Question about Toro Electric Trimmer
Toro trimmer Model3 51412
I was given a toro stringtrimmer model 51412 and can not figure out how to wrap new line onto the trimmer. It has two exit holes for the line and only shows one direction to wrap the line. How do I end up with the two ends of line to trim ?
  • cmaher Sep 06, 2008
    I can't figure out how to take the spindle off to restring it.
5 Suggested Answers
radar001
  • 1051 Answers
SOURCE: How do you remove the line spool cap on a toro
There are 2 tabs, 1 on each side of the cap. You need to press these in at the same time to pull the cap off.
Posted on Apr 06, 2010
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Posted on Apr 25, 2010
kel1guy2002
  • 3740 Answers
SOURCE: want down to down load owners manual for Toro 7
If you use this link:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Then type in your model and serial number, You can download your User's manual. Toro is pretty fussy about handing out manuals hence the model number AND serial number are required in their site.
Thanks for using FixYa,
Kelly
Posted on Apr 29, 2010
SOURCE: Have a Toro 51990A string trimmer. It starts, but
toro trimer model 51990a part drum with eyelet
Posted on Aug 27, 2010
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need o_1089.jpg_1088.jpg_1087.jpgpposing force.
Posted on Mar 30, 2011
Where do I get a manual for aToro 51412 trimmer
Please check the model number, struggling to find your machine
Apr 22, 2016 | Toro Garden
How to restring cordless weed trimmer
Make a sharp bend in the line and insert it into the hole in the spool hub. Start wrapping the replacement line in the direction shown on the spool.
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
How do you restring the line spool
Please see Figures 11,12,13 and 14 of your owners manual here for instructions and diagrams on that procedure: This is for a GH750. You probably have a GH1000, but I feel they are the same.
http://www.homelite.com/system/manuals/stringtrimmers/UT41110_221_eng.pdf
Jul 04, 2011 | Black & Decker 14" Grass Hog Xp...
Putting on another spool, do I thread the line through the hole in the side?
I feel that the END of your trimmer line should exit THROUGH the hole in the side. That hole should have a small metal grommet to alleviate wear on the plastic head unit as the string flies.
So string your line onto the spool and when you are done, run the END of the line through the hole in the side.
Jul 04, 2011 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
How to replace trimmer line ?
1. Remove the cap on the trimmer head, it unscrews.
2. The spool comes off, and on the inside of the spool there is a small hole, this is where you will start your trimmer line. It it will hold it in place while you wrap it. There is also arrows on the spool showing the direction that you need to wrap your spool.
3. Insert the line in the hole and start to wrap the line in the directions of the arrows, try to keep the line in rows, or else the line may bind and you will have to do it all over again.
4. Feed the line through the retainer and reinstall the spool by lining up the retainer and the slot on the outside portion on the trimmer head, the screw back on the trimmer head and you will be ready to trim.
Jun 29, 2011 | Toro Electric Trimmer
How do I replace the line in an 11 inch electric toro trimmer I can't turn the part that would come off to put new line in.
All I can do is refer you to the manufacturer's instructions. See page 5 after downloading your user manual. If you can not turn the cap off, then the cap is possibly cross threaded onto the shaft end and/or the threaded end if the driveshaft is stripped. See if the user instructions are of help to you.
http://www.toro.com/en-us/Homeowner/Yard-Tools/Trimmers/Pages/Model.aspx?pid=51347-11-Inch-Electric-Trimmer
Jun 08, 2011 | Toro& Electric String Trimmer
It has come apart and I would like to refill the line on my toro heavy duty electric trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 23, 2009 | Toro Garden
Jun 03, 2009 | Toro Electric Trimmer
Toro Electric Trimmer Logo
512 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Dwain Pippen
Are you a Toro Garden Expert? Answer questions, earn points and help others
