TV mod #24v510T.I do not seem to get a sound signal out of the bottom two of the three vertical jacks labeled Video 1. I am trying to hook up wireless headphones and these are the only two audio jacks on the back of the set.
  • Lige Aug 27, 2008
    Thanks;
    That's what I thought, just not what I was hoping for.
    But, there are audio output jacks on my Cox cable box, and my Sony DVD recorder installed in line between the Cable box and TV and they do not seem to work either. Am I doing something wrong?
    Lige777@aol.com
  • 4,234 Answers
Sorry to say, but these are audio Input jacks for the Video 1 channel. Your set does not have audio output capability.
Dan
Posted on Aug 27, 2008
How to hookup a bose 321 to a toshiba 58l7300 tv
The Bose system does not appear to have HDMI output. The best-quality method would be to use Component (RGB) cables with analog audio. One RCA pair will be for audio and these are often RED & WHITE connectors, but don't have to be. Any RCA pair will work. Connect these to the Bose RED/WHITE jacks found in the "TV" labeling. Connect the other ends to the Toshiba's RED/WHITE jacks on the bottom row, first two jacks.
Now you need a Component cable. This has three RCA connectors at each end and are traditionally RED, GREEN, and BLUE. Again, colors do not matter as long as you connect the ends so they match. Under the "Component" labeling on the Bose, you will find the three colored jacks. Connect these to the Toshiba's same-colored jacks which are next to the RED/WHITE ones you used previously. These three connectors carry the video signals. They will transfer Hi-Def 1080i signals, not 1080p, but you wouldn't be able to tell the difference.
Switch the input on your TV to "Component".
Dec 29, 2013 | Toshiba Car Audio & Video
How to hook up a cable remote to a Samsung cable box?
    • 1 Examine the back of the your cable box and the back of your Samsung HDTV. Note which cable jacks are of an identical size and color. Those are the ones that can be used to connect the two devices. Samsung HDTVs cluster all the jacks in a single panel near the power cord.
    • 2 Look at the square rectangular boxes labeled "HDMI In." These are for high-definition multimedia interface cables--combination A/V cables that provide the highest possible image and sound clarity. Look at the back of your cable box for an identical jack labeled "HDMI Out." If you see one, connect the two jacks using an HDMI cable. If you don't, you need to use another set of cables to hook up your cable box.
    • Sponsored Links
    • 3 Check for a series of three round jacks labeled "Component In" and color coded in red, green and blue. These are component video jacks, which provide a good HD picture, but not as good as HDMI. If your cable box has an identical set of "Out" jacks, use them to connect the two components.
    • 4 Look for a pair of red and white jacks (possibly connected to a yellow one). These are audio RCA jacks. If you're using component video cables to hook up your cable box, you will need to hook these two up as well: Component video cables don't provide sound. Any cable box that uses component video cables should also have "Out" jacks for RCA audio cables.
    • 5 Find the raised circular jack with a pinhole in the center of a milky white plastic interior. This is the coaxial jack. Samsung HDTVs label them "Ant In." Every cable box should have a corresponding jack labeled "Out" or "Ant Out." If none of the other cable jacks on the cable box match, use a length of coaxial cable to connect the TV to the cable box through these two jacks. You can also use this connection to hook the TV directly to the wall cable.
    • 6 Turn on your TV and cable box, and set the TV to the input jack connected to the cable box. You can do this by pushing the Menu button on the remote, scrolling down to the "Input" option and pushing "Enter." That will let you cycle through the various input options, labeled by cable type (HDMI, component video). Press "Enter" again when you reach the right component, then exit the menu. You should now be able to watch TV as normal.
Read more: How to Hook Up a Cable Box to a Samsung HDTV ' eHow.com http://www.ehow.com/how_4867255_hook-cable-box-samsung-hdtv.html#ixzz2DwgQRtRE
Dec 03, 2012 | Televison & Video
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    Aug 13, 2011 | Panasonic Televison & Video
    How to hook up cable box, dvd player, and tv, to the home theatre system
    Instructions things you'll need:
    • Composite video cable
    • TV
      • 1 Place the front left and right speakers on each side of the TV with the speaker labeled "Center" either above or below the TV screen. Set the rear speakers behind the seating area at head level and place the subwoofer on the floor a few inches away from the wall, which can absorb bass sounds if the sub is pressed against it.
      • 2 Connect the plug on the end of each speaker to the jack labeled for that speaker on the back of the Durabrand receiver. The cables are permanently attached to the speakers, so each may need to be moved closer to the receiver. For example, the left front speaker connects to the jack on the receiver labeled "LF."
      • 3 Plug the video cable from the Video OUT jack on the back of the receiver to a Video Input jack on the back of the TV.
      • 4 Plug in the Durabrand receiver and TV to the electricity and switch on both components.
      • 5 Press the "Input" button on the TV remote several times until the Durabrand signal displays on the screen.
    Mar 25, 2011 | Durabrand STS98RW Theater System
    I need the wireing to hookup to a tv.
    Hi, it depends on the kind of TV your using...
    How to Hook Up a Receiver to an HDTV
    Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
    Instructions
    things you'll need:
    * HD television
    * HD satellite or cable receiver
    * DVD player
    * Stereo receiver
    * AV cables
    * Cable connector
    * HDMI cables
    Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
    Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
    Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
    Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
    Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
    Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
    Tips & Warnings
    Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
    Mar 15, 2011 | Audio Players & Recorders
    I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
    Hi, it's a general process to connect any receiver to a HD TV.
    Things You'll Need:
    * HD television
    * DVD player
    * Stereo receiver
    * AV cables
    * Cable connector
    * HDMI cables
    Instructions
    Tips & Warnings
    Hope it helps.
    Good luck..
    Feb 23, 2011 | Kenwood VR-406 Receiver
    Connection using Component video No Video
    1-Locate the audio/video input jacks AND the component input jacks on the TV.
    Inputs are typically located on the back of the TV, but occasionally are on the sides, top, or bottom. They may also be located behind a hidden panel or door in the television.
    Look for inputs marked Audio and Video IN.
    Do NOT connect the system to anything marked OUT.
    2-Connect the rectangular plug of the Component Video Cable into the Digital AV Out port on the back of the Wii console.
    3-Connect the Component Video Cable to the television as follows. (Note that the Red and White audio cables are bound together with a black band labeled "audio.")
    4-If you do not have a TV/Video button, then the input could be labeled something different. Some common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, AV, or a channel such as 00 or 99.
    http://bit.ly/2ykOBno
    Oct 13, 2017 | Aspire Digital AD-1000 DVD Player
    Why can't we get the sound to work by hooking the DVD player directly to the tv?
    The JVC system is designed to output audio only via the speaker terminals at the rear of the system. There is NO provision to send audio directly to the TV from the system.
    Page 14 of the manual (link provided below - free to download) details the connections available to a TV. These connections are limited to three types of connections: 1) "Video" for standard TVs which is "good" 2) "S-Video" for TVs that have an S-Video input jack which is "better" (both #1 and #2 are considered "composite" types).
    The third type is called "Component" which is used for TV's that are capable of "progressive scan" video input which is "best" for the system. Notice that the jacks on the DVD player are labeled "Y", "Pb" and "Pr", not "Video", "Left" and "Right". This type video signal requires the use of three cables - they do not send audio as you may be used to see on all but the newer TVs. TVs capable of displaying "progressive scan" video have a better looking picture when using these jacks. Incorrectly connecting the video from the DVD to the TV audio inputs (Left & Right) will likely result in noise or hiss from the TV speaker.
    To recap - audio can only be played through the JVC system's speakers. Use the highest quality video jacks that BOTH your TV and the DVD player supports.
    I hope this was Very Helpful and enjoy your DVD and TV!
    http://www.retrevo.com/support/JVC-TH-M505C-Home-Theater-Systems-manual/id/318bh527/t/2/
    Dec 21, 2009 | JVC TH-M505 System
    Televison & Video Logo
    48 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
