Question about Palm Treo 650 Handheld
How do I handle error 0x80040702 Failed to load dll:HSAPI
The Treo 650 CD install bombs with this error -- what should I do? Palm support has disconnected the call three different times after a 1 hour wait. ?? What support?
    Master:
  • 903 Answers
Re: How do I handle error 0x80040702 Failed to load...
Old version of Palm Desktop There appears to be a few versions of older Palm Desktop that the installer has problems overwriting. Did you have a Treo 300 or an older device perchance? A solution from Brighthand forums: "Error Number: 0x80040702 Description: Failed to load dll: HSAPI The problem appeared to be that I still had the older Palm desktop software (version 3.01) from my Palm V on my computer. Uninstalling the old software solved my problem. While this may be a bit obvious, I was surprised that the Treo 650 installation instructions had a section on upgrading from another palm device, but failed to mention that you need to uninstall the old software. " One reason that you run into this problem may be that you dont have sufficient rights to make registry changes on your PC (including one installer removing and older installation). Check with your IT Admin to ensure you can do what you are trying to do.
Posted on Sep 07, 2005
I have an older version of a aplm pilot i705... I installed cd on my new computer using a vista operating system... at this time I have learned that they are not compatible and am trying to uninstall and keep getting error code 0x80040702....
Posted on Dec 30, 2008
How do i fix 0x80040702;failed to load dll:kill? pls help !
Posted on Oct 14, 2008
Try unstalling with windows control panel. sometimes it will not let you, the only solution is to edit the registry and delete all the "handspring" "palm" and "U.S. Robotics" entries. the easiest and safest way is to use Reg Cleaner (freeware) and delete all these. then proceed with the installation CD, it should work fine then
Posted on Jul 24, 2007
Excellent! Great help Maya.
Posted on Jul 29, 2007
0 characters
3 Points
Palm Treo 650 Handheld Logo
5,363 people viewed this question
Top Palm PDAs Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
David Payne
David Payne
Nataly Roberts
Nataly Roberts
Are you a Palm PDA Expert? Answer questions, earn points and help others
