Question about Stainless Refrigerators
Few surface scratches on fridge door handle and front panel area. how to fix
  • 1,543 Answers
There is a product called scratch b gone, available from appliance parts sources.
Posted on Aug 28, 2008
Refridgerator door shutting causes freezer door to open
Check for a draft connecting main body to freezer body, theory is air compression transfer from main compartment to the (smaller) freezer compartment. also a quick fix would be to add more magnet strip or bare the metal that makes contact to the magnet strip that seals the door, if its a latch, Inspect the surface area that locks the latch to mount. Draft checking is achieved by blowing a fan into the smaller compartment, vice versa and having strands of string hanging around in the opposite compartment, if the string nudge indicates an air passage point. Also, check the level of the fridge, if the fridge is uneven (assuming the front is tilted downward) the momentum of the door closing will push the fridge backwards and whip it forward effectively opening the freezer door.
Oct 14, 2011 | Refrigerators
How to remove front door handles or window on ford tranit van model 1997
ou need to slip the flat side of the handle removal tool just behind where the handle meets the door panel so the flat side is against the door panel. Be careful not to tear or scratch any panel materials!
  • 2 Once the tool is in place, turn the window handle a little bit at a time in both directions while simultaneously putting downward pressure toward the handle with the tool until the "C" clip retainer gets caught and is pushed out of it's slot. This retainer may jump away so you want to keep a close eye out.
    This process is more of a manipulation which may take a few moments until the tool catches the clip since you can't see back there. A little patience here and don't force anything!
  • 3 install-car-window-crank-handles-1.3-800x800.jpg Typical window crank handles. Notice where the the "C" clip is located. Once the retaining clip has been removed you should be able to pull the handle straight off of the gear it is on. It may take a little force and you should only work it off from the attachment area and not from the arm of the handle.
  • 4 To reinstall the handle you will need to set the retaining clip just over the stem part of the window handle that will fit back over the gear. You will see the slot the "C" retainer clip will fit over. Press the clip "partially" over the slot, so that when you press forward, once the handle is on the gear, with your tool it will snap forward and set into the groove which will lock it in.
  • 5 Once the handle is in place with your "C" retainer in place, slip the same removal tool behind the handle and between the door panel and push forward as you gently turn the handle until the "C" clip catches and slips over the entire handle locking itself down. It may take a few tries and a little patience.
  • 6 Once you feel the clip catch, you can test to be sure it is in correctly by trying to pull the handle off from the attachment area, where it is attached to the gear, not at the handles end. If the clip has truly caught, it will not pull off.
  • Oct 05, 2011 | Ford Cars & Trucks
    How do you remove a door panel off a 1997 sierra 1500
    There will be 2 either screws or bolts in the pull pocket of your door panel (arm rest area you use to pull door shut). As well use a clip tool or flat head screwdriver and pop off the little cover that goes behind your inner door handle, be gentle. there will be a screw behind there if i remember correct. as well there is a cover clip just under the part of the trim panel that goes up to the mirror area pop that off. once you have all those handled the rest is just held on by clips to save you grief with scratching the interior of the door begin near the speaker and rocker panel. Work your way around if you begin at the big opening of your door you may scratch the paint and will see it. Best used for this is a automotive clip remover tool. door panel will then be off
    Dec 31, 2010 | 1997 GMC Sierra
    How do you get fine scratches of the stainless steel door?
    Firstly remove the handle, find the "allen" screws at underside of handle ends. Start first with a coarse towel and "re-scratch" the area. If that was not enough becoming more aggressive, use much care/ gentle pressure- a 3m scotch brite #7447 "going with the grain", you in essence are removing those scratches with scratches. Use DeBruce Polish with the grain for rourine cleaning and touch-ups. We use DeBruce Polish on all of our stainless steel. Non-toxic, non-abrasive and odorless, DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
    Apr 26, 2010 | Fisher and Paykel E522B Stainless Steel...
    My Kenmore HE dryer door handle has cracked. How
    Carefully remove the door from the dryer by removing the screws from the hinges and lie on a flat surface face down. Lay a towel under the door to prevent scratching the door window. Remove the screws from the back of the dryer door and the hinge. The back panel should lift off exposing the screws holding the handle in place.
    Searspartsdirect.com has some excellent exploded view diagrams that you can work from as well.
    If you have questions, please let me know. I hope this helps you.
    Sep 30, 2009 | Kenmore Elite HE4 Electric Dryer
    He3 door handle repair
    Carefully remove the door from the front of the dryer and lie on a flat surface face down. Lay a towel under the door to prevent scratching the door window. Remove the screws from the back of the dryer door and the hinge. The back panel should lift off exposing the screws holding the handle in place.
    Jul 21, 2009 | Kenmore Elite HE4 Electric Dryer
    Condensation on refrigerator front btwn top freezer and refrigerator doors
    I have the same problem with my frig in the basement. I get condensation and resulting mold on the top outer surface and related areas. This is from the surface being cold, with resulting outside moist air condensing on the cold surface. Best solution - spray/wipe the surface with a bleach and water solution, let it soak a few minutes, then wipe off with a rag. Add a drop of dishwasher soap to a mixture of roughly 4 parts water to one part bleach. Repeat if necessary. Do this as often as the problem seems to creep up again. Good luck!
    Handyman in NJ
    Oct 01, 2008 | Frigidaire FRT18B4A Top Freezer...
    Scratch on stainless steel Kenmore fridge
    brillo a little harsh, finer steel wool would be better ive even used the scour side of the sponge, using wd40 as a "cutting oil" lightly go over scratched area. look close and follow the grain of the S/S. just likje wood S/S has a grain direction
    Feb 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
    GE Refrigerator side by side loose door handles
    I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
    Oct 29, 2007 | GE GSH22JFR Side by Side Refrigerator
    Refrigerators Logo
    117 people viewed this question
    Top Stainless Refrigerators Experts
    Dan Webster
    Dan Webster
    billconfused
    Are you a Stainless Refrigerator Expert? Answer questions, earn points and help others
