Question about GPS
My sky caddie sg5 wont charge - GPS
  • 10,319 Answers
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Posted on Jul 16, 2011
SOURCE:
Sky caddy breeze will not charge
I cannot charge my sky caddie breeze even though I am using the same lead and USB port that I have always used. Do you know why this might be?
Jan 02, 2014 | SkyCaddie BREEZE GPS
My sky caddie sg5 won't charge thru the usb or power cord...any ideas???
Hello there,
Since you have tried charging the device using the usb and the power cord. It is quite clear to know that the problem is from the device connection port. It is bad and need to be replaced.
But you need to Try to test the battery in other devices then try to charge it there to see if it will hold a charge. If the battery holds a charge there, then it means the battery is okay and if it does not charge. Then it means the problem is from the battery. It need to be replaced if so.
Then test the charger/ power cord on another device if it is not bad, then you test the usb cable also. After running these test. You will be clear to know if it is the connection port. Then replace the connection port once confirmed to be the problem. Hope this helped. Goodluck Elect_Comp
Sep 02, 2011 | SkyGolf SkyCaddie SG5 Car GPS Receiver
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
Do i need to do anything special when I store the sky caddie SG5 until next Feb. In particular I'm curious about the battery. Don't want to do something to shorten it life. Thanks. Lou.
Just make sure that you're keeping it indoors in a climate controlled environment if possible. Charge it completely and then store it and you should be fine.
Nov 16, 2010 | SkyGolf GPS
Sky Caddie SG5 will NOT turn on
Hi David
I know this is some time after you posted your question. I had the same problem with mine and was ready to throw it in the bin.
Searced the net and someone had posted that they bumped into a Skygolf rep who suggested lifting the charging flap and blowing into the hole.
I thought he's having a laugh, but guess what it worked.
Good luck if you've not already fixed it.
Mark
May 03, 2010 | SkyCaddie SG 3.5 Handheld GPS Receiver
How do I download skycaddie program back on to the computer. I already have a subscription for the year
THIS HELP YOU
http://wareseeker.com/free-sky-caddie/
www.skygolf.com/ -
Sky caddie Free Download,Sky caddie Software Collection Download. ... English and Dutch versions avilable.sky caddie. foxfire mail, Download now ...
www.brothersoft.com/downloads/sky-caddie.html -
Mar 01, 2010 | SkyGolf SkyCaddie SG5 Car GPS Receiver
Lost power mid download
I think there is a way to reset the unit by holding down one or more buttons while turning it on. This varies from brand to brand, read your manual.
Feb 09, 2010 | SkyGolf SkyCaddie SG5 Car GPS Receiver
Cant get past personal info page to activate sky caddie sg5 golf range finder!get to entering username or password.then after a while it says skycaddie sync not responding
Well first of all you can try to reset your caddie, just remove the battery for 5 hours and insert them again, check again after resetting it......, to reset your caddie there is also a "reset to factory default" option go to main menu then settings then select restore option......
post comments if further you have the same problem....
Good Luck!!
Thanks
Dec 14, 2009 | Sport & Outdoor - Others
GPS Logo
962 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
