Question about SanDisk Sansa e250 MP3 Player
Recovery mode how do u enable the hold swith
  • Anonymous Aug 30, 2008
    when i m start my sansa, he gave me '' load main image failed switch to recovery mode.'' only that
Just move it till it clicks. it's on the top
Posted on Aug 30, 2008
How to put arnova 7 g3 in recovery mode
make sure the tablet is off, then push and hold the reset button(small hole on same side as power button), while holding the reset down push and hold the power button. continue holding both buttons until you see the "Arnova" flash screen, then release the two buttons. this should put you in recovery/download mode... it is not touch enabled though, and there are no physical buttons on the tablet, so you will most likely need the Rockchip flashing tool. Good luck
Jan 19, 2013 | Archos ARNOVA 7b G3
My i phone is disabled what do i do ?
Hy follow this steps to hard reset your device:1. Swith of your phone and hold pressed "menu"button and press switch on button, hold pressed when it saws recovery mode , follow the the instruction.
also can visit
if my suggest helped post like.
Jun 20, 2012 | Cell Phones
When i try to play soul calibyr broken destiny, it says something like, "game cannot be started (FFFFFFF8)
Are you using a modded PSP? If so, try the following.
The steps below fixed this issue that a user like yourself was having on his PSP.
Enable EBOOT.BIN in recovery mode. This is how you do it:
  1. Go to the recovery menu by turning your PSP off and powering it back up while holding the R-trigger
  2. Go to Advanced -> Advanced Configuration
  3. Set the value for Excute BOOT.BIN in UMD / ISO to Enabled
  4. Exit recovery mode and start the game
May 11, 2011 | Computers & Internet
My recovery mode says "enter USB2.0 MSD mode" what do i do
Hi there.
I can understand your issue. When you say "enter USB2.0 MSD mode"getting into recovery mode. Then i'd say firmware needs to be updated..
Please follow the steps..
There are files in the player that might be corrupted causing the device to freeze and stop responding.
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
SOLUTION 2 - Force MSC or Recovery mode then update to the latest firmware.
STEP 1 - Force MSC or go to Recovery mode
For e200v1/e200R (Recovery mode only): Connecting in Recovery mode
1. On your Sansa player, press and hold the Power/Menu button for 15 seconds to turn the device completely off.
2. Slide the Hold switch so the orange portion shows.
3. On your PC, double-click My Computer
4. On your Sansa player, press and hold the REC button while connecting it to the PC.
5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer.
For e200v2 (Force MSC mode only): Enabling MSC mode
1. Turn device OFF.
2. Slide the hold switch to the direction of the headphone jack so an orange color would show putting the device on Hold.
3. Press and hold the ( |<< ) button while connecting the device to the PC.
STEP 2 - Update to the latest firmware manually, as it is described in Method 2
In case you have any further inquiries, please do not hesitate to contact us!
Jan 04, 2010 | SanDisk Sansa e200 MP3 Player
Laptop does not boot up and recovery from cd gives d2d32 type mismatch error
A couple of things to try in the bios:
1. try changing the SATA mode to IDE for the restore and then back to AHCI mode after it was complete
2. Enable disk to disk recovery mode: To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility,
then select Main from the categories listed at the top of the screen. Find D2D
Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this
value to Enabled.
Jul 11, 2009 | Acer Aspire 5920 AS5920 Notebook
Theft mode i can disable it
if you press the + and - buttons on the front of the monitor at the same time for 10 seconds it disable's it. You can disable it completely by running the software disc and choosing disable Theft Lock.
Apr 15, 2009 | HP Computers & Internet
I don't know how to put flash player on my psp
What Firmware do you have?
Most likely, you will get problems with Sony Firmware. With a Custom Firmware like 3.77 M33.
Then enable it in the recovery mode... That is:
Press and Hold L1 and put the PSP on....
You will then go into the Recovery Mode, and you can enable Flash player there.
Jul 03, 2008 | Sony PlayStation Portable (PSP) Console
Problem with charging
try performing recovery mode on the player then after performing recovery mode update the firmware of your player. Recovery mode is > Enable Hold Switch + Press Record Button + Menu Button
Oct 08, 2007 | SanDisk Sansa e250 MP3 Player
Sansa not connecting to computer
try going to recovery mode and upgarade the firmware of the player. Recovery mode = enable hold switch press the record button and press the menu button until it shows welcome to recovery mode on the player.
Jul 26, 2007 | SanDisk Sansa e250 MP3 Player
Jul 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
227 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
