Question about HP iPAQ HX4700 Pocket PC
Hx4700 - screensaver
Hello! How can I disable screensaver appearing with JPGs from My Pictures folder when on AC power?
    Master:
  • 450 Answers
Go to Start > PROGRAMS > Dockware. Now click on the top left hand corner of screen. Click on 'Setup' to uncheck the box to Automatically start Dockware.
Posted on Sep 07, 2005
Tip
My Pictures Slideshow screensaver
Make use of the Windows XP's My Pictures Slideshow screensaver for this purpose. Follow the steps:
Using Paint brush (mspaint.exe), create 10 or more images with a Black background in each. Open each image file and embed your company logo in it, in (place it in random areas, one in each image).
Create a folder for the image files you've created, and place the images in that folder. Assign this folder read-only permissions for all the users.
Now, configure the screensaver under your user profile. In the My Pictures Screensaver properties, do the following:
Set the folder where you've stored the image files
Set the interval using How often should the pictures change slider.
Uncheck all the checkboxes at the bottom of the dialog
Click OK and save the changes
Set the Screensaver Timeout to a preferred value in minutes
Test the Screensaver in your profile to see everything is fine
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
My xp does not work well. the screensaver does not appear. It can not repair itself.
Hello, there can be multiple causes and solutions to this type of problem you have but my guess is that there is a service not running properly for the screensaver as in THIS Microsoft article.
To view services to see if the Human Interface driver is working go to start->Run->type in the box "services.msc" without the double quotes, and then find the service mentioned in the microsoft article.
OR you can use the registry editor to modify your screensaver settings (PLEASE ASK FOR FURTHER HELP OR CLARIFICATION WITH THIS / USE WITH CAUTION IF YOU DONT KNOW EXACTLY WHAT YOU ARE DOING).
SImple example: Go to start->Run-> type in "regedit" and then go to the following registry entry/folder: HKEY_CURRENT_USER\Control Panel\Desktop\ there you can find the screensaver key named:ScreenSaveActive, if set to 0 set it to 1 and vice versa to enable/disable screensaver modify settings. More info HERE
Mar 20, 2011 | Microsoft Windows XP Home Edition
HP iPAQ hx4700 need default password
If you can't remember your passcode, you may have to do a hard reset(factory settings) if you have a sync folder on your computer, there is your backup. To do a hard reset: 1. Remove your iPAQ from the cradle, making sure that it's running on the internal battery power. 2. Use the stylus to press down the recessed reset button on the back or side of the iPAQ. 3. While the reset button is held down, press the On/Off button. 4. Release the reset button. When you press the On/Off button again, your iPAQ turns on and all your files are gone. To avoid repeating this major disaster in the future, you should back up your iPAQ files on your desktop PC. Activesync will generate another folder,and you will have to rename your pocket pc. But once your past that point, open both folders and drad and drop into the new folder. Hope this helps.
Jan 25, 2010 | HP iPAQ HX4700 Pocket PC
How do I ge my pictures from kodak easy share to my screen sver
Just save your pictures to "My Pictures" folder (windows xp) or "Pictures" folder (windows vista).
Then, right click on your desktop and go to Properties (win xp) or Personalize (win vista), then on Screen Saver, select "My picture slideshow" and you will have your pictures as your screensaver.
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Easyshare converted all of my jpgs to easyshare files
i'm not sure how to change the default picture program... but i can tell you that you won't lose pictures if the easyshare program is deleted. it's just an extra program to view/edit pics.... the actual pics are located in a generic folder somewhere on your computer. click properties on one of the pics in easyshare, and see where it's located. then just go to that folder through windows....
hope i helped a little, sorry i don't have the solution for the other part
Nov 12, 2008 | Kodak EasyShare One Digital Camera
Can't Download pictures
Run all jpgs through the Sansa media converter IF your user's manual indicates that this player can play picture files.
Sep 02, 2008 | SanDisk Sansa e250 MP3 Player
TomTom GO 910 - screensaver?
try this it does take a while to do.
STEP 1
Connect your TomTom to your computer1.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup1.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Dec 27, 2007 | Tomtom GO 910 GPS Receiver
AC charging issue
Sounds like a defective AC adapter.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
HX4700 backup
Doosoft's mobsync is brilliant. I have used it for a year now to back up my SD card. It starts automatically when doccked. Also allows me to specify folders to back up on different schedules. http://doosoft.seesaa.net/
HP iPAQ HX4700 Pocket PC Logo
173 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
