 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
