Question about HP iPAQ H5550 Pocket PC
Ipaq 5550 keeps re-booting
My Ipaq 5550 just keeps re-booting itself, even when I cut it off. I can cut it off, and it will start up by itself. What do I need to do?
  • 3 more comments
  • Anonymous Nov 12, 2007
    how do you carry out a full reset please ?
  • gigi_eu Feb 28, 2008
    I have the same problem that my IPAQ H5550 keeps rebooting without any reason even when is turned off. Has anyone a solution for this behaviour?
  • Anonymous May 29, 2008
    I have the same problem. Hardware reset (cal + itask + reset) doesn't help. Bizarely, mine does work while the reset button is held in. The problem comes and goes.
  • mehandra Aug 24, 2008
    I have a 6515 and it is rebooting on it own.
  • cumminsbradl Jan 16, 2009
    my i paq 5550 keeps rebooting but i also have a horrible fan like sound when its plug in any helpers? i have tryed hard reset
Do the hard reset
Posted on Mar 12, 2007
SOURCE:
IPAQ 5550 can I override the pin number?
Simple Solution:
Perform a hard reset and then attempt to login repeatedly (10x).
You will then be prompted if you wish to reset the pin entirely.
Good luck,
-AndyPants-
Jun 15, 2009 | HP iPAQ H4150 Pocket PC
Hp ipaq 5550
To do a full reset, you hold the calendar and itask buttons (buttons 1 and 4) down at the same time, then insert the stylus into the little hole on the bottom and press gently. Hold all for 4 seconds. The screen should begin to fade. Now release all. If successful, you will not be able to start the machine by pressing the on button. You will have to reconnect to ac power to start it.
That is all there is to it.
Jan 24, 2009 | HP iPAQ H5550 Pocket PC
5550 not powering on
was the battery a exact replacement to the one you removed?
also do you have the power adaptor for it put the old battery back in and see if it will run off the adaptor with the old battery plugged in and then you know the issue is with the new battery and not the unit itself.
Sep 16, 2008 | HP iPAQ H5555 Pocket PC
Water Ingress
Place a piece of tape on the screen and lift gently to lift touch screen from pad and it should separate if dry.
Aug 26, 2008 | HP iPAQ H5550 Pocket PC
HP H5550 keeps going blank and wont restart
See manual for 5550 from hp.com for description of how to do hard reset. You can download it.
Jul 16, 2008 | HP iPAQ H5550 Pocket PC
Ipaq 5550 background problem
Failed to start background reading (status=5, error=-102, retcode=0). Perform a normal resert and try again. IPAQ 5500
can you please send me the files to upgrade it?
Ljubimirek1996@hotmail.com
thank you
Mar 18, 2008 | HP iPAQ H5550 Pocket PC
IPAQ 5550
Performing a Full Reset A full reset is sometimes referred to as a ?hard reset.? Perform a full reset when you want to clear all settings, programs, and data from RAM. A full reset deactivates the battery. The power button does not function until the battery is reactivated. CAUTION: If you perform a full reset, your iPAQ Pocket PC returns to its default settings and loses all information that is not recorded in ROM. To perform a full reset: 1. Press and hold Application Buttons 1 (Calendar) and 4 (iTask) on the front of the unit and, at the same time, use the stylus to press the Reset button on the bottom of your iPAQ Pocket PC. 2. Hold all buttons until the displayed Full PDF document can be found here: http://h20000.www2.hp.com/bc/docs/support/SupportManual/lpia8006/lpia8006.pdf
Aug 19, 2007 | HP iPAQ H5555 Pocket PC
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
WPA-PSK and AES
on my ipaq hx4700 , i'm only able to use wpa-psk tkip, no aes option. not sure if any difference on 5550.
Sep 14, 2005 | HP iPAQ H5550 Pocket PC
PAQ 5550 and MMC 4.x (Plus)
so MMC cards are the older version of SD cards. Ipaqs support the fast SD cards and all sizes up to the max.
Sep 08, 2005 | HP iPAQ H5555 Pocket PC
HP iPAQ H5550 Pocket PC Logo
487 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
