Question about Samsung SGH-D500 Cellular Phone
Display problem my display is inverted... i mean like... it is flip horizontally...
  • cutenet Aug 30, 2008
    my display is not opened because its open to white screen only.
    Brigadier General:
  • 7,752 Answers
Engrjo - replace the lcd
cutenet - you will need to have the flexcable replaced
Posted on Aug 31, 2008
How do I flip the picture after mounting on the wall?
first Put the projector On a place where you can read the menu.
then go to the menu and select and select projection type. there you will see option . Vertical invert and horizontal invert. Select vertical invert and change it in some projector it will be denoted as ceiling . after changing the desired setting place the projector where you want it to be.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 07, 2016 | Televison & Video
My window has been inverted, how can i make it correct?
i don't know what operating system you are using so this will be a general answer. go to control panel, click on "display", click on "change display settings", open the orientation tab and click on "landscape" and click apply. other options would be portrait, portrait flipped, and landscape flipped. luck.
Apr 18, 2014 | Acer Aspire 5315 Notebook
My webcam is inverted, how do I fix it?
If the image on yur webcam is inverted, this is what you do.
Turn on you webcam.
From the settings, you would see the option to flip horizontally and vertically.
Flip it vertically, nad that should fix the problem.
Hope that helped?
Have a great day.
May 31, 2011 | ASUS K40IN Notebook
The image is inverted
This may sound ridiculous but check and see if the camera is in the holder upside down :) It is possible, but very unlikely, that the software is inverting the image... but it is much more likely that the camera itself is upside down.
May 28, 2011 | ASUSTeK Computer Inc. USB2.0 UVC 0.3M...
I want to reversa an image for later transfer to a t shirt. Can I do this?
If you would like to reverse an image--by reverse, I assume you mean flip horizontally--then you will need an image editor.
GIMP 2.0 is a powerful editor that you can get much more use from with t-shirt making. Download GIMP, select your image, right click and select flip horizontally.
Additionally, some operating systems will allow you to right click the image and select "flip horizontally" or "reverse".
May 13, 2011 | HP PSC 1610 All-in-One Printer, Scanner,...
I have amonitor 32 inch when i turn it on i see meany horizontal lines this lines colored how can i solve this proplem pls?
Hello When you get horizontal line, especially colored, it typically means there is a problem internally: either with the LCD inverter (backlight), LCD Circuit board (interprets incoming signal) or the Display panel itself. Sometimes shaking it around can clear up the issue slightly but for the most part it's time to get a new screen. If you have pictures I can verify this is the issue. Any other questions, feel free to ask.
May 13, 2011 | Polaroid Computers & Internet
My Pres C300 laptop works fine with an attached monitor. But its own LCD screen is currently having 3 equal horizontal sections. First (top) section is normal, second flickers and is normal when pressed,...
Since the laptop works fine with an attached monitor, it means the problem is the inverter.
The problem with your laptop screen is that the inverter is malfunctioning, that is why you have those three equal horizontal sections.
Change the inverter of your laptop screen and you will see that the screen will be stable back.
Take care.
Apr 27, 2010 | HP 435768-001 - Compaq Presario C300...
When on the camera the image in display is invert
This is a common problem with the flip out display feature. Either the little image inverter switch is bad on the flip out screen unit or the flex cable unit going to the display is bad. Sometimes that switch can be cleaned ,but if it's the cable it will need replacement. This problem is a display issue however ,so if you can rotate the display in another postion to where you can use the camera you can still use it. It will not effect the recording made. I fix these all the time . Repairs run from $40 to approx $165. Larry's Electronics 916-362-8708 ledstiles@hotmail.com
Apr 23, 2010 | Sony Handycam DCR-SR40 Camcorder
Inverted webcam
check the webcam setting ia aim
and fill the otion of:
vertical flip
horizontal flip
till get it righ.
plz rate this post.
Feb 06, 2009 | Dell XPS 410 PC Desktop
Samsung SGH-D500 Cellular Phone Logo
Top Samsung Cell Phones Experts
Fotis Papastamatiou
Bill Long
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
