Emmersion heater in airing cupboard tripped, so i replaced old for new rdt 18inch vertical ressetable therostat but it still tripped, could the problem be the element? if so how easy is it to replace?
Easy! Breaker trips means electrically touching ground. Disconnect parts till unit stays running then "that eas the grounded part. Thank you very much!
Posted on Aug 27, 2008
00 FORD EXPLORER CAN NOT GET ANY HEAT ,IVE REPLACED THEROSTAT,RADIATOR,HEATER CONTROL VALVE AND A BLEND DOOR ACTUATOR HOSES ALSO FLUSHED HEATER CORE HOSES ON HTR CORE ARE GETTING HOT WHAT ELSE CAN I CHECK...
When you turn the heat on,is the blower putting out good wind speed.Do all the vents and defroster have good air flow.Does the A.C. blow with good air speed.
Jan 19, 2014 | Ford Cars & Trucks
My heater regularily trips my electrical circuit breaker the model no is hm2000t. I bought it about 10 years ago but because of this problem It has been in a cupboard for 9 years. Should I throw it away
Good day!!!
if your machine will trips the breaker every time you plug it in a split seconds only...
that problem is cause of shorted parts inside...The common parts that usually have a high risk of shorted is the heating element itself...
please try to compare the price of your machine to the parts you need to buy...if the price almost the same or too close....I suggest you to buy the new machine because if you replaced the parts and still persist or you have another trouble cause of short circuit..
Thanks for using fixya...
Jul 30, 2011 | DeLonghi 6707E Oil Filled Radiator Heater
Spark plug fired,( Sears -30,000 BTU) starts and runs for approx. 30 seconds, then cuts off. The reset button does not reset for restart for about another 20 - 30 seconds. Then the unit will restart...
check and see if the heater has a high temperature limit switch. if it does it will shut the machine off until it cools down.. just replace it with a new one.
Jan 31, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
The therostat breaker keeps triping no mater what the therostat setting is. I have to reset the breaker each time i want hot water. Is this GE solution to save energy?
It sounds like the thremostat may be shorting out they are not to exspensive to replace.
It it constantly triping there is a wire touching somewhere.
May 16, 2010 | General Electric GE SmartWater Household...
My old gas heater wall unit doesnt kick off when it gets to temp.
Move the thermostat closer to the return air or replace the therostat.
Dec 20, 2009 | Cozy (W352E) Heater
Heater blowing cold air 1998 eddy bauer temp control blows cold air ,heater control was just replaced
Low fluid or bad therostat if it does it when engine is warmed up.Heater control valve replaced or mixing valve? If so you have a vacuum hose disconected
Oct 31, 2009 | 1998 Ford Explorer
Heater/air stop blowing after car is run for maybe 30-45 min.
I had this same problem. Your blower is going out. Just replace the blower. Its a siple fix, and its pretty cheap.
Feb 03, 2009 | 1991 Oldsmobile Cutlass Ciera
Emmersion tank wireing
if it's 110 the black is the postive voltage, the white is either the negative of the voltage or hot for 220 and the green is the ground.
Sep 02, 2008 | Water Heaters
Honeywell therostat wiring help
Don't assume the wires at the thermistate are correct.
I had similar and had to go all the way back to the heat/AC controller board. I found the colors weren't attached per spec so was fighting the origional installation at the new thermistat.
Also some digital won't control mutizones proerly
Dec 15, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
