Question about Kinderkraft Vermont Crib
Where would i buy an allen wrench??
I need an allen wrench for my crib allen wrench part number is 1040 anyone know where i could get one?? meijers?? lowes?? menards??
    Scholar:
  • 62 Answers
Any hardware store. Allen wrenches are usually sold as sets, this way you'll have many different sizes, and one of them will surely be the one you need (just have to know whether metric or standard, or buy both sets).
Posted on Aug 27, 2008
My Dad Has 2008 E350 4matic trying to replace front brakes. Don't have a long Allen wrench to remove caliper. Anyone know what size so I can buy and remove? Thanks Curtis
Probably is a T-50 bit that fits on your rachet...you can buy a set of star key bits...these are not allen wrenches...Hope this helps.
Nov 12, 2015 | Cars & Trucks
ALLEN WRENCH SIZE. I LOST IT HELP
They are most likely 6mm metric. Get one of these: http://www.harborfreight.com/hand-tools/hex-wrenches.html You want the one that has the set that folds out.
Aug 25, 2015 | Graco Baby Gear
I lost my manual, I need to know how to transform the crib into a toddler bed
Converting a Simplicity Crib into a Toddler Bed:
Please note, Simplicity has gone out of business and the Simplicity Cribs should NOT be used as cribs. They were sold at Walmart, Target and BabiesRUs. The word on the street is that Walmart is the easiest to deal with when it comes to returning them. Those who wish to return Simplicity cribs don't need a receipt, they can just take them to Walmart for store credit. BabiesRUs was apparently giving about $65 while Walmart was closer to $190. Again, this is just what I have heard from others.
You can find the specific information on the Simplicity recall here.
If you do want to use your Simplicity crib as a Toddler Bed, I have not read any warnings against this. Again, I might just take it to Walmart anyway and get a store credit and perhaps buy a new convertible crib. You can get some great ones on Amazon for around $150 with delivery included.
I would pack it up, take it in for store credit, and get a new crib!
You can get some great deals these days on cribs, there's a great one on Amazon for $150 with free shipping so it's kind of a no-brainer.
As I have heard, Walmart will take it back, no questions asked and no receipt necessary and you can get a brand new one with brand new parts, brand new instructions and no recalls or risks!
Good Luck.
Here's one of my favorites:
mkd123_2.jpgGraco Sarah Classic 4-in-1 convertible bed
If you still want to convert it, here is what you need to do:
1. Remove the front panel of the Simplicity crib. Use an Allen wrench and 45mm bolts (there should be extras underneath the crib, along with an Allen wrench, but if there aren't then you can pick some up at your local hardware store.)
2. Check the mattress support. It needs to be in the lowest position available, which will allow the toddler to get in and out of bed easily. It is also the only position that will make the rails line up properly with the pre-drilled bolt holes. To lower the mattress, unscrew the four bolts from the four corners of the mattress support and slide the support down. The holes for the lowest setting are just about the bottom wood panels. Use your Allen wrench to reattach the mattress support with the same bolts you pulled out when the mattress was in the higher position.
3. Attach the toddler bed rails to the crib frame. Use two 38mm Allen bolts on each rail. There are pre-drilled holes in both the rail and the crib frame. Line up the holes and then loosely screw the bolts into place. The bottom of each rail has a metal L-shaped hook. This will slide under the mattress support. Use a 19mm Allen bolt to attach this piece to the mattress support. When everything is lined up and screwed in loosely, go back and tighten each bolt. Repeat on the other side.
4. Check the entire crib frame for loose bolts. Use the Allen wrench to tighten all the screws. Toddlers can be rough on their beds, so it is important to make sure the bed is safe. You should recheck for loose bolts often. Jumping and climbing on the bed can easily loosen the bolts and screws.
5. Don't forget to hang onto the front panel and store it carefully, you will need it later to convert the bed into a full sized bed.
Jan 23, 2011 | Simplicity for Children 4-in-1 Convertible...
Convet morigeau lepine crib to a toddler bed
Use the allen wrench that came with the crib to slightly loosen the two bolts on the moveable gate side (bottom) then shimmy the sliding gate out of the tracks. I did it myself with verbal directions from the store - should be easy.
Jan 02, 2010 | Pali Katie Crib
I lost my instrction manual!
Step 1: Detach the front panel from the 2 front post using an allen wrench
Step 2: If the mattress support is not in the lowest position unscrew the bolts and move it to the lowest position
Step 3: Using the allen wrench, attach the guard rail using 4 bolts between the lest and right front post (the guard rail would be that extra piece that you couldn't do anything with while the bed was converted to a crib. Looks kinda like a wooden board)
Step 4: Tighten all screws and put the crib mattress back in
Apr 30, 2009 | Baby Gear
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
I NEED SCREWS!!
Ace hardware carries these metric screws. I lost one screw & this was the closest thing I found.. The allen key part is not the same but the thread & the length are perfect- they are about 0.75 each. : )
Feb 04, 2009 | Simplicity for Children 4 in 1 Ellis Honey...
Missing Babycraft Crib Screws
a few trips to the hardware store will solve this, take a few screws from around the house and find one that will thread into the barrel or whatever is in the frame, measure the lenght and off to the hardware store. home depot has a large selection of specialty screws.
Dec 31, 2008 | Delta Enterprise Versailles 4970 Crib
Jardine Crib 4 in 1
step 1: detach the front panel (part j) from the front posts h(1) and h(2) using allen wrench
Step 2 if mattress support (part K) is not in the lowest position, unscrew mattress support bolts (Part d) from the post and move it to the lowest position
Step 3: Using the wrench provided, attach the guard rail (part f) using 4 bolts (part a) between the left and right front posts
Step 4: tighten all screws clockwise.
good luck
Sep 23, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Kinderkraft Vermont Crib Logo
Top Kinderkraft Baby Gear Experts
Joyce Nokleby
Craig Butler
Craig Butler
wcdoc1953
wcdoc1953
Are you a Kinderkraft Baby Gear Expert? Answer questions, earn points and help others
