Question about Maytag MSD2732GR Side by Side Refrigerator
  • NJDCBLANK Sep 02, 2008
    The temps are fine. How does one fix this? Can I do it?
  • 1,462 Answers
Indicated appliance is overgassed assuming fridge and freezer temps are ok
Posted on Aug 28, 2008
Not easy to do without the right gear. if you can lay hands on a line tap valve (valve which bolts onto the compressor pipe and pierces a hole) then you can try letting out a little gas at a time but only let gas out when compressor is not working and has been off for a few minutes
Posted on Sep 02, 2008
Ice forming under the freezer drawer & on drain tube water pooling in floor Cleared drain tube, what else?
Whirlpool corp., whom made this unit, had a bad design for the defrost drain tube by the compressor. Order part W10619951 and install. This is a kit to change out the current drain tube to a better one. You still have to defrost the frozen defrost drain tube but this will fix it for good.
Aug 01, 2015 | Maytag MFI2269VEM Monochromatic Stainless...
Ice inside my fridge
Check door seal intact and sealing ok, clean rear compressor section of all dust/ dirt/ fluff and check drain hole on rear of water should not pool inside but run away outside rear. Lift/ adjust door to make sure it closes properly.
May 17, 2012 | Samsung Refrigerators
Leaking under neath front of refrigerator
Usually any defrost water sits in a plastic pan and evaporates away in normal operation. If the pan becomes brittle it cracks and leaks water. Pull the fridge out and look on top of the black pot (compressor) Is there a plastic drain pan sat on top of it?
Sometimes if the fridge is working hard a lump of ice can form on the pipework going back to the compressor which melts causing some water at the front of the fridge.
Lastly, the insulation under the fridge may have broken down, allowing condensation to form and drip. If the drain was blocked, the water would be inside the fridge, not underneath.
Apr 20, 2012 | Kenmore Refrigerators
Fan inside fridge not blowing
is the ice on the floor of the freezer?if so the freezer drain is blocked,ice is building up and the fan blade is jammed from the ice.when the machine gets cold ice forms on the evap coil in the freezer,when it goes into defrost the heater turns on and melts the ice and the water drains down a hole under the evap coil and the water goes down into a pan where it evaporates from the heat of the compressor and condenser coil but your drain is blocked and the water is leaking onto the floor of the freezer instead of going down the drain,i use a steemer to clear blocked drains but if you don't have a steemer you can use a hair dryer to melt out the ice,on your machine you can pull out the machine from the wall,remove the back bottom panel and unplug it first,then look at the right side,you'll see a plastic drain line with a wire tie around it,that's the drain line,you might have to cut the tie and then pull the drain line down and remove it,now go to the freezer,you have to remove the door and racks and then remove the back inside wall of the freezer,melt out all the ice that you see with the hair dryer,after you melt the ice go to the back and snake a long plastic tie like the one that's on the drain line or if you have a piece of 1/4 inch plastic water line or anything you can think of to snake through the hole where the drain line came off of,i would use plastic,if you use metal be careful not to damage anything,then pour hot water into the drain in the freezer,if it drains out the back hole you're done,if not keep hitting it with heat and if you have a turkey baster or anything that will push air down the hole to clear it and when you think it's clear pour more hot water into the hole until it drains.hope this helps and good luck with your machine.
Nov 15, 2011 | LG LFD25860TT Titanium French Door...
Ice forming on a line from the compressor and melting , ruining my floor
indicates low refrigerant gas, you will need a technician to top up the gas after ensuring there is no leak in the system
Aug 05, 2011 | Whirlpool Refrigerators
Pool of frozen water forms in the bottom of the freezer section which melts from time to time and flows out onto the floor. Can avoid this by regularly chipping the ice away. Overall the appliance is...
you need to remove all the ice and then if you look way in the back you will see a drain , which is plugged you will have to clean it out .
Feb 15, 2011 | Refrigerators
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
There is water dripping down the inside back of the freezer side
Had this happen twice. My problem was the drain line that goes to the pan underneath was plugged. Had to pull it apart to get to the drain and unplug it.
May 23, 2017 | Refrigerators
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
Ice is forming in the bottom of the freezer compartment, and water forms under the fridge freezer. Also the comperssor does not always respond to the freezer setting when the stat is turned...
compressor may not start for quite a time even if you change the stat setting. this is deliberate.
ice on floor of the freezer is caused by the drain being blocked - probably with ice. remove the back panel inside the freezer and melt the ice off with a hairdryer. you will have to clear the drain itself with hot water - needs a bit of patience.
this can just happen with time but you may have a fault on the defrost system which is causing it
Jun 25, 2008 | Admiral Refrigerators
Maytag MSD2732GR Side by Side Refrigerator Logo
80 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
