Question about Hitachi USB 2.0 to IDE 1.8" Aluminum External Hard Disk Drive Enclosure -- for Drive Case
Hitachi external hard drive recovery
I have a hitachi external USB hard disk 120 GB. recently it has stopped functioning and the light is on in the casing. Windows cannot even detect the USB Drive please help
precious data is on the drive
  • 1 more comment
  • Anonymous Dec 05, 2008
    i m facing this problem also, & when i plug in to my computer automatically hang.
  • Anonymous Jan 27, 2009
    drive letter is no where to be found but drive is functuioning
  • ruudzijlma Mar 06, 2009
    COMPUTER CAN NOT FIND IT, BUT EARLIER NO PROBLEM, BUT STILL CALLING COMPUTER I AM THERE , BUT NOT FINDING.I THINK MISSING STARTING PROGRAM??
  • 734 Answers
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 12, 2008
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Hitachi Simple Drive mini 500 GB USB only ticking sound when plugged in. Eight months old, used sparingly. Any ideas?
The external storage device has several major components:
* USB cable
* external power-supply (your "mini" device may not need one)
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 04, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
I want a converter for Hitachi HTS541612J9SA00 120 GB SATA Hard Drive to usb do you know wich one I need..?
You need a 2.5" inch SATA to USB external harddrive enclosure.
since its a laptop hard drive you need a small case.
for example this one http://www.amazon.com/2-5-SATA-HDD-Enclosure-Black/dp/B0018TCB0O
Aug 07, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
External hard drive device installer error
Has it got its own power supply or is it using a two USB ended cable. It could be your laptop cannot supply enough power via one USB port so that it really needs a two ended cable so that two USB ports will power it up. Try this Mark
Aug 18, 2009 | Hitachi 0A52126 120 GB SATA Hard Drive
HELP! retrieving files from corrupted drive
he should keep the hard drive in the freezer for one day
Apr 24, 2009 | Hitachi Hard Disk Travelstar E5k160 120gb...
Hitachi 80 GB. USB HDD problam.
If you plug it in and it does not appear, it may be choosing the wrong drive letter.
If that drive letter is already in use it will not appear.
Open the start menu, right click on my computer, then choose manage.
Select (on the left) Disk Management.
If it appears in there.
Find the thumbdrive in the list and right-click and choose 'Assign a new drive letter' . Make it like M or somthing far down in the alphabet.
If that does not appear under the disk management then the disk might be physically damaged.
An urban myth (which does sometimes work) includes putting the drive in the freezer for a day or so.
Also remember it might be somthing as simple as a bad cable or port on the computer. Try to access it with a new cable from a diffrent computer.
Apr 23, 2009 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Toshiba 120 GB USB 2.0
check if you have another drive which has the same alphabet as your external drive, if so then go to disk management and change the name of the disk.
Apr 22, 2009 | Toshiba 120GB USB 2.0 Portable External...
Western Digital WD 1200VE; 120 GB external hard drive unable to boot
You need to send it to a data recovery house like Drive Savers. The prices range from 500 to 3000 USD for data recovery and they can't guarantee 100 percent success. The platters need to be removed in a clean room and placed in a unit to read the data. They then copy the data to another drive or to optical disks. Unfortunately when the drive hit the floor the drive sustained physical damage hence not starting up.
Sorry to be the bearer of bad news.
Cheers.
Dec 23, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External hard disk
the Hatachi 80 gig looks the same as the 120 gig verbatum 47558
also had the same blue flashing light and no recognition by XP
I open the case and removed the drive from the pc board. cleaned the contacts and reconected the PC board , the fault was oxidisation
May 30, 2008 | Computers & Internet
WD 120 GB 2.5" hdd not listed in my computer
I HAVE MY PROPERIETRY SOFTWARE WHICH I USE TO FORMAT ANY DISK OF ANY TYPE... AND MAKE ANY TYPE OF PARTITIONS LIKE ALL IN ONE PARTITIONING AND DISK MANAGMENT.
I HAVE STILL NOT REGISTERED AND TRADE MARKED IT. BUT I AM SUCCESFUL IN MY PRACTICE ON VARIUOS HARD DISK DISCOVERIES AND RECOVERIES .EVEN I CAN DO A FULL ZERO LEVEL FORMAT TO ANY HD.
CATCH ME AND REQUEST FIXYA TO ALLOW YOU TO SEND YOUR HDD OR ANY TYPE OF STORAGE MEDIA FOR RECOVERY AND SOLUTIONS. +0+9+3+2+1+1+0+1+7+1+7
Apr 17, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Computers & Internet Logo
913 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
