Question about Canon i9900 InkJet Photo Printer
Incorrect Color We have an i9900 Ink Jet Printer which is printing everything in blue & pink tones. You may respond to me at cathy@birchwoodchurch.com
  • 3 more comments
  • William Rumage Sep 02, 2008
    i9900 printing everything with a green tint. I've clean the heads and ran the alignment program several times for each with no luck.
  • GAIII Oct 18, 2008
    I've got the same problem, that started 2 months ago. I notice that if I print on regular paper, it's pretty normal, but on high gloss, it's all tinted green. HELP!
  • Anonymous Oct 21, 2008
    I get green tones mostly in place where red should be.
  • Anonymous May 23, 2009
    I haven't used my printer in a while i.e., 1 year - all the ink tanks are full and i've done deep clean / head's alignment - the full maintenance works... my pictures are purple ... should I replace all ink tanks?
  • wotz101 May 26, 2009
    same error normal printing FINE
    HI resolution or photo printing there seems to be no photo magenta or magenta printing
    I run the cleaning setup and I have even done a thorough head clean with window cleaner (recommended ) and still no luck was intermittent but now getting worse
    is it time for a new print head ..or another solution
    cheers
    John
Mine is printing with no reds... Find a solution please let me know.
Posted on Aug 29, 2008
I have the same problem as cathy. if anyone have any solution, please like me know...thanks syang75@yahoo.com
Posted on Oct 21, 2008
Why is this EPSON STYLUS C88+ "Dura Brite Ultra" printer printing the wrong colors?
You have a corrupt or incorrect printer driver. Completely remove all references to the current driver from the computer. Un installing is not enough as the registry references remain. Then install the driver(s) again.
Jul 22, 2014 | Epson Stylus C88 InkJet Photo Printer
My HP CP1700 prints out gray tones in pink.
Your head / nozzles must be dirty , perform a nozzlecheck /head clean from printer software maintainance utility,
regards
Mar 28, 2008 | HP cp1700 Color Inkjet Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Blue and red dots
See if there is something wrong with the pad under the ink carton. There is a little sponge thing that absorbs the ink and transfers it to the paper. The ink could also be the issue. If none of these works, you can just return it for a new one if you still have the receipt
Mar 20, 2010 | Computers & Internet
Can't print BLUE.
I use a clear silicone tube to carefully prime the carts by sucking a dab of ink out of the tiny print holes before installation. I am careful to have a tight seal at the holes to prevent getting too much ink and possibly getting it in my mouth. Make sure each color appears.
Jun 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
Printer S400 won't print out blue and pink ink
Hi..
The nozzles have gone bad...it needs to be serviced or replaced...i appreciate your efforts yoy put in to fix the problem thats best we can do after all its a machine.if the printer is in warranty contact the manufacturer.
Regards,
debroy
Nov 25, 2008 | Canon S400 InkJet Printer
Pink teal lime
the printer cartridges have the ink Blue (light blue), red (pink) and yellow (lime).I think your printer printing fine do not worry all the printer have same ink........If you have the problem with color on print outs :you this link ::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS25128&relevance=1
Mar 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Line Printing to hp office jet9110
I have this same problem, I have pink lines going through everything that I try to print in color. When I print in black and white, everything works fine. The blue and yellow ink cartridges aren't empty, so I'm not sure what the problem is. Any suggestions?
Feb 16, 2008 | HP Officejet 9110 All-In-One InkJet...
HP Laser Jet 1600
It should not, when you say pink you mean Magenta right?
sounds like it needs some cleaning, pull out everything you can pull out from the printer, and carefully clean any tone you see inside with a dry cloth, also clean the cartridges themselves.
print a few pages for any remaining toner to get phased/cleaned out on the print outs and see what happens
thanks for rating
Jan 10, 2008 | HP Color LaserJet 2600n Printer
DeskJet 950C Pink Printing problem
Assuming that you have the correct print drivers and the color is set correctly on your software. Then the issue is often caused by the ink drying and clogging the injectors. Open the lid and remove the ink cartridges, then unplug the printer. Then get a swab or Q tip and using bottled water (do not use tap water). Moisten the swab and wipe the areas on the printer where the ink cartridge contacts the printer. You should see ink on the swab. After you let it completely dry then place the cartridge back in and turn the printer back on. Try to print again. If it is still not printing with the correct colors then you could have a problem with the injector circuitry. At that point it is cheaper to buy a new printer. You can get refurbished ink jet Dell printers at Dell.com under outlet for usually $30-$40 and a one year warranty.
Jan 04, 2008 | HP DeskJet 950c InkJet Printer
Canon i9900 InkJet Photo Printer Logo
260 people viewed this question
old marine
old marine
