Question about HP iPAQ HX4700 Pocket PC
Hx4700 moving files
Hi Very simply I'm new to ipaq and want to move some movies from my new ipaq to a cf card I just bought, but can only see copy and paste a file not move file ???? Can you help Thanx
    Master:
  • 450 Answers
To move from main memory to CF card, you would do a Copy and Paste and then delete the file from origianl location with the 'Cut'.
Posted on Sep 07, 2005
I just bought one 4BG SD card for my Hp Ipaq HX4700, but its dosen't show up. Please give me the suggetions, how can i use it ? Thanks in adnavce.
Use a CF-SD/SDHC adapter and use the CF slot. AMAZON sells it for under $12.00. I am using a 16GB SDHC right now.3_7_2012_7_17_35_pm.jpg
Aug 25, 2011 | HP iPAQ HX4700 Pocket PC
How to update Amap EKP IV. I downloaded a zipped file to the computer. In the zipped file are two files that match files on the compac card. If I move the zipped file to the compact card will the GPS do...
In order to update your EKP you need a CF reader, you cannot update your CF without it.
First of all download and unzip the update files from our support section.
Enable the show of hidden files. Create on your Desktop the folder 'Old CF'
and copy in it all the files from the CF (is the backup folder if something goes wrong).
Omit to copy the 'CHARTS' folder. Create on your Desktop the folder 'New CF'
and copy in it the same files you copied in 'Old CF'. Replace the files format swx
in 'New CF' with the ones you downloaded from internet. Ovewrite the files in the cF
with the ones in 'New CF' (do not touch the CHART folder). Turn on the EKP and verify
if the procedure was correctly executed. If not, reinstall in the CF the files from
'Old CF' and repeat the procedure.
NOTE! : this procedure can delete all user marks from the RAM. Save them first in the CF
with File Manager.
NOTE! For the update of 21/oct/10 you will need to update the Jeppesen cycle to !
Feb 06, 2011 | HandHeld Entertainment AvMap EKP-IV...
Replacing PDA Screen - HP iPAQ hx4700
http://www.repairhppda.com/video/How-to-Repair-for-HP-iPAQ-HX4700-HX4705-series.html
Jan 19, 2009 | HP iPAQ HX4700 Pocket PC
Just bought 4GB SD card that hx4700 does not recognise - help pse
Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
http://en.wikipedia.org/wiki/Secure_Digital_card
Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
SD Card issue
Its design not a problem, it will do the samething with a CF card. They probably figured that you would only insert a card into the device if you intended to use it.
Sep 14, 2005 | HP iPAQ HX4700 Pocket PC
Hx4700
You need to sync the old one with your PC, then simply set up a new partnership with your new Ipaq and sync it with that same PC.
HX4700 backup
Doosoft's mobsync is brilliant. I have used it for a year now to back up my SD card. It starts automatically when doccked. Also allows me to specify folders to back up on different schedules. http://doosoft.seesaa.net/
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Data erased from iPAQ hx4700
If an ipaq loses power , then all data in RAM is lost. It's important to keep it charged. It's also important to do regular backups..... so there are two backup options - one is thru Activesync which will backup to your PC and one is the IPAQ's own backup program which will backup to the IPAQ FILE STORE (area in ROM) or a SD card. I do the Activesync backup every time I sync and then the IPAQ backup about once a week or immediately before a system change. Activesync backup ------------------------ Here is a guide which best explains it http://www.cewindows.net/faqs/activesync/backup.htm this guide suggests doing a full backup, but it's fine to do an incremental backup each sync - this means that only changes will be added to your backup and makes the whole process much quicker. IPAQ Backup ----------------- So under Programs is a program called IPAQ Backup. The default location is IPAQ FILE STORE which is an area in ROM and is not lost thru a power failure nor hard reset. You may also choos to backup to a SD card - a full backup will need roughly 20MB. So in this backup procedure, if you click on 'Browse' you can choose a SD card. A restore can then be performed from the IPAQ FILE STORE or SD card (depending on which location you chose) and so if you are away from your PC, this will be no problem. A restore this way , rather than thru Activesync is also much quicker, so if you have a choice go this route.
Storage Memory
memory card isn't really memory it's more like a disk drive. it's not like when you add memory to a PC and the new memory is automatically used. To make use of this card you need to transfer some of your larger files to the card.... You can move files from within the ipaq... Click and hold on file. Select Copy Click and hold Select Cut Navigate with File Explorer to the SD card.... Open File Explorer Select My device Now select SD Card You can create a new folder or select an existing folder Click on Edit at bottom of screeen. Select Paste. You can also move files directly from PC to Storage card...... While IPAQ is connected, go to My Computer, then double-click on Mobile Device, then double-click on Pocket PC. Now you will see your Storage Card, and you can use this just like a folder on your PC. You can create folders within it. You can click and drag files to it or to any of it's folders.
Sep 07, 2005 | HP iPAQ H4150 Pocket PC
HP iPAQ HX4700 Pocket PC Logo
57 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
