Question about Viking Kitchen Ranges
I have a viking VGIS480-6GDSS range the oven door will only open 1/3 of the way. I need to get the door opened. I need either the schematics or other information to get the door operational.
  • captrick Aug 27, 2008
    I will go to the house and try that solution. However, does this mean every time I have to do this or just this once. Why did the stove door stop in this position
    President:
  • 1,952 Answers
Start ur oven and increase the temperature then open it...it ll open fully
Posted on Aug 27, 2008
    Master:
  • 521 Answers
  • 5 more comments
  • tech expert12 Aug 27, 2008
    check the link which i have given.if it does not solve your problem this is one of the best link just insert proper model number of your product and you can get proper details of your product with solution.
    http://www.autozone.com
    by mistake i gave you the auto reparing link this is the proper one below.sorry for inconvience
    http://www.partselect.com
    thats one of the best link for your problem if nothing helps try this.
    www.applianceaid.com
    http://www.applianceaid.com/
    this link is having every thing with proper diagrams.and proper solutions.
    Most microwave door switches can be tested for continuity to see if the switch has failed. This can "fool" you sometimes. This switch looks fine, tested fine with an ohm meter and even made the "click" noise ok when we pressed on the actuator button.
    BUT,
    Once we opened up the switch, it became clear this switch's contacts where being overheated and failing = new switch time.
    This switch "looked" ok, "checked" ok with an ohm meter...but as you can see...it is not ok.
    for proper pictures of the door switch and how to check the connection just click the link and every thing will appear in front of your screen follow the steps and you can make your unit working.the following link will also help if you receive any problem further
    http://www.applianceaid.com/micro2.html
I have an Eaton Viking stove that has a broken baking element. Is there anyplace that can supply one for me.
Amazon or direct
Amazon.com: Bake Element for Viking Range, PJ010004: Appliances
https://www.amazon.com/Bake-Element-Viking-Range-PJ010004/dp/B00OJ5VL0U
Rating: 4.8 - ‎17 reviews
Buy Bake Element for Viking Range, PJ010004: Range Parts & Accessories - Amazon.com ? FREE DELIVERY possible on eligible purchases.
Viking Parts by Viking - Factory Parts for Viking Appliances
www.allvikingparts.com/ Need a part for a Viking Range, Stove, Oven, Grill, Refrigerator or Dishwasher? We stock thousands of Genuine Viking parts.
Locate Your Viking Model and Serial Number - Allvikingparts
https://www.allvikingparts.com/Articles.asp?ID=142 What do Viking Model Number and Serial Numbers Look Like? Viking ... For Viking Open Burner Ranges and Rangetops(You have an Open Burner Range or ... Eaton Viking stove Google Search
Mar 13, 2017 | Heating & Cooling
My viking oven door has literally fallen off the left hand side hinge - is this a diy FIX?
The door slides onto the two hinges and is held in place with two gravity operated latches. I'm not sure of the condition of your range but it sounds like the door was forced or lifted rapidly allowing the one side to release. The only solution I know of is to remove the other side and reinstall. The hinges have multiple locking positions so the next time you are cleaning your oven, open the door about 8 inches, find the small latches in the door hinge groove, and hold them upwards as you lift the door towards yourself.
The hinges should remain slightly opened. For installation, lower the door onto the hinge posts and pull it outwards slightly.
Oct 27, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
VIKING STOVE DOOR IS LOCKED AND WILL NOT OPEN , STOVE WAS IN A SELF CLEANING MODE AND DOOR WON'T OPEN AFTER CYCLE COMPLETE
unplug or turn off breaker to stove for 10 minutes...then try to gently open.....the oven has to be completely cool before it will unlock....when cleaning is done release lock before turning cleaning off
Nov 28, 2009 | Viking VGSC306-4B Gas Kitchen Range
I have a viking VGIC365-6bss I pre-heated oven to 500 degrees and now the oven door will not open.
One of the door hinges was loose. You have to lift the door by the handle to open it.
Nov 26, 2009 | Viking VGIC365-6B Gas Kitchen Range
Viking VGSC366 6B oven door won t open fully
Sounds as though the hinges are broken. Door will have to be removed and hinges replaced
Mar 02, 2009 | Viking VGSC366-6B Gas Kitchen Range
VGSC3054 oven door won't open
After frantically calling Viking hdqtrs and several repair shops for their advice and experience, it turned out that after my husband fiddled further with it, something got unstuck and it miraculously opened all the way again. Don't think we'll ever know what caused it in the first place , but it works now.
Oct 10, 2008 | Viking VDSC305-4B Dual Fuel (Electric and...
Viking Range oven door does not close properly
sounds like the door hinges need replaced. order a part #PC020009 qty 2
Jan 12, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking 36
The door can be removed from the hinge assembly by lifting upwards and outwards while the door is only slightly open - no hardware needs to be removed to get the door off. My door VGIC366 hinges did the same thing a few years ago, and simply cleaning them fixed the problem entirely.
Dec 02, 2007 | Viking VGSC366-6B Gas Kitchen Range
Oven door hinge adjustment...?
Regarding the oven door not closing all the way and dropping suddernly to the floor, I called a local authorized service company and asked if there was a door spring (no). So the recommended solution is to have the hinges replaced. However, since the oven door didn't really hold its open position from the beginning, when it was brand new back in 01, I'm going to see if a new Viking oven has the same defect as ours. Then, it would seem like a good idea to take a chance on having it repaired.
Is replacing a set of oven door hinges something a person with reasonable mechanical aptitude can do?
Nov 24, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Kitchen Ranges Logo
342 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
