Question about Saeco Classico Espresso Machine
No flow of water
My machine is 3 or 4 years old. No water is flowing from coffee side. I opened machine and it looks like there is a small cut in the tubing at its first connection. Can this cause enough air intake to stop the pump from working. Sometimes when I lift the tube & water tank high, the water will flow. If this is the problem, can I replace the tube with readily available tubing from a hardware store? Or is there a sealant I can use?
  • fagundes79 Oct 10, 2008
    The machine hesitates, that is it sounds like it wants to start pumping water through the coffee side then gets quite again, and sort of comes and goes, trying to pull the shot. Sometimes I will eventually pull the shot, but not most of the time.
    I descale regularly, and removed and cleaned all screens.
  • Anonymous Jan 07, 2009
    I'm having the same problem... before I go out an replace it can this be fixed?
    Scholar:
  • 62 Answers
You can use any readily available tubing, but don't use sealants - they make their way into the water.
Posted on Aug 27, 2008
Hi! Miele makes only small amount of coffee then all the rest of the water leaks into drip tray. Please note that no water is inside the machine or trash bin. Unit has been descaled & cleaned.
I really sounds like the machine is working properly (water flowing properly) and either the filter material is too thick, or the coffee is too fine, or the flow control mechanism is failing to open properly. (For reference, I use Bunn filters in mine as they are taller and allow the water level to rise deeper in the basket before overflowing.)
Some things to look at: (1) make certain that you are using only one thickness of paper filter, (2) that you are only using coffee designed for your coffee maker (drip grind usually) and that (3) the mechanism is opening properly (not gunked up with dried coffee or whatever).
Nov 09, 2016 | Miele Coffee Makers & Espresso Machines
Tip
Ventilate won't go away! WHY?
Why do I get Ventilate all the time?
The ventilate problem will always come back if the flow meter is restricted. If the flow meter is plugged it will never go away.What happens to cause this problem? Coffee grounds are the answer. If you remove the water tank, it exposes the water intake receptacle under the tank on top of the machine. The small opening in the receptacle that has a hose that goes to the flow meter that then goes to the pump intake. If some coffee particles fall into this opening when you are filling the bean hopper (and they do). When the pump is activated, it creates a suction, moving the water and anything in the hose to the flow meter. The flow meter has a small opening in the intake side. ). When the pump is activated, suction inside the flow meter creates a jet of water, which spins the little turbine inside. The turbine has a small magnet on top that passes a pick up sensor, which tells the computer that water is flowing. If the intake opening is restricted with coffee grounds, it will let some water flow but won't create a jet of water needed to spin the turbine. Water will come out of the steam wand, but won't spin the turbine and the ventilate signal will still be there. If the flow meter is slightly restricted, the pump can create enough suction to spin the turbine when there is no restrictions when the steam valve is just flowing water (priming), but when you try to steam or make coffee and the pump slows down, the jet of water stops and so does the turbine and the ventilate comes back.How to fix this problem? Answer, the flow meter has to be removed and cleaned, or just replaced.How to prevent this from happening? If you are working on the bean hopper (filling with beans) keep the water tank on and covered. This will prevent a bean chip from falling into the receptacle and getting to the flow meter. Do the same with the bean hopper. If you ware filling the water tank, keep the lid to the bean hopper on, so water doesn't spill into the bean hopper and ruin the grinder.bansheracer.jpg
on Jun 28, 2011 | Saeco INCANTO DELUXE Espresso Machine
Tip
Problem: No water flow; Solution: Unclog a small orifice in the flow meter
My 5 year-old Syncrony Logic stopped working for the first time today. The water would not flow, not through the steamer, not through the brew group. I had previously thoroughly cleaned the brew group screens, steamer wand, water dispenser filter, etc. Still no water flow. I could hear the pump working but no flow.
I only use distilled water in the unit, so I've never had a scale problem (distilled water has no minerals, thus nothing to create scale). After downloading a parts schematic from here, I dug into the case. By the way, I suggest you don't proceed unless you have at least some mechanical ability and are not afraid to break something in the process. Be sure to unplug from the wall first, unless you really like electricity A LOT.
After removing the drip tray, grinds bin, water tub, and coffee hopper, I removed the gray top. To do this: from the top remove 2 screws under the water tub, 2 screw under the coffee hopper. And from below the control panel: 4 screws from the under-side along the front and behind the brew group cover. Once the screws are out lift the cover at the back and pivot off the front.
2 things are attached to this cover: the power switch and water hose. The power switch easily slides off the top cover. The water hose runs from the water dispenser fitting and into a little white gizmo with another hose running out of it and into the pump. The little gizmo is a flow meter that ensures water is flowing. Remove the hose from the tank and flow meter in order to clean it.
The top of this flow meter easily comes off by slightly twisting the top counter-clockwise about 10 degrees, lining up 3 tabs with slots and lifting it off. Its a little snug coming off due to an o-ring seal. You'll see the little turbine wheel inside. In the top is the input and output ports in the flow meter turbine chamber.
The input opening into the flow meter turbine is TINY. It was clogged with a bit of gooey fluff. I poked it out with a small pipe-cleaner, then made sure the hose from the tank was clean, and the opening into the turbine was gunk-free.
After I put it all back together it ran like a champ again. I love this espresso maker. First problem in 5 years of flawless operation.
Bill
on Jun 06, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Slow water dispensing
How slowly in comparison to other units? Have you measured it how fast it runs ?? If slower than when Syntia was brand new is maybe caused by an insufficiently cleaned brew group or lack of proper descaling .Calcium or mineral in the unit's lines and boiler can slow down your machine .
if the filter screen is partially blocked from old coffee tar then water cannot flow faster . In my opinion it always runs slowly when rinsing .
If you use a "Coffee Residue cleaner "only use it in the pre-ground
setting chute and use only a pinch at a time . then run pre-ground setting without any grounds and run another one to clear the detergent
Very oily ,sticky coffee beans can plug up any late model superautomatic's system as you can read in the unit manuals . Because the laser cut holes in the fliter screen are so small that any coffee tar will not flow properly through the screens .I have had many machines which had to be switched to a less oily bean to work more than for2 or 3 cups .When beans are roasted too fast and too hot ,the coffee oil can turn to coffee tar .
My Xelsis unit cannot handle very oily beans . 2 cups and it STOPS
I only use beans roasted to American Coffee institute recommended procedures .
Aug 30, 2014 | Saeco Syntia Espresso Machine & Coffee...
Eurig B70 empties the entire reservoir when turned on
Buy a saeco you'll never look back
I've had mine for four years and do the cleaning as required
It has pulled 15468 coffees and still going strong
It did cost a pretty Pennie but you get what you pay for
My condolences to your coffee machine
Jan 04, 2014 | Keurig Platinum B70 Coffee Maker
Low level water led turns does not extinguish anymore
You have a restriction in your flow meter or inlet opening. Usually it's the flow meter. The flow meter is connected to the intake opening on the back of the machine by a silicone hose. The other hose connected to the flow meter goes to the suction side of the pump. The intake side of the flow meter has a small opening and the other side connected to the pump has a large opening. When the pump turns on and everything is clear, the small side of the flow meter creates a jet of water that spins the turbine. This lets the computer know that water is present and turns the heater on. If the turbine doesn't spin the computer thinks the pump is bad and turns the light on for water and keeps the heater from turning on and burning up. You need to clear the small opening in the flow meter.
Dec 09, 2010 | Saeco Incanto Classic Espresso Machine
Gaggia Classic (3 months old). Suddenly there is steam only, no water flow.
If there is no water from the head then remove the screw and screen, then press brew button, if water flows clean shower, using a pair of plies hold screen over open flame, coffee will burn out of the small holes. If no water after trying above then remove the 2 allen wrench screws and carefully remove the diffuser and seat with spring, now try running the head, if water flows reassemble and you are back in busines, if no water descale machine.
Nov 25, 2010 | Gaggia Classic Espresso Machine
My issue: watertank is full, when powered, coffee buttons and the left LED are blinking. When I open the steam valve, the pump works for like 5-10 seconds then stops, neither water nor steam come out. Same...
HI
Nov 17, 2009 | Saeco Incanto Classic Espresso Machine
Solis Palazzo Steam problem
Hi
Sounds like your flow meter is restricted with the usual chip of bean. The flow meter spins when the pump is moving water. There is a small opening in the intake side of the flow meter and this creates a jet of water that spins the flow meter. When the flow meter is spinning the machine is happy, but when the intake gets restricted the water doesn't spin the flow meter and the machine says ventilate. It wants the flow meter to spin and be happy. You could possibly fix it your self if your handy, other wise let the pros do it.
Nov 25, 2008 | Solis Palazzo Espresso Machine
Saeco italia error
What happens when you open the knob on the right? It may just need priming.
Jan 21, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Classico Espresso Machine Logo
225 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
