Windows 98 startup
I reloaded windows 98 its at the startup and asks for something to be typed after C:> ANY CLUES TO WHAT I TYPE HERE
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
How did you reload windows 98? Did you use a CD or have you just used a boot floppy disk?
Posted on Aug 27, 2008
  • Dadpie Sep 03, 2008
    Ok, all the floppy disk does is load the CD driver you need. You now need to run Setup from the Windows 98 CD.
    To do this, boot from the floppy again, insert the CD into your CD drive, change to the CD drive on your PC (usually drive D) by typing "cd D:" at the prompt which looks like "C:\>".
    When the prompt changes to "D:\>" then type "setup".
    You should now be able install Windows 98. Good luck.
How would i go about formatting a computer?
How to Format a Computer
Want to know how to format a computer hard drive?Need to learn how to format your computer and start with a clean slate? Formatting a disk prepares the surface of the drive to accept and store data. Computers are often formatted before they are sold, donated, or returned to an employer. Likewise, computers with viruses or errors can be formatted and returned to their "out of the box" settings.
Warning - Formatting hard drive information does not permanently erase the data. Even after a computer has been formatted, deleted files can be easily recovered. If you want to permanently wipe your hard drive by completely overwritting hard drive data, check out WipeDrive.
How to Format Computer Quick Links:
How to Format a Computer with Windows XP
How to Format a Computer with Windows 95, 98, & ME
Wipe All Data Before Formatting
Reinstall Windows XP
Reinstall Windows 95, 98, & ME
Create a Startup Disk
The first step in learning how to format a computer with Windows XP or 2000, is to insert Windows CD and restart your computer.
Your computer should automatically boot from the CD to the Windows Setup Main Menu.
At the Welcome to Setup page, press ENTER.
Press F8 to accept the Windows XP Licensing Agreement.
If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue installing Windows.
How to Format a Computer with Windows 95, 98, or ME
To reinstall Windows, you will need a Startup Diskette and a Windows Installation CD.
Download the Startup Diskette Creator
Note: We recommend using the Startup Diskette available on this page. Other Windows Startup Diskettes may not work with the following steps.
Once you have your Startup Diskette, insert it into the floppy drive and restart your computer.
Select option #1 - Start the computer with CD-ROM support.
After a minute or so, you will see "A:>_".
Type "fdisk" and press Enter.
If asked to enable large disk support, select Y for Yes. (Note: Some versions of Windows 95 may not be compatible with large disk support. Select N here if it does not support the FAT32 file system.)
Select Option #1 - Create DOS partition or Logical DOS Drive.
Select Option #1 - Create Primary DOS Partition.
The drive integrity will be verified.
Unless you are planning to make multiple partitions, select Y when asked if you want to use the maximum available size for the partition and to make the partition active.
The drive integrity will be verified again.
When completed press the Esc key to exit fdisk.
Without removing the floppy disk, press the reset button on the computer or press the keys Ctrl then Alt then Delete and release them together. This will restart the computer.
Again, select the option to Start the computer with CD-ROM support.
When you see A:>, directly above it is a message about your CD-ROM drive. It will tell you the letter assigned to your CD-ROM drive, take note of it.
At the A:>, type "format C:" and press Enter.
Press the Y key then the enter key when asked if you want to proceed with the format.
The format will probably take some time, so be patient.
You will be asked to choose a Volume Label, which is a name for your hard drive. It has no effect on the operation of your computer, you may choose any name you like.
How to Reinstall Windows XP
To reinstall Windows XP or 2000, imply insert Windows CD and restart your computer.
If your hard drive has not been formatted, Windows XP will walk you through the formatting process described above
Your computer will automatically boot from the CD and begin the installation process
How to Reinstall Windows 95, 98, or ME
After formatting your hard drive as described above, insert the Startup Diskette into the floppy drive and restart your computer.
Place the Windows Install CD into the CD-ROM drive.
Type "E:" (where E is the letter assigned to the CD-ROM drive) and press the Enter key.
Type "dir" and press Enter. You will see something like the following:
Volume in drive E is 020409_1121
Direct
Dec 15, 2011 | ASUS Computers & Internet
My operating system was accidentally deleted from my Asus netbook. I want to reboot it with a bootable pendrive but it doesnt work. It gives the message, NTLDR is missing,press ctrl+alt+del
Below is Microsofts solution to your error. Reload the OS with a Microsoft CD format it completely not the fast format option reload from sctratch. If you have no CDrom use an external.
Systems hard disk drive has FAT32 file system. Computer hard disk drive has INT-13 extensions with a system-ID type of 0C in the partition table The heads value in the FAT32 BIOS Pattern Block (BPB) is inaccurate.
To resolve the error message "NTLDR is Missing" follow the below steps: Boot the computer with a Windows 95 or Windows 98 Startup diskette or another bootable diskette with sys.com on it.
At the A:\> prompt type: sys c: <press enter> After pressing enter you should receive the prompt "System Transferred". Once the file system has been transferred reboot the computer without the diskette and attempt to reproduce the error.
Aug 23, 2011 | ASUS Eee Pc 1000Ha 160G Netbook
I want to restore my windows 98
Under normal circumstances, Windows is capable of detecting and recovering from registry errors automatically. If Windows is incapable of this, a previous copy of the registry can be restored manually. Windows makes and stores a backup of the registry when you start your computer successfully each day. By default, five previous copies or the registry are stored. To restore one of these previous copies:
  1. Start your computer, press and hold CTRL, and then choose Safe Mode Command Prompt Only from the Windows 98 Startup menu. If you are running Windows Me, start your computer with the startup disk.
  2. At the MS-DOS prompt, type cd\windows\command, and then press ENTER. Where windows is the name of the folder in which Windows is installed.
  3. At the C: prompt, type scanreg /restore, and then press ENTER.
  4. Select the previous registry you want to restore, and then press ENTER.NOTE: A properly working registry has the word "Started" next to the date.
  5. When you receive notification that you restored a properly working registry, press ENTER to restart your computer
Apr 23, 2010 | Microsoft Windows 98 for PC
Message read/ missing export user 32.dll update layerd window.
Greetings,
To resolve this issue, follow these steps:
  1. Restart your computer using the Windows 98 or Windows Me Startup disk.
  2. On the Startup menu, choose the correct CD-ROM support for your computer.
  3. Type the following commands, pressing ENTER after each command:
    c:
    cd <windows>\system
    ren user32.dll user32.dlx
    ren gdi32.dll gdi32.dlx
    ren winmm.dll winmm.dlx
    <ramdrive>\ext.exe
    where <windows> is the name of your Windows folder and <ramdrive> is the virtual drive created by the boot disk (probably e:\ or f:\).
  4. Type the following line, and then press ENTER: For Windows 98:
    <CD-ROM drive>:\win98
    For Windows Me:
    <CD-ROM drive>:\win9xwhere <CD-ROM drive> is the drive letter assigned to your CD-ROM drive. Note that this letter may be different when you boot your computer with the Windows Startup disk.
  5. Type the following line, and then press ENTER:
    user32.dll gdi32.dll winmm.dll
  6. Type the following line, and then press ENTER:
    <drive>:\<windows>\system
    where <drive> is the drive on which Windows is installed, and <windows> is the folder containing Windows.
  7. Review the information displayed. If it is correct, press Y.
  8. Type the following commands, pressing ENTER after each command: cd
    ren Cmapieng.vxd Cmapieng.vxx
  9. Restart your computer.
  10. Once Windows has restarted, run the Defragmentation application.
When Ext.exe has finished extracting the files, follow these steps:
  1. Remove the Windows 98/Me Startup disk, and then restart your computer.
  2. Press and hold down the CTRL key as your computer restarts. On the Windows 98 Startup menu, select Safe Mode.
  3. After Windows starts, on the toolbar click Start, point to Settings, click Control Panel, and then double-click Add/Remove Programs.
  4. On the Install/Uninstall tab, click any utility that you have installed, and then click Add/Remove to remove the utility. Repeat this step to remove any utilities you have installed.
  5. On the toolbar click Start, point to Settings, and then click Taskbar And Start menu.
  6. Click the Start Menu Programs tab, and then click Remove.
  7. Double-click Startup, click the appropriate entry, and then click Remove.
  8. Click Close, click OK, and then restart your computer.
  10. In Microsoft System Information, on the Tools menu, click System File.
  11. Click Settings, on the Advanced tab, click Restore Defaults, and then click OK.
  12. Restart your computer.
Sep 20, 2009 | Microsoft Windows 98 for PC
No Audio devices installed in my pc
Click on Start >> Run, type services.msc and press Enter.
In the services window, double click on the Windows Audio Service and make sure that the startup type is automatic. Click on Start/Restart button and then check.
Apr 08, 2009 | Intel Computers & Internet
HOW TO INSTALL WINDOWS 98
How to Install Windows 98 loadTOCNode(2, 'moreinformation');
  1. Insert the Windows 98 Startup disk in the floppy disk drive, and then restart your computer.
  2. When the Windows 98 Startup menu is displayed, choose the Start computer with CD-ROM support option, and then press ENTER.
  3. If CD-ROM support is provided by the generic drivers on the Startup disk, you receive one of the following messages, where X is the drive letter that is assigned to your CD-ROM drive: Drive X: = Driver MSCD001
    Drive X: = Driver OEMCD001 NOTE: If your CD-ROM drive is not available after you boot from the Windows 98 Startup disk, install the CD-ROM drivers that are included with your CD-ROM drive. For information about how to obtain and install the most current driver for your CD-ROM drive, view the documentation that is included with your device, or contact your hardware manufacturer.
  4. Insert the Windows 98 CD-ROM in the CD-ROM drive, type the following command at a command prompt, and then press ENTER X:\setup where X is the drive letter that is assigned to your CD-ROM drive.
  5. When you receive the following message, press ENTER, and then follow the instructions on the screen to complete the Setup procedure: Please wait while the Setup initializes. Setup is now going to perform a routine check on your system. To continue press Enter.
Jan 21, 2009 | Microsoft Windows 98 for PC
NOT booting WINDOW XP
Hey stanley154
try to boot your machine using window 98 startup disk or window 98 bootable CD. then type fdisk on DOS prompt. Then try to delete non dos partation and the create primary dos partation. Restart your machine, let it start window or the floppy until it return to dos prompt. Then you can type the format c: e.g a:\format c: or D:\format c:. After that try to run window xp.
all the best
zinja
Sep 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
How do I re-format a 2x serial SATA drive to reinstall XP?
How to Format a Hard Disk
After you create the partitions, you must format the partitions:
Restart your computer with the Startup disk in the floppy disk drive.
NOTE: If you are using a Windows 95 Startup disk, a command prompt is displayed and you can skip to step 2. If you are using a Windows 98, Windows 98 Second Edition, or Windows Me Startup disk, select the Start computer without CD-ROM support menu option when the Windows 98 Startup menu is displayed.
2. When a command prompt is displayed, type format c: /s and then press ENTER. This command transfers the system files and should only be used when you format drive C (or your "active" drive). For all other partitions, type format drive: (where drive is the letter of the partition that you want to format).
NOTE: If you receive a "Bad command" or "Bad file name" error message, you may need to extract the Format.com tool to your boot disk. To do this, type the following command at a command prompt, and then press ENTER:
Extract ebd.cab format.com
After the Format.com tool is extracted to your boot disk, type format c: /s t a command prompt to format your active partition, or type format drive: if you want to format a partition that is not your active partition.
3. When you successfully run the Format.com tool, you receive the following message:
WARNING, ALL DATA ON NON-REMOVABLE DISK DRIVE C: WILL BE LOST!
Proceed with Format?
4. Press Y, and then press ENTER to format drive C.
5. After the format procedure is finished, you receive the following message:
Volume label (11 characters, ENTER for none)?
NOTE: This is an optional feature that you can use to type a name for the drive. You can either type an 11-character name for the drive, or you can leave it blank by pressing ENTER.
Jul 25, 2008 | Computers & Internet
Compaq Presario 5102US downloading Windows 98
If U already have 98 on the pc, R U trying to have dual boot, recover, or reload 98 instead of 98ME?
The disk U R using is a recovery disk and U will still need the 98 cd to reload. The disk is for repairing or reloading the 98 system and I would suggest that U learn how to use the command structure first before attempting a system repair.
Please explain what the problem is and what U want the system to do. We R very happy to help U get to where U want to go.
Jun 08, 2008 | Compaq Presario 5000 PC Desktop
Laptop won't startup HELLP!!!!!!!
what is the configuration of your laptop - i can't tell you the solution without knowing that
Jan 07, 2008 | Microsoft Windows 98 for PC
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
