Question about Palm Tungsten T5 - Multilingual Handheld
Expansion card doesn't stay in.
Expansion card does not fit in slot and doesn't stay inserted.
If the expansion card will not lock in when inserted, the mechanism may be broken. If all else fails, the spring can be removed from the mechanism, and the "pop-up" feature disabled. Instructions here http://cfgraf.com/palmt5fix/palmt5fix.html
Posted on Mar 10, 2006
    Master:
  • 903 Answers
Problems inserting expansion cards, or keeping them in your device, may have a simple solution. Try these first: * Make sure the expansion card is facing the correct way. See the handbook for your device for illustrations. * Expansion cards do not fit into the slot if not oriented properly. If a MultiMediaCard (MMC) slides all the way through, it does not operate correctly. Make sure to fit cards carefully in the slot. * The mechanism of the expansion slot is called "push-push." Much like a glass cabinet door, you push to insert the card, and then push it in again to get the mechanism to release. Expansion cards do not need to be forced out of the expansion slot. * Though most expansion cards are notched at the top for removal with a fingernail or other such object, removing the card this away may damage the mechanism. Use an object only when a push fails to release the card. Please be aware that you could damage your handheld if you remove a card improperly, or insert objects other than expansion cards into the slot. * Expansion slots damaged by forced removal of the card do not release the card when pushed, and could refuse to ?lock? the card in the slot. Expansion slot damage can only be repaired by having the entire handheld serviced. * Some expansion cards labeled as SD or MMC do not actually conform to the SD or MMC specification.
Posted on Sep 07, 2005
Installing additional memory into my Jitterbug smartphone--How do I do it?
Per the Jitterbug Smartphone manual, on page 124:
https://www.greatcall.com/docs/default-source/pdfs/jitterbug-smart-user-guide.pdf
Adding more Memory Your Jitterbug features a microSD expansion slot to add up to an additional 32 GB of memory. The following is how to add more memory:
1. Remove the Back Cover using the Back Cover Release notch found on the bottom corner.
2. Locate the microSD expansion slot, which is below the External Speaker, and carefully insert the microSD card into the expansion slot until it clicks into place.
3. Replace the Back Cover.
IMPORTANT! Do not remove the SIM Card located opposite of the microSD expansion slot. Tampering of the SIM Card may cause issues with connectivity to the GreatCall network.
May 19, 2017 | Cell Phones
Wifi card Intel Centrino Advanced-N 6205 not fitting in designated PCI slot on new motherboard.
Make sure that the opening in the case is properly aligned with the PC slot of the notebook. If it is not - disassemble and correct - assuming a PC (the old "PCMCIA") card is what you're trying to insert.
If you're talking about a connector on the mainboard that supports a built in Wifi PCB connector cable or an expansion slot on a desktop PC, please indicate exactly what you have.
Mar 19, 2015 | Lenovo 429033U - Thinkpad X220 I5-2540m...
Fitting a Gforce video card in a veriton 5700GX
Your restrictions are based on available slot size and version. So get one that fits PCI-e x16.
Could not locate PCI version so check your manual, because the slots are backward compatible. Meaning you can connect a Ver 1 card into a Ver 3 slot, but not the other way around.
Expansion Slots - 1x PCI-e x16 slot, 1x PCI-e x1, 2 x PCI slots
Dec 11, 2012 | Computers & Internet
Hi. I have a P8H67 ASUS mother board. it has two PCI 16 Express slots. the first slot is Blue and second slot is black. When I put my 1 GIG DDR2 9500 GT graphic card in the first slot, it gives me 3 beeps...
There are 4 types of expansion slots on this motherboard.
The expansion slots on this motherboard are as follows.
Expansion Slots 1 x PCIe 2.0 x16 (blue)
1 x PCIe 2.0 x16 (x4 mode, black)
1 x PCIe 2.0 x1
1 x PCI
Sep 03, 2011 | ASUS US P8H67M PRO Desktop Motherboard...
Boots up but no video
Either the built on video card is not functioning properly or not activated in the bios. If you have a card that is fitted to an AGP slot it may not be seated properly. If you have a card fitted to an AGP slot and an expansion card placed in the first PCI expansion slot the problem is a conflict between the Video card and the card in that slot. Those two slots share resources. If you are using the built on card make sure it is activated in the Bios, assuming you can get that part to give you video. If you can't there may be a jumper on the board set incorrectly. As a final option, if everything appears to be working correctly it may be the monitor that is malfunctioning or a bent pin on the video cable.
Feb 26, 2011 | HP Pavilion Slimline S3123W Desktop PC -...
Expansion slota
eMachines Support > ET1331 desktop computer > Product Views > Rear View,
http://support.gateway.com/emachines/desktop/2009/emachines/et/ET1831/ET1831rv.shtml
The metal covers that have the Plus sign ( + ) holes, are Expansion Slot Covers.
Insert a flat tipped screwdriver blade in the + sign hole.
Insert the screwdriver blade horizontally, in the + sign hole, on the right side. ( ---- , not vertical I )
Gently bring the back of the screwdriver down.
This will make the metal slot cover, bend the small metal tab that is holding it.
Go to the + sign hole on the Left side. Do the same on the Left side as the above.
Bring the back of the screwdriver up.
Keep working the metal expansion slot cover back, and forth, until the two small metal tabs that are holding it in, break.
Remove the metal expansion slot cover.
Before you begin, ensure that the expansion slot cover you wish to remove, lines up with the wireless adapter card.
Have any questions concerning this, post in a Comment.
Jun 25, 2010 | E-Machines eMachines Refurbished EMA...
SGH-U700 mobile Phone simcard does not fit
Hi, DONT CUT SIM!
Sim cards on the samsungs slot into sim reader which is found under battery. If you remove the battery you should see where it goes. The slot you are referring to sounds like the memory card slot which is an expansion slot if you want to increase the memory size for file storage. Hope that helps?
Apr 30, 2009 | Samsung SGH-U700 Cellular Phone
Monitor screen stays blank
HP desktop computer? Change the monitor cable. The cable from the monitor to the computer, may be bad.
Happens.
If this doesn't solve it then I suggest the GPU is bad. Graphics Processing Unit. If you have Integrated Graphics, (Also referred to as 'On-Board'), then I suggest buying an average, inexpensive graphics card, and installing it.
You'll have to see what expansion slot, your computer uses for graphics. It may be a PCI slot, or an AGP slot, or a PCI Express x16 slot.
Clear as mud on that last one? Let me give you some links, that might help clear up what an Expansion slot is, and the three types of expansion slots used for a graphics card.
1.Expansion slot:http://en.wikipedia.org/wiki/Expansion_slot
2.PCI (local bus):http://en.wikipedia.org/wiki/PCI_(bus)
3.AGP:http://en.wikipedia.org/wiki/AGP
4.http://en.wikipedia.org/wiki/PCI_Express
5.http://en.wikipedia.org/wiki/File:Asus_a8n_VMCSM02.jpg
The link above (No.5) shows a photo of an average motherboard. At the top right you will see two White slots. Those are PCI expansion slots.
Below the PCI slots is a PCI Express x16 slot. It is Black in color.
Apr 10, 2009 | Computers & Internet
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Cannot see any SD card in expansion slot
The first thing to try is a soft reset while the card is inserted.
Sep 11, 2005 | HP iPAQ H2210 Pocket PC
Palm Tungsten T5 - Multilingual Handheld Logo
178 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
