Question about Konica Minolta Office Equipment & Supplies
I have a konica minolta bizhub 7222. After a power outage the screen only reads "error f-35-4 please call service. I am unable to do anything on the machine. How do I get in this thing to reset it or change whatever needs to be changed to fix it without calling service? Thanks.
  • Konica Minolta Master
  • 6,850 Answers
Enter 25 mode then select soft switches
set 3-1-0
currently set to 3-1-1 due to code you have
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 25, 2018
SOURCE:
  • 1316 Answers
SOURCE: How do you change the time on the bizhub 7222?
Enter in the user tools and setting the value.If don`t work tell me for more information.
Posted on Oct 01, 2009
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Posted on Oct 10, 2009
firecontrol7
  • 6850 Answers
SOURCE: my konica minolta copier says call sevice code
Sir,
Fuser Code (Hot Unit has over heated) To reset you will need to go to 25 Mode to enter his mode you must turn off the machine then holding down the 2 and 5 button turn on the machine, hold them 25 down for at least 30 second once in 25 mode select SW (soft Switch) select "3" then "2" it should be a "1" change to a "0" then exit and turn off the machine and turn "ON".
Posted on Feb 27, 2010
hamzaskilltd
  • 318 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
  • 59 Answers
SOURCE: konica minolta 7222 model f-35-4
Related with the heater. check two thermistors and other parts if the avery thing is ok then:
Reset code using 25 mode, dipswitch 3, bit 1 is the fuser reset command "0" is no and "1"for yes
presumably this means that if you must reset a fuser fault, you enter this mode, select dipswitch 3,select bit 1 and change no to yes , by pressing "ON"
Posted on Jan 27, 2011
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Konica Minolta Bizhub 7222 scaner don't working N-37
Does it print?, Can you ping it. Scan to Email or PC? Or SMB/FTP? Check mail server. also try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Feb 14, 2014 | Konica Minolta Office Equipment & Supplies
I have a konica Minolta bizhub c450 it was running fine until there was a power outage when powered on the device read an error code CD370 and the language was in chinese or japanese after clearing the...
you should be able to get into service via trouble reset hold utility button while turning on copier when you get to trouble reset screen do the stop 0 stop 0 1 and that should get you in. You might need to put the stock firmware on to cure the fault. If you need anymore help i can look into it for you.
Oct 30, 2013 | Konica Minolta bizhub Office Equipment &...
Konica monilta 7222 error f-35-4
my machine konica minolta C252 is giving the code 9401 how should I resolve and what is
Jul 19, 2013 | Konica Minolta Minolta 7222 Laser Printer...
Konica Bizhub 200 touch screen doesn't get past the Konica logo screen.
power off the machine and take toner bottle out. Then turn the machine without the toner bottle. let it run it should ask for the toner bottle to be replaced. Please wait is the machine is conducting house chores prior to READY TO COPY. one is to ensure toner in the developer unit is properly mixed. Also might check. Power on the machine while depressing the utiltiy/counter button hold down until you see trouble reset touch ok power off then wait 10 seconds and power on. if neither works get a tech out to look at iti
Mar 30, 2017 | Konica Minolta bizhub 200 Printer
Abort code
contact service use go to www.konicaminolta.com
Oct 06, 2012 | Genuine Konica Minolta Konica Minolta...
Unable to power up konica minolta bizhub c250
here is the linkhttp://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-smif you have any problem contact me.
Dec 06, 2011 | Konica Minolta bizhub C250 All-In-One...
What are codes F-34 and F-35?
These are heat sensor abnormality error codes in Konica Minolta 7222/7145/7135/7235/7228 models.You did not mention the model.
Oct 04, 2010 | Konica Minolta Bizhub C300 All-In-One...
Oct 01, 2009 | Konica Minolta Office Equipment & Supplies
113 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
