Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
(hedge trimmer blades do not move back and forth. have lossened the blade screws,replugged unit back on and still no blade movement.motor is making a noise liked it is jammed.there is no material between the blades to cause a jam. HELP. (Black $ Decker 22" Elec. hedge trimmer #HT22D Type 1)
  • fellerT Oct 29, 2008
    hedge trimmer blades do not move, makes sound like it is jammed, nothing in the blades, have unplugged and replugged unit in
    Champion:
  • 313 Answers
You know what the problem is. it the motor magnetic ring that is
broken. it also called stationary parts of the motor.
Posted on Aug 29, 2008
B&D Hedge Trimmer (HT33) was working yesterday but not today. Motor sounds fine & the blades move back & forth ... just not cutting any foliage ... any ideas?
Mechanical issue. Make sure that the screw that holds the moving blades up against the non moving blade is adjusted properly. If loose, the blades will not be close together during the cutting stroke and no cutting will ensue.
Jul 05, 2015 | Garden
Neuton cordless hedge trimmer may need new motor. the blade does not go back and forth
Primary gear on motor shaft may be stripped, no source for replacement known. I have the same problem motor runs but blades do not move.
Feb 19, 2012 | Black & Decker Garden
Hedge trimmer blades dont move although the electric is still getting to the motor you can still here the motor turning but no movement from the blades
Likely the pin in the gear has sheared. You will need to replace it. It is designed to shear to protect the motor.
Aug 23, 2011 | Garden
16" B&D Hedge Trimmer, No.
motor smoking is an electrical fault internally
brushes , armature of field windings problem
take it in for a proper diagnosis
Nov 13, 2017 | Black & Decker 16Inch Hedge Trimmer
I have a Black and Decker 17" Hedge Trimmer
id check the electric motor first, was it whining when it was going? like maby the brushes in the motor are worn out. if so u can maby get replacements
Mar 22, 2011 | Black & Decker 17 in Hedge Trimmer
Blade moves back and forth,but won't cut anything
Check the bolts or screws holding the blades together are tight but not so tight that they cant move.
Ensure blades are sharp.
Feb 02, 2011 | Poulan Ght225 25cc Gas Hedge Trimmer
Blades not moving on ss24 weedeater
I just disassembled a SS24 hedge trimmer that had the same problem of the blades not moving. The problem is that there are 2 or 3 teeth on the helical gear that are missing. Consequently, the small gear on the motor shaft cannot continuously engage the gear that moves the blades back and forth.
May 27, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
Hedge trimmer blade not moving
I have a Troy-Bilt gas powered hedge trimmer. My blades would not move. After tearing it apart, I found that there were some spacers under the 5 or 6 screws along the blades. These spacers are steel and designed so that you don't overtighten the screws. However, around those steel spacers, there is a teflon type material that makes the oval shape of the slot. That teflon had fallen apart and lodged so that the blades would not move. I removed the teflon and put the spacers back in and it now works fine. There is a little play between the spacer and the edge of the slot and it will probably eventually wear out but at least I got a few more cuttings off of it.
Jul 04, 2009 | Black & Decker Black Decker 16" Hedge...
Electic trimmer
You're going to take off like 20 screws including the ones that hold the handle and the hood at the base of the blade. You open it like a clamshell. There is a black plastic cover at the very bottom that covers the gear wheels (one tiny wheel that comes from the motor and a large wheel that actually moves both blades back and forth). The black plastic cover is no attached with screws. You just remove it so you can get to the gears. Now you oil and manipulate the large gear wheel until it comes loose and you can see the blades move back and forth. Put the whole thing back together and you are ready to go!
Jun 12, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
294 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
