Question about Samsung HLN617W 61" Rear Projection HDTV
HDMI Does anyone know if you can adapt the DVI to HDMI with this particular model DLP? I bought a Blueray DVD and It won't accept a Monster DVI/HDMI adapter. Any input would be aprecciated.
  • stealthawd Sep 01, 2008
    First night home, crawl into bed to watch a movie on the new bedroom TV...can't see anything BluRay. Sent the kids back down stairs to pick another movie to watch on DVD.
I have the same TV and my HDMI to DVI worked fine, it took some doing in the ps3 setup, but it worked, send me more on what happened, and I will try and help you
wbwill@sbcglobal.net
Posted on Sep 16, 2008
DVI to HDMI
HDMI and DVI use the same encoding scheme for video purposes- the only difference is HDMI can carry audio signals and therefore have different connectors- so it is not like the lack of a picture signal is because you are using two different cables (HDMI and DVI). In theory the DVI to HDMI adapter should work.
Is there a possibility that the adapter is defective? Any bent or missing pins?
How long are the cables? If they are of poor quality, a digital signal can be lost at 20 feet. Again, in theory.
The only other thing I can thing of, off the top of my head is to ask, did you change the input selection on your t.v.'s display screen to go from the input source that you get your t.v stations from... to the input source of the Play Station?
Nov 27, 2013 | Toshiba 50HDX82 50" Rear Projection...
I have a Denon AVR 587 and a Phillips DVD Player. I am trying to figure out how to hook the DVD player up to the receiver without using an HDMI Cable. Also I have a laptop with a DVI connector on it that i...
Get the manuals. All is explained there.
http://www.retrevo.com/support/Denon-AVR-587-Receivers-manual/id/696ci075/t/2/
Component video is just as good as HDMI.
The unnamed Philips DVD player has a manual somewhere. Try retrevo or drill down into this directory to find it...
http://www.p4c.philips.com/files/
Be patient. The alpha directories are slow to load.
DVI connectors can be adapted to HDMI or component video.
"Web search "dvi to component adapter" "dvi to hdmi adapter"
Your PC's video and display controls will determine how all that works.
Aug 04, 2011 | Audio Players & Recorders
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Dec 16, 2010 | Toshiba 30HF84 30" TV
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
I can not connect my pc to my samsung dlp
Not all TVs have video inputs to directly connect the computer output. Some computers have video cards that have separate outputs(usually S-Video) which you can use. Or you can purchase a video card that has the proper outputs.
If your computer has a DVI output, and your TV has an HDMI imput, there are cheap adapters that you can buy, as HDMI can process the DVI signal directly, just the cable is different.
If you need more assistance, we would need to know the models/outputs/inputs of both the computer and the TV.
Best Regards
Nov 11, 2008 | Samsung Televison & Video
Samsung hlr4667 dlp \ no hdmi connectivity
No, when I bought my new plazma tv, and unhooked my old DVR box, I had to go to my cable provider and inform them. they sent a signal and WHAM I was back in Biz.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
HDMI->DVI cable won't work
Are you using a HDMI to DVI cable or are you using a HDMI to DVI adapter? Sometimes, though not on all products you have to go into the menu and select which out put your using for each source and whats going through it. You might need to go into your dvd player menu and tell it not to try to run audio through the cable. That way it's not trying to force a signal through the cable that cant be accepted by the TV. That might possible solve your problem for the DVD player. Let me know if it works
Have a Great day
Aug 11, 2008 | Televison & Video
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Samsung HLN617W 61" Rear Projection HDTV Logo
151 people viewed this question
Henry  Thomas
Henry Thomas
