Question about Dishwashers
The dishwasher tablet won't dissolve
The dispenser is open, the spray arms are rotating and are clean (have checked them for blockages). I also checked the filter, it was clean.
I did dry the detergent compartment before putting the tablet (as suggested in one of the websites). I have tried 3 different makes of tablets with different washing cycles, but in the end of each one the tblets were still there undissolved. Another suggestion, on different website was to put the tablet in the cutlery tray. I went for the dishwasher cleaner instead (the stuff that usually comes in a bottle). After the cycle the bottle was full.
  • 3 more comments
  • Anonymous Dec 06, 2008
    ditto zdf511
  • Anonymous Dec 07, 2008
    have tried putting the tablet in cutlery draw at top of dishwasher and in the compartment in the door.
  • Anonymous Dec 11, 2008
    Same problem here...wasting my tablets and I can't find any help online! Someone have ANY advice? I'll try the tablet in the cutlery tray tip...
  • mackintosh1 May 21, 2009
    Same problem, tried different brands of tablet, different times of running the dishwasher, different loading techniques, checked the salt level and all sorts. It won't dissolve for love nor money - the latter being exactly what I'm wasting! Help!
  • Ian Greenland May 11, 2010
    it sounds like either the motor isnt coming on or maybe its not heating.What brand and model is it?
5 Suggested Answers
  • 704 Answers
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Posted on Jul 31, 2009
  • 351 Answers
SOURCE: Bosch Exxcel Dishwasher
no not if it getting hot it still sounds like the motor isnt coming on put the spray arms in the same position turn it on then open the door are the arms still in the same position or haved the moved.those cleaners need hot moving water to melt the seal.
Posted on Sep 03, 2008
Testimonial: "Sorry about late reply. Thank you for your help."
  • 8619 Answers
SOURCE: Neff S5433 Dishwasher - Detergent tablet not dissolving
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Posted on Feb 22, 2009
  • 174 Answers
Take off lower spray arm there is a spay hole underneath if its blocked the tablet gets left in the bottom. also check the filter is not split as rercycled food deposits is the cause of the blockage. short programme is not suitable for tablets,
Posted on Jul 13, 2010
Why is water not heating in cycle?
Hello Kevin, thank you for your post!
From my understanding your Electrolux dishwasher is not fully dissolving the detergent tablet. It may not be an issue with the water heating up it could be a possible problem with the water not receiving adequate pressure or not enough water. Does your dispenser have any build up inside of it? Have your spray arms been recently cleaned? I would recommend cleaning the dispenser and spray arms out. I can also provide you with information regarding any heater inside of your dishwasher. In order to do so I need your model number. You can locate your model number on the inside wall of your dishwasher. With this information I would be happy to assist you further. -Matt
Feb 02, 2016 | Electrolux Dishwashers
When our Neff dishwasher has completed a cycle most of the tablet is still in the open dispenser. Can you advise ?
Check and clean both spray arms.
make sure nothing is restricting the movements of the arms. Have you selected the correct programme? Quick wash may not always dissolve tablets, you may need to put the tablet straight into cutlery basket at start of quick wash programme
Sep 23, 2014 | Neff Dishwashers
The soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
1. Water temp is wrong should be 140-145
2. spray arms clogged with food
3. water valve is not letter the correct amount of water in
after it fill's check to see water amount in bottom , dose it sound like it is starving for water ? it would sound like it was surging
Dec 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Tablet keeps coming out of the dispenser on my hotpoint fdl 570 dishwasher on all cycles and falls on to the floor, result is that the crockery isn't always clean on the top tray. Machine is still...
Hi Jeanette,
Maybe I misunderstood your question, but the tablet is supposed to come out of the dispenser and fall into the bottom of the dishwasher. It needs to fall into the hot water in the bottom of the washer to dissolve. The dispenser releases the tablet at different points in the cycle depending on which wash cycle is selected. On a shorter cycle it will be released soon after starting. On longer cycles, there is usually a rinse first, so the tablet will be released a little later. There would only be a problem if the tablet wasn't being released, or wasn't dissolving completely.
There are a number of reasons for poor cleaning on the top rack. The most common are the upper spray-arm not spinning, incorrect stacking or overloading. If the upper spray-arm isn't spinning, there may be caused by a blockage in the spray-arm or the water delivery system, but, as the dishwasher is new and it's not happening every time, it's possible that the dishwasher isn't levelled correctly. The spray-arms aren't motorised, they use water pressure to spin, but they wont spin if they aren't balanced, i.e. the dishwasher isn't level.
You can check whether the spray arm/s are spinning by pointing them front-to-back, or left-to-right (so you can remember the position) and allow the dishwasher to run for a few minutes. Then open the door and check the position of the spray arms. They should continue to rotate slowly for a short while after opening the door, but if they're in the same place and static, they're not spinning. I'd suggest repeating this a couple of times to eliminate the possibility of them having stopped in the exact same place you left them.
If the spray arms are spinning, test the dishwasher with only a small load in the top rack. If the top rack comes out clean with a small load, you may be overloading it or stacking it incorrectly some of the time. There should be a correct stacking guide in your user manual.
Hope this helps. If you need further assistance, check whether the arms are spinning then post back.
Jul 03, 2011 | Dishwashers
Finish Dishwashing tablet does not dissolve and our dishes do not come out clean. We have used a product to clean dishwasher, but to no avail.
Many dishwashing detergents need a water temperature of 140 degrees to dissolve. If your water is at the correct temperature, the only other suggestion I have is to make sure the detergent dispense is not blocked by large objects such as baking sheets, frying pans etc. If the dispenser cannot open fully, the detergent won't dissolve.
Also, you might want to check the sprayer arms. If they are clogged, they won't turn effectively. Sometimes debris will be pumped into the arms but the openings are too small to release the debris. You can remove the arms by removing the screw that hold them in place and then flush the arms with your sink sprayer. Then you can check the openings to see if there is any "crud" left in them. By crud, I mean small pieces of paper, bone fragments,
I hope one of these suggestions helps you. If it does, please rate my effectiveness. Thanks
Jun 02, 2011 | Maytag Dishwashers
Kenmore dishwasher we use new finish detergent and the little soap pouches do not dissolve.
Mar 09, 2010 | Kenmore Dishwashers
Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Jan 22, 2010 | Zanussi Dishwashers
Tablet is not dissolving from my dishwasher drawer
If it drops to the bottom when you open the dishwasher door - your soap dispenser is blocked by the rack or an utencil protruding from the rack. Make sure both racks slide in all the way to the back. (hint: check the middle spray arm inlet, make sure it aligns with the tube on back.
Good luck)
Oct 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Having problems with AEG dishwasher-tablet not dissolving..
open the door when in cycle and check both spray arms are rotating. you will get a bit of water out but not a lot. if arms not rotating, then this is caused usually by rubbish in the spray arm jets so clean them. also check water is being heated
Aug 05, 2008 | AEG 18 in. Favorit 54750Vi Slim-Line...
Dispensing tray is not opening at right time in cleaning cycle
unlikely to be dispensor opening at the wrong time. the powder is washed out by water squirting from angled jets at the end of the spray arm. check no blockage in spray arm - sometimes difficult to see. you may find also that the spray arms are not rotating for the same reason
Mar 21, 2008 | Neff 24 in. S5453X1 Built-in Dishwasher
Dishwashers Logo
2,322 people viewed this question
Top Dishwashers Experts
