Question about Sony Playstation 3 (PS3) Console
Disc is stuck in ps3 drive
I inserted a 3.5" disc in the drive and it got stuck i cannot remove even after pressing the eject button please can u help me
regards
sam
  • Anonymous Dec 07, 2008
    yea it happend to me too i was playin saints row 2 some how the cord got unplug and i turned back on and i push reject button but it didn't come then i pushed it again it turned green then it went yellow
  • 42 Answers
Trying sticking something thin and firm in there gently.. try to feel for the bottom side of the disc. Press the eject button and press up a few times. This may take awhile. But Be sure to be very Very gentle while doing this.
Posted on Aug 29, 2008
Disc Stuck In 60G Console
  • Press the "Eject" button on the PlayStation 3 console and hold it for at least 10 seconds; if your PS3 has the "force eject" feature included it will eject the disc regardless of whether the console is frozen or not. Turn off the console and turn it back on before inserting new discs.
  • Unplug the power cord and any other cords from the PS3 console if the "force eject" feature does not work and you own a PS3 Slim. Turn the console upside down so that you have access to the bottom of the console.
  • Locate the small compartment door on the bottom of the console. Remove the door by pulling it up and off the console; a blue screw and a small hole should be visible inside the compartment.
  • Insert a Phillips-head screwdriver into the hole. Turn the screwdriver in a counterclockwise direction to manually eject the disc. Once the disc is removed, replace the compartment door and turn the PS3 console back to its correct position before reconnecting the power cable and any other cables you previously removed.
  • Jan 29, 2012 | Sony Playstation 3 (PS3) Console
    Problem with the disk drive, the console isn't recognising it and it won't eject, think its stuck
    One thing you could try is to turn the console off that the back of the PS3. Turn it back on so it is in standby. Hold down the disc eject button and then press the power button on the front. This should force the disc to be ejected from the PS3. Hopefully this will solve your problem but if it does not please reply here and I will do my best to help you some more.
    Aug 09, 2010 | Sony Playstation 3 (PS3) Console
    PS3 Won't Take Disc!
    Hi, I think it was me who had helped you before. I will be glad to help again. Ok, first you have to tear apart your PS3 (just like when you cleaned it). Now looking at the rollers and "dogs" make sure that they are closed and not open all the way like when a disc is in it. Look at the flap on the top too make sure it opens and closes freely. Next, PLEASE BE CAREFUL!! Plug your PS3 in and try to hit the eject button, if it is reset and ready for a disc it will beep twice when you hit the eject button without a disc in it. Place the top back on the he DVD drive and try to insert a disc. At this point it should take it. If not then try hitting the eject again. Once the PS3 resets and takes and ejects discs again, then you can put it back together.
    Aug 13, 2009 | Sony Playstation 3 (PS3) Console
    My disk is not ejecting from my ps3. my pro evo 2009 has been stuck in for a while now. when te eject button is pressed it attempts to do so but then nothing comes out and it goes back to normal (as if...
    is there a tiny whole in your ps3? in which you could insert a small pin? if not. then the disc tray may be stuck. you could try lifting the disc tray with a pliers or something that can hold the tray and slowly pull the disc tray as you press the eject tray. Pm me for any clarifications.
    Aug 07, 2009 | Sony Playstation 3 (PS3) Console
    Disc stuck in the drive of my ps3,,,i've tried holding the eject button down, the paperclip trick..nothing worked...any other ideas??
    no. just turn on the game n pick up the system.tilt it completely over 2 where the part where u insert thte disc is facing the ground.then,hold down the eject button.simple. no number.no repairing.
    Jun 13, 2009 | Sony Playstation 3 (PS3) Console
    Disk will not go into PS3 appears to be blocked
    Press and hold the eject button for around 15 seconds, this resets the cd drive and will fix your problems. Hope this helps
    Jan 18, 2009 | Sony Playstation 3 (PS3) Console
    Something stuck inside disc drive
    try this, press and hold eject button for around 15 seconds, this resets the cd drive, hope this helps
    Jan 10, 2009 | Sony Playstation 3 (PS3) Console
    System wont load or eject any discs...
    Remove the disc drive from the console. Remove the cover very carefull. Take the top part off (remove the 5 screws) and open the disc drive like a book.
    Carefull remove the guide mechanism (the front part -1 screw).
    The clicking noise is caused by the fact that the left side mechanism that raises and loweres the deck when the disk is inserted or ejected is stuck. Carefull push back the piece of plastic with teeth located on the left side of the deck (as you are looking at the disk drive the oposite side with the lens driving motor) until it clears complete the plastic round gear that drives that part.
    mount back the guide mechanism, and the top part.
    Attached the ribbon cables to the unit , power the console and keep the eject button pushed for about 10-15 seconds.
    That will reset all the gears and stuff.
    Worked for me when I experienced that issue.
    Sep 05, 2008 | Sony Playstation 3 (PS3) Console
    2 disks stuck in ps3
    You are A ******, try beating yourself with a hammer
    Aug 22, 2008 | Sony Playstation 3 (PS3) Console
    Jammed cd drive
  • Touch the eject button on the PLAYSTATION 3 system front for 10 seconds or longer to force the disc to eject. After removing and before reinserting a disc into the PLAYSTATION 3, turn off the system, and then turn on the system again to resume use.
  • If the disc cannot be inserted, you may need to send your system in for service, please click on the link below.
  • Aug 27, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    171 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
