Question about Toshiba 32A33 32" TV
How do I get to the screen (video blue?) to play DVDs. I have a satellite receiver.
  • 135 Answers
Hook up a dvd player to the rca jack inputs, select "video" on tv.
Press "play" on DVD...
Posted on Oct 11, 2008
I burned a dvd in my Toshiba Satellite laptop, it wont play on my dvd or blue ray player
dvd players play vob or mp4 format. so try "convert x to dvd" software to burn your dvds in the right format http://www.vso-software.fr/products/convert_x_to_dvd/
Feb 24, 2016 | Toshiba Satellite Computers & Internet
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
I have just bought a toshiba satellite c650d. Will it play DVD's. It is running on Windows 7 and has 4GB of ram
Toshiba Satellite C650D has a DVD Drive and it is capable of playing DVDs.Certainly, it will play DVD. It even supports High Defination (HD) video. So, ENJOY!
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Feb 03, 2011 | Computers & Internet
DVD player won't read DVDs - goes straight to blank blue screen
tried the cleaner disc you can buy one at
best buy or waltmart
Aug 25, 2009 | Initial DTV-172 17 in. TV/DVD Combo
Prior to the recent installation of Direct TV I was with DISH. I switched to Direct when Dish attempted to charge me for a new full package cost because I wanted to re-activate a Dish receiver which I had...
After it is hooked up, it should have a white screen saying "searching for satellite signal." After fifteen or twenty minutes, it will go to a black screen saying the same thing in a blue box. Once you are there, you can prerss the LIST button on the remote and record and copy your selected shows. This is assuming you have a newer DVR. Model R15 or higher. thanks keep updated
Jun 16, 2009 | Philips Televison & Video
Toshiba 26AV502U (new) video dropout if VHS tapeis not perfect
Had problem checked by local outfit called "Circuit Pro"; their analysis was compatibility.
Actual answer was that the Toshiba required a better quality input from "any" VHS source.
I finally took a "less than perfect" VHS tape with me when I returned the Toshiba TV to the store and demonstrated the problem to one of the TV sales people. He played the VHS tape through a display VHS/DVD player to three different brands of TV. The picture was often "black screen" on a Toshiba, but was merely poor quality on the other two brands. I upgraded to a Sony KDL26M4000 from the Toshiba 26AV502U.
Dec 03, 2008 | Toshiba 26HF84 26" TV
Thomson scenium rear projector 52inch
What is your tuner source? Cable, Satellite, or antenna?...accordianman
Nov 17, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Home theater reception
you need to unlpug your set and reconnect everything over and see what it does.if that does not work have a tech check your system.your sony recviever is the culprit let that be checked.good luck
Apr 05, 2007 | Sony KP-53XBR45 53" Rear Projection...
Toshiba 32A33 32" TV Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
