Question about Intertherm Heating & Cooling
I have an electonic start furnace. Everything kicks on but the heat. It's like the burners won't light up. I don't have a lot of money to fix it so I was wondering if I could somehow trouble shoot the problem myself
Yes! The furnace goes through 4--steps for complete run time. Step -1 the small vent fan comes on, and prove it thru the small rubber tube that sucks the switch close and tells the c.b. its turnning, Step 2.. the glow plug glow and 08 seconds later, Step -3 then the gas valve open and dump in gas ,which ignites and heat up the box. and proves it got flame through a flame sensor (pin) sticking in the flame .& Step -4, the box heats up to a predetermined temp. and turn on the fan! thats all. Thank-you-very-much!
Posted on Aug 27, 2008
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
I have a 50s Coleman gas floor furnace. Normally works great in my 720 sq/ft house. This year I cleaned it, turned gas on, lit pilot, cranked the burner on and turned the thermostat up like usual....
Make sure the vent that the heat comes out of is open and clean, make sure all pumps to it are connected, make sure its not an electrical problem because that could be dangerous. If none of that helps, call a repair man.
Nov 06, 2013 | Heating & Cooling
Furnace burners won't ignite
Assuming this is a gas furnace, when the thermostat calls for heat the pilot heats an igniter to produce voltage that opens the burner gas valve. In your furnace, the igniter may have failed and the burner can't fire up
Mar 09, 2013 | Sport & Outdoor - Others
I have an oil fired aga the oil will not come throw to the burner
see the following steps:
f the burner doesn't run, set the thermostat a few degrees higher than normal to see if it comes on. If it still doesn't come on, check switches, and breakers and fuses (see the Electrical Service Panel Fix-It Guide). If the unit has a reset button, press it. Also oil the motor at any oil ports (see below). If the unit doesn't want to start and run, first check the c to make sure that the ignition is getting power. If there is power, check the built-in safety controls (see below) that may turn the system off if they perceive problems.
If the burner cycles too often, replace the filter (see below). Also, oil and adjust the blower (see the Forced-Air Distribution Fix-It Guide).
If the burner runs but won't fire, make sure the oil valves are open and that there's oil in the tank. Check the tank level with a clean stick.
If the burner smokes or squeals, shut off the unit, let it cool, and fill the oil cups. Recheck them after the motor has run for an hour.
If the chimney smokes even after the flue has warmed up, the unit is wasting fuel; call for professional repair.
Safety Controls
Oil furnaces and other heat systems include safety devices that monitor operation and turn off the unit if something goes wrong. In some cases, the safety device can be the problem.
If you encounter an operating problem with an oil furnace, first reset the safety and try again.
If the burner kicks off again, shut off all power at the electrical service panel ; the burner motor and ignition may be protected by separate fuses or breakers.
If the sensor has a photocell, wipe it with a clean rag or tissue and see if the furnace starts.
If the safety is a stack switch mounted on the flue, remove the screw holding the unit to the stack, slide it out, and wipe off the sensor.
If the furnace won't start after three tries, seek professional assistance. Unburned oil can accumulate in the combustion chamber and "flash back."
Jul 31, 2012 | Heating & Cooling
I started my forced air furnace yesterday and it worked fine. Today the burner kicks on when the thermostat calls for it, but this morning the burner kicks on, but the fan won't start.
Hello there,
If the burner kicks on but the fan is not starting, then it simply means there is a problem with the blower motor. The problem most likely is that the motor is dusty and need to be cleaned out.
Once the motor sis cleaned out, have it greased and installed back and ensure the wiring is intact, then turn on the furnace and the fan will start to foll. If that does not solve the problem, then it means there is a problem with the blower motor and it meeds to be replaced.
All the best Elect_Comp
Sep 16, 2011 | Heating & Cooling
The furnace will start and run for 5 mins and kick off. Then the burners will not reignite after that. However, after everything cools down (about a half and hour later) it will restart and run for...
Hello, sounds Like the Furnace is tuning off due to the limit switch or rollout switch opening. A limit switch and rollout switch are safety swtiches that will turn off the furnace if it gets to hot or the burners flames are abnormal. Usually a weak blower motor, dirty blower wheel , dirty burners or even a crack in the heat exchanger can cause this problem. Best bet is to call a hvac technician and have them check it out.
Sep 14, 2011 | Heating & Cooling
1986 Weathermaker SX 150 series, model S85X060-CC-1
There are 4 -steps for full run time to kick in a furnace.. step-1, inducer fan runs & prove thru the air tube which closes a switch and tell the circuit board to go to step-2, the igniter lights the pilot & prove its lit by heating the thermocouple, which tells the circuit board to go to step-3, opens the gas valve to dump gas in, which will light from the pilot light, and prove by a flame sensor metal stick on the last burner , which heats up and tell the circuit board Saying, ok , I've got flame.. step-4. when the box heats up, it closes a switch and turn on the main fan...! (Some gas-valves has a brain -or circuit board on top of them and are real sensetive to moisture..)
Sep 05, 2008 | Heating & Cooling
Heating & Cooling Logo
152 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
