Question about Xerox WorkCentre XD100 All-In-One Laser Printer
The machine did'nt star well
When i turn on the xerox, there's a message in the screen "E7" and the fotocopy can't scan, whats the problem? thanks.
Make sure exposure strip at left edge of glass is clean, in position, undamaged, unobstructed, etc.
Posted on Aug 27, 2008
I have E7 and machine won't work????
E7 sounds like an error code. First step is to look it up in your owner's manual.
Aug 26, 2014 | Singer Sewing Machines
What does E7 mean
  • E7 - Scanner locked error
    1. Turn the scanner off then move the lock switch to the "Unlocked" position. The lock switch is located on the left side of the scanner.
    2. Plug the power for the scanner directly into the wall, not in a surge protector or battery backup
Aug 18, 2014 | Xerox Documate Office Equipment & Supplies
Sharp mx 350n code e7 90
You need to make sure the machine is in Copy Mode then hit
Pound, Star, C, Star
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jun 29, 2014 | Sharp AR-M450N Black & White Copier
Hello. My sewing machine DDL 5550-6 display shows the problem. E7. What is it? And how do I fix it? Thank you
HI THERE
concern E7 there's many reasons :
1- machine jamd ( try to turn machine by hand if you found handwheel is move easy ok.
2- thread trimmer locked or release? sometimes E007 come at the time of thread trimming function activated.( please check timming cam for thread trimmer ).
3- sometimes some threads go insaide hook and machine stop and give E7.
best regards
ashraf abozid
CAIRO - EGYPT
Mar 30, 2011 | Juki DDL-8700
Xerox C20 displaying "Scanner Locked" message. Won't copy.
  1. Press the power switch to the OFF (O) position. The power switch is located on the lower, left side of the machine.
  2. Pull the scan lock switch toward the front of the machine to unlock the Scanner.
    NOTE: The scan lock switch is located on the bottom of the Scanner Module. Make sure the scan lock is completely free. It sometimes hangs at the halfway point.
  3. Press the power switch to the ON (|) position. A 'Warming Up, Please Wait' message will be displayed on the Display Screen. Warm up time is less than 40 seconds from power ON and less than 25 seconds from the Power Saver mode.
Aug 30, 2010 | Xerox CopyCentre C20 Black and White...
Xerox xd120f showing error code E7 and not copying
I had E7 and the unit required a new laser unit. Precision Roller had the replacement laser, which did correct the error. Apparently, during a move to a new location, something jarred the machine and caused the failure.
Oct 06, 2008 | Xerox Office Equipment & Supplies
No scanning, no printing, no xeroxing
thanks for your answer.now the problem is even bigger.there appears a message saying Port disabled and then Cannot open device.i'll try change the USB cable to see if it helps.
Thank you again!
Sep 25, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Fault code
well..it's a system error code..is this an older machine, by chance?
Aug 20, 2008 | Xerox Phaser 8400 Laser Printer
Error message on Xerox workcentre 7242, error 010-333
Fuser jam, maybe the exit switch ?
If you turn the unit off and back on does it come up ready to copy or ready to scan you job
Jul 07, 2008 | Xerox Office Equipment & Supplies
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
143 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
