Question about HP LaserJet 2550L Printer
Dislocated carousel how do I fix the carousel short of taking to a shop?
  • 138 Answers
Here a short run down on it:
Common on this type print engine. Your carousel is out of index. Repair requires removing all toner cartridges and printer covers. Big black carousel gears have index marks, one on each side. Trip the solenoid carousel brake at the top left of the rotary drive assembly by lifting the solenoid flap to free manual carousel rotation. Bring the yellow slot to the front, facing you to achieve rough indexing. Look for the two white pins of the white carousel drive gear, one pair on each side. Rotate the carousel to where the two pins, which face inward, are at the bottom. The mark of the carousel gear should be between the two white pins. Chances are it is a tooth or two out of index on one side. To reindex, push the black carousel gear inward and the white drive gear outward to skip a tooth. Recheck, reassembly, and have fun.
Hope that helps you.
Posted on Sep 03, 2008
    Problem Solver:
  • 3 Answers
The previous way of realigning will work but you will be there for an hour. There is a much easier way that takes less than a minute but easier to show or find a good tech. I believe there is probably some video support out there how to do it but if you don't know what you are doing, take it to a shop.
Posted on Dec 31, 2012
While our microwave is running, there is popping sounds and the panel on the side is sparking
take out the tray and the carousel and put something in the microwave and try to heat it,no zapping means faulty carousel or tray,if you used the microwave with nothing in it,then the microwave WILL do that{zap},do not use your microwave without anything in it,if this still happens,replace the microwave,or you have metal in the dishes you are using.stop using the dishes,get microwave safe dishes.
Jan 03, 2015 | Microwave Ovens
My Kodak Carousel 650H has a stuck slide and the tray won't move. The stuck slide is lined up with the "gate index." I tried releasing the tray but only one side of the tray releases. The...
Two steps.
1) Look down into the center of the carousel. There should be a round, flat silver knob with an elongated notch in it. Take a coin (US 5-cent piece or similar) and use it to turn the knob. This releases the catch on the metal plate under the projector. You should then be able to lift the carousel off. Be careful: some slides will fall out as the slot is not aligned with the carousel body properly once you do this.
2) Make sure the locking ring on top of the carousel is in place (or else take out all your slides. Turn the carousel over and gently rotate the metal plate covering the bottom of the carousel into position. You will hear/feel a "click" when it's in place.
The projector may have jammed because there are two slides stuck in the viewing slot--check for this before you put the carousel back on the projector. If it jams a lot the metal plate under the carousel may be bent.
Jul 17, 2011 | Kodak Carousel 4600 Slide Projector
Keypad not working
most of this type of model,keypad failure always happen
* when phone dropped and it causes keypad flex connected on the board is dislocated
* water damage that may lead to corrusion or shorted thats why keypad is malfuctioning
* keypad flex is damage and needs a replacement....
by all means,you can bring it to a mobile service shop near you for assistance...
hope it helps...
Jun 04, 2011 | Sony Ericsson K770i Purple 3G Camera...
Only prints on right side
carousel that rotates the toner cartridges needs to be aligned
need to take printer to a printer repair shop or send it to me to get it fixed.
printerman at gmail.com
Sep 23, 2010 | HP LaserJet 2840 Printer
Door hinge not releasing on Sharp carousel microwave oven
this problem is due to hinges dislocation from its normal position . it can be solved if you can just tap at the top of the hinge with a heavier object and be careful that you dont overdo it as it may affect the owen.
hope it helps you
Dec 30, 2009 | Microwave Ovens
My slide projector is advancing the carousel non-stop and I can't control it. What's the problem?
either the switch terminals are making a constant contact, or the advance solenoid is shorted on. you'll have to take the control panel apart to see if the switch pieces are touching. if not, you'll have to either find the short or take it in for repair.
Oct 14, 2009 | Kodak Carousel 4600 Slide Projector
The color is faded on the left side of the page printer, what is the possible cause or solution?
From the service manual:
If the light printing is on the left side of the page, the carousel might be dislocated.
Solution: Verify that the print-cartridge carousel drive teeth are aligned correctly. If the teeth are aligned correctly, replace the print-cartridge carousel.
Jun 03, 2009 | HP LaserJet 2840 Printer
DISLOCATED CAROUSEL
you need disassemby the carousel and assemby again , calibrate the carousel by a mark in the left side of then, and the other mark are in plastics of chassis.
Jan 06, 2009 | HP LaserJet 2820 Printer
Hp 2550 prints only right side of page
printing only the right half of the drum
Nov 28, 2008 | HP LaserJet 2550L Printer
Printing on right side only
It is the carousel that is dislocated. Check the alignment if it's brooken
Nov 01, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2550L Printer Logo
911 people viewed this question
Ben Johnson
