Question about Sharp R-1874 Convection/Microwave Oven
Microwave removal My Sharp R 1850 A microw/covection oven in my 2000 HR Endeavor died. I need to remove it. How do I get at the bolts that hold it in place. Is there any place I can get a diagram to show me how it was installed? Thanks, Glenn
  • Sharp Master
  • 9,098 Answers
We have installation instructions on our site that cover several past Sharp models and may be close enough to yours to help you.
Normally you take the grille off then remove the two screws that would then be revealed. Then unplug it and slide it forward.
But you should check the link - it should help.
What problem are you having with it?
If you have trouble with the control panel, we regularly repair these for customers nationwide with our guaranteed $39.95 service.
Posted on Sep 01, 2008
  • William Miller
    William Miller Sep 06, 2008
No rotisery and cooking power
Check diode ( this connects to the casing of microwave) , the transformer, then the magnetron in that order. Turntable has separate motor and the spindle that fits onto oven plate are prone to breaking.parts are replaceable and can be bought off eBay for approx £24
Jan 13, 2015 | Sharp Electronics Corporation SHARP 1000W...
Trying to remove sharp r-1480, removed two bolts on top, don't know where the other bolts are holding unit in.
there are 2 scews behind grill piece that runs above the door and control panel. loosen and you'll be in business..
Aug 06, 2011 | Sharp R-1480 Microwave Oven
Show hight voltage shema capacitor sharp 1850 sharp carousel
Not sure exactly what you're asking but the service manual for the R-1850 is available online here and you can order part here or here.
Jan 22, 2011 | Sharp R-1850A Convection/Microwave Oven
Looking for operater manual for sharp covection oven
http://www.sharpusa.com/~/media/65B6B50076584AA0B66678537D761381.ashx
Mar 03, 2010 | Sharp R-1870 Convection/Microwave Oven
How to remove from wall for remodel project
There are 4 bolts or should be 4 holding the microwave top to the cabinet. Open the doors to the upper cabinets and you should see the bolt heads unplug the microwave unscrew the bolts while holding the microwave. After the bolts are out tilt microwave towards you and pick up from the bottom next to the wall to remove oven from mounting plate and thats it.
Sep 16, 2009 | Sharp R-1505 Microwave Oven
How to replace a 2000 HR Endeavor "over the range microwave oven"
It sounds like you may have a bad keypad or (hopefully) a simple door switch failure.
When you press Start, if it does not beep, then either the door open switch is bad (not very likely) or its mount is bad, or your membrane keypad is failing.
If it beeps when press Start, and your fan and inside light come on and it counts down, but the turntable doesn't turn and it doesn't cook, then you have a bad secondary interlock (lower door switch with white and gray wires) or its mount is broken or loose.
You can try gently pushing up and down on the door while trying to hit Start. That will sometimes make it try to work.
For this model, neither the control panel frame with keypad nor the separate membrane key sheet is is available, but the key sheet from a different colored model may still be available. I can check into that further if you want.
Door switches are pretty easy to get. They are often held in place by a little tab on the underside of the mount. That can be hard to reach, but not too bad if you're careful.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We have the service manual for this model and I can e-mail to you.
If you'd like us to install the keypad, we can do it for $39.95 plus parts.
Please feel free to contact me directly if you need more help.
Please contact me directly and I'll also send you installation info on several Sharp models. That should give you enough info in case you decide to remove it.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 25, 2008 | Sharp R-1405 / R-140 Microwave Oven
Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
May 08, 2008 | Sharp R-963 Convection/Microwave Oven
Sharp R-1450 micro over range removal
Those specific installation instructions are no longer available, but I have a couple for other models that may be close enough to help.
I have uploaded them here and here.
prototech@usa.net
Apr 21, 2008 | Sharp R-202EW Microwave Oven
Wont heat items in the micro or convection
MODEL NUMBER NEEDED
Apparently this is not actually an R-510HK since that model does not have convection mode. Can you reply back with the correct model number? We may have the service manual for you.
A PRELIMINARY OPINION
It sounds like you have loose door switch mounts or possibly loose door hinges.
If the door won't open via the door open button, then the outer cover will have to be removed.
BEFORE YOU RATE THIS
This is a preliminary post, asking for further information (model). Please withhold your rating until we actually offer the solution.
Dec 06, 2007 | Sharp R-510HW Microwave Oven
Sharp R-1874 Convection/Microwave Oven Logo
207 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
