Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Dishwasher Leaking Dishwasher leaks from underneath the right front side of appliance. Can't tell exactly where it's leaking from, because of plastic guard/support on underside. All of the connections and hoses are in good shape. I'm assuming that it has something to do with the draining process, as it will leak 2-3 times during a wash cycle. Sometimes it's very little water and sometimes it's as much as a gallon.
  • eab01 Sep 22, 2008
    Our dishwasher also leaks from under the door, on the right side. We have checked all the hoses and drains, and replaced the door gasket. Nothing works.
  • Anonymous Apr 04, 2009
    When the dishwasher is running, water comes from the door
  • 734 Answers
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Dec 12, 2008
I have had water leaking from underneath my dishwasher and have found that on filling, water overflows top of the water inlet unit
My Miele 828 dishwasher started to leak at the front left corner. The leak became worse. I tipped the machine on its side and removed the rubber moulding connecting the base of the drum to the pump. I cleaned it out and refitted it finding two small coins inside. The leak persisted. I took off the top of the machine by unscrewing the two screws on either side and pushing the lid backwards. I switched the machine on and, with a torch could see that the detergent dispenser had detached from the delivery pipe under it. Using advice elsewhere on Fixya I undid the three bolts around the door and the three screws around the detergent dispenser; one is deeply recessed and easily missed. Than I unclipped the drain pipe behind the little door at the bottom left hand corner at the front. The front then hinges out from the left with hinges at the right side making the leaking connection easily accessible. Make sure you get the rubber flange well up the plastic tube as there is no flange on the tube to secure it. A possible design fault but the unit has functioned for ten years before the connection failed.
Sep 24, 2013 | Dishwashers
Frostfree freezer leaking from lower front
From what you have described, without a model number, it sounds like the unit is leaking from possibly going into a defrost cycle. Check to see if you have any ice build up that is now melting or "slushy" in that general area. Water tends to run along the nearest plastic ridges and parts til it can escape underneath.
Jul 31, 2012 | Electrolux Frigidaire Professional Series...
I unclogged the GD by removing the pipes underneath and replaced them tightly. GD seems to be working fine now, but water is slowly leaking from underneath the GD! It appears to be leaking from the...
The leak comes from above where water comes out.
Turn off power before touching wet electrical appliance.
Put stopper in disposal.
Fill sink with water.
Check if water is getting through the putty seal at sink connection.
Next, check if water leaks only when dishwasher runs. Dishwasher drains into garbage disposal.
Last, check tailpiece where it attaches to side of garbage disposal. The tailpiece is usually sealed with a rubber washer. When washer is old, it gets deformed, and then it doesn't seal perfectly when put back.
I use rectorseal on all tubular pipe joints under the sink.
Works on both plastic and rubber washers.
It is gooey and sticky.
Brush it all over the washer, use plenty, then assemble pipes.
The rectorseal assures that joint will not leak.
Oct 25, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The dishwasher is leaking on the right side, could
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
Washer appears to be leaking towards the top back right..
sounds like your main tub seal is leaking, also check the hose running to your water level switch,,and your outter plastic tub could have a crack in it
Feb 15, 2010 | GE WBSR3140DW Top Load Washer
My 91 honda accord is leaking antifreeze underneath by the right front passenger side dont know where it is leaking from?
probably your lower rad hose. shine a flashlight around underneath and see if you see it reflecting off of a liquid trail, that will tell you where the leak is coming from. you can also get leak tracer to add to your coolant that will leave a more visible sign.
Sep 10, 2009 | 1991 Honda Accord
Danby dishwasher leaking from underneath
It is still under warantee-contact the company you bought it from. If you fix it yourself you could void the warantee.
Jun 14, 2009 | Danby 22 in. DDW399 Free-standing...
Dishwasher leaking - Candy CD474
From you're description it seems that the water pump is bad, Some where their is a tag with the Model# and serial# then go to Searspartsdirect.com
Oct 05, 2017 | Dishwashers
Fridge Leaking water from front right hand corner
yes, get a pipe cleaner and put in to the hole to try and clear if not from the back you will find the pipe which will be clipped to a plastic tray on the compressor. unclip and blow up the pipe this will always clear the blockage.
Oct 19, 2006 | AEG SK78800I Compact Refrigerator
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
408 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
