Question about EuroTech EWC177 Front Load Washer / Dryer
Washer vibrates on spin cycle and is falling apart,
Door is cracked.soap dispenser is cracked andfalling apart
  • 750 Answers
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You say, your door is cracked.soap dispenser is cracked and falling apart?
How old is the washer????????????
Waiting for your response!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Sep 29, 2008
How do I fix it?
Probably a loose balancing block. this the only thing that comes to mind.
Oct 28, 2014 | Amana Front Load Washing Machine Washer...
Detergent dispenser will not stay shut so the soap power falls out before washing starts. Last time use I opened the door by mistake part way through the cycle. Could this have messed up the latch...
Opening the door did not affect the latch on the dispenser. The catch does wear out and can be replaced. This involves disassembling the door and a small jigsaw puzzle of springs and levers. If you are attempting I would advise taking pictures to refer to before taking apart.
Eric
Jan 11, 2010 | Kenmore Dishwashers
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Mah9700AWW maytag washer dooer is locked
unsrew the lid to soap dispenser and search for the cord , you probably have a bad wax motor(lock motor)
May 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
Overbearing shaking and vibrating washer even when no load in it and just run empty
is the damper pad at the base dry.they need to be oily other wise the machine can vibrate badly.hope this helps.
Mar 12, 2008 | Washing Machines
Maytag Neptune out of balance on spin cycle
Hi, try to check the spring virator support might pollout from slot or hole connected, some adpter are rusted spring replace it are also available in appliances store.
Feb 15, 2008 | Washing Machines
Door Locked and wont open
Mine is crazy too! Sometimes, if I open the soap dispenser it will open, othertimes not. Sometimes, if I pull up on the big, round knob (that you use to turn on the cycle), because it gets stuck down. Once in awhile, I just put it on the last 2 minutes of spin cycle again.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
EuroTech EWC177 Front Load Washer / Dryer Logo
143 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
