Question about HP 22" Widescreen Flat Panel TFT LCD HD Monitor
HP w1907 19' Widescreen Flat-Panel
This monitor has power, but when it is on it goes dark. When I turn off and on the power, the screen is visible but then in two seconds it goes black. What is the problem here?
  • 2 more comments
  • Elizabeth Rendon Nov 10, 2008
    Jaime,
    HP's monitor is a defected because the backlight is bad. You will need to chat with online technician or call them. Online technician web address link is https://wimpro2.cce.hp.com/ChatEntry/Cha...
    You must fill in your name and other information, however my desktop product that I have is an HP Pavilion, you can change the product from this link right hand side. Hope this is helpful.
  • Anonymous Jan 13, 2009
    the display is Okey but the Backlight do not function. What should I do?
  • Anonymous Apr 12, 2009
    I have a HP w1907 and the screen keedps going black. I have only had this for approx. 1 year- how do I fix this
  • jaime 123 May 11, 2010
    MYCOMPUTER WHEN I STOPWORKING IT GOES DAEK AND I TURNET OFF AND IT GOES NORMALL BUT FIRST IT GOES TO THE MENU IT TURNS OFF
I have the identical problem, hitting it fixed it for a few weeks, now im lost.
Posted on Oct 24, 2008
The monitor Westinghouse model LCM-19w4 when I turn on the computer the screen remains black even with a green light on and I can use a flashlight to see the screen. When I turn it on and off the scre
It's mostly likely a bad capacitor in the main power supply of your monitor. If you're brave enough to dismantle it, look for capacitors that're "crowned", and sometimes even rupture from overheating in such circumstances. You can order replacements from Digi-Key if you can figure out which might be your problem, but I'm not sure I recommend you try this unless you have at least SOME soldering/desoldering skills or a friend who does. You COULD wind up worse off. It's up to you, only YOU know your personal skill level for such tasks. And do I need to say, UNPLUG it before dismantiling? :)
Mar 16, 2014 | Westinghouse 22" Widescreen LCD Flat Panel...
Monitor goes dark after about 2 seconds
I have the same monitor, its a power supply problem from the computer most likely. check the cable connections etc... I would get a service call from an authorized dealer near you ... about $120.00. Hope this helps:)
Jul 24, 2010 | HP Vs17 17" LCD Flat Panel Monitor
DELL 2208WFP LCD-Comes on normally, but almost immediately goes dark You can see something on the screen if you look closely. Turn it off and back on you see it then dark. any help?
I believe the power led button is still on while the screen goes dark, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes dark after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes dark.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Using my hanspree jm01-22 through vga cable alls fine except lack of brightness on the screen,ive turned the brightness and contrast up on the monitor and its still fairly dark,appreciate any help
It does sound like it had logic issue that seding the dimming command to the backlight inverter circuits to dim down the lamps. Yoy may have to look inside.
Please look here to see what ususlly goes wrong with the monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 31, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
My hannspree hs257hps monitor keeps going dark after a short period of time. I can turn it off and on and it works for a while but after a few minutes it goes dark again
backlight inverter is loose or bad.. dissasemble and check..shile a light on it while it is dark , but still on ..just like you would with a laptop
Jan 10, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Monitor goes dark... can still see the screen faintly, have to turn the monitor on and off to get the picture to " stick"..
ok, we have two options here, either the power inverter that turns on the backlight has stoped working or the backlight itself is not working. in these both situations, the best for you will be to ask to a local technician to replace it for you. but you may want to verify first if it's worth it to repair due to the low prices on lcd monitors nowadays.
Dec 12, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Element 26 model ELCHS 261. The tv powers up ok but
has problem on the board.the solder is loose or loose solder
Jul 18, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Emachine 19" Widescreen Flat-Panel TFT-LCD Monitor
Your power/inverter board is in need of an overhaul.
The capacitors are failing and possibly a transistor.
If the screen showed any redness or pink whebn it was working, Then there is a slight chance that one or more of the 4 lightbulbs in the screen was going bad and finally went.
If you take it apart and send me a picture, I may be able to tell by looking at it.
I repair these boards on ebay
bammbammfran
Nov 05, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
HP 22" Widescreen Flat Panel TFT LCD HD Monitor Logo
278 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
