Question about Palm Tungsten T5 - Multilingual Handheld
Finding data on SD or MMC
'Find' application does not include SD or MMC expansion card data
    Master:
  • 903 Answers
The Palm OS "Find" application does not look at the content in SD or MMC expansion cards inserted in your handheld. It only searches through data stored in the internal memory of your handheld. There are many third-party searching utilities available.
Posted on Sep 07, 2005
SOURCE:
How do i repair sandisk micro sd card
Hi....
If you lost your data from sandisk memory card then you can use one of the sandisk memory card recovery software that is available online in order to recover files from sandisk memory card.
Dec 06, 2012 | Samsung 8gb Micro Sd Memory Card 4 Galaxy...
I am trying to format a 4GB SD card for my camera and it will not format
The DX7590 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use cards 2GB and smaller.
Feb 15, 2011 | Kodak EasyShare DX7590 Digital Camera
What memory card should i put in a kodak easyshare c530 camera
Kodak easyshare c530 has SD/MMC card expansion slot. So you can use any SD(secure digital) or MMC(multimedia cards) storage devices.
Sample pics below: bourngenius_20.jpgSD bourngenius_21.jpgmmc
Feb 14, 2011 | Kodak EasyShare C315 Digital Camera
I dropped my Micro Drive, how can i recovery my pictures?
You can use Card Data Recovery to help you recover your pictrues from the damaged drive.
It can recover data from all camera flashmemory cards including Compact Flash Card (CF), Smart Media Card, SecureDigital Card (SD), Multi-Media Card (MMC), XD Picture Card (XD), Micro Drive,Sony Memory Stick (Duo, Pro), as well as removable storage including Zip disk,USB drives and Hard drives. Recovery of files is also possible even when drivehas been formatted.
http://www.card-data-recovery.com
Nov 22, 2010 | Canon IBM Microdrive 1 GB CF+ Hard Drive
What type of sd memory card for c530 camera
As per Your camera specifications it supports SD/MMC cards for expansion.
You can check the image of SD card here in the below website:
http://www.cavecreations.net/woots/Kingston_2GB_Micro_SD_Card_with_AdapteraDetail.jpg
You can check the image of the MMC card here in the below website:
http://www.flash-data-recovery.co.uk/wp-content/uploads/2008/11/mmc_card.jpg
Any further issues you can contact me.
Regards
-Dileep
May 23, 2010 | Kodak EasyShare C315 Digital Camera
Where do u go to buy memory cards for the tungsten
Palm Expansion Slot - Expansion cards can be added for extra memory, data back up or slot content such as reference and language translators, sold separately.
You can use SD, SDIO or MMC memory cards. Take your unit to Office Depot, or Best Buys and purchase one. You can probavbly try it in the store before purchasing.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 28, 2009 | Palm Tungsten E2 Handheld
Inserting media card into toshiba laptop
In the card slot if u are inserting a mmc card it will be inserted directly and after inserting u will find a new drive in my computer and on opening that u will be finding the data and to transfer the data directly right click on the data and send to drive name allottedto card reader.
If u rae using a micro SD card then u will have to use an adaptor which will convert micro sd card to the MMC size.
Mar 01, 2009 | Toshiba A75-S125 Satellite Notebook
Expansion card doesn't stay in.
Problems inserting expansion cards, or keeping them in your device, may have a simple solution. Try these first: * Make sure the expansion card is facing the correct way. See the handbook for your device for illustrations. * Expansion cards do not fit into the slot if not oriented properly. If a MultiMediaCard (MMC) slides all the way through, it does not operate correctly. Make sure to fit cards carefully in the slot. * The mechanism of the expansion slot is called "push-push." Much like a glass cabinet door, you push to insert the card, and then push it in again to get the mechanism to release. Expansion cards do not need to be forced out of the expansion slot. * Though most expansion cards are notched at the top for removal with a fingernail or other such object, removing the card this away may damage the mechanism. Use an object only when a push fails to release the card. Please be aware that you could damage your handheld if you remove a card improperly, or insert objects other than expansion cards into the slot. * Expansion slots damaged by forced removal of the card do not release the card when pushed, and could refuse to ?lock? the card in the slot. Expansion slot damage can only be repaired by having the entire handheld serviced. * Some expansion cards labeled as SD or MMC do not actually conform to the SD or MMC specification.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Expansion card content is not backed up during HotSync process.
Through the use of an SD or MMC expansion card reader, which connects to your desktop computer, you can copy the contents of your expansion card to your hard drive. Where can you get an SD card reader? Try your local electronics or computer store, or look online.
Camera doesnt recognize a Secure Digitalor MultiMediamemory card?
The cause and solution may include one of the following: The card may not be certified SD or MMC. Purchase a certified SD or MMC memory card. The card may be corrupt. Reformat the memory card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Palm Tungsten T5 - Multilingual Handheld Logo
85 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
