Question about Lexmark X1290 All-In-One InkJet Printer
Not printing I have documents in printer que but they do not print. I overwritten driver software, but it still doesn't print
Arunc-o dao dracu!!!
Posted on Sep 30, 2008
  • 109 Answers
I would start over. Delete the print jobs from the queue, then uninstall the printer software. Install it again from the CD and try again.
Steve
Posted on Sep 09, 2008
Wireless printing doesn't work
Is the printer set as default in the printers? I need more info to give a solution. Is the printer offline? Try to delete the printer and re-add in software. What message do you get when you try to print to printer? Are your documents in Que to be printed? If so Delete /cancel and try to print again.
Nov 02, 2012 | Acer Aspire One PC Notebook
No content prints on document when word document is sent to the printer
Is the problem only with Microsoft Word? If so you might have selected something else in the "Print What" box in the "Print" dialog box instead of "Document". See the below screenshot and make sure that the "Document" is selected. The Print dialog box will come up when you click the "Print" sub-menu from the "File" menu, i.e. click "File" and select "Print".
If this doesn't help, reinstall the printers drivers/softwares. That should fix your problem.
If the problem isn't only with Microsoft Word Documents, then there might be other problems with your printer, it could be cartridge/s, ink, drivers, etc..
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 14, 2011 | HP Officejet 6500 AllInOne InkJet Printer
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
Printer does not print document,
The quickest way is - disconnect the printer, remove the drivers and reboot twice. Reinstall the drivers and only hook up the printer when asked.
Aug 13, 2009 | Office Equipment & Supplies
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=83027&lc=en&cc=us&dlc=en&lang=en&cc=us. HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
Mar 26, 2009 | HP DeskJet 6122 InkJet Printer
Need Dell All-in-One printer 924 to work with Inspiron 530S.
If it doesn't say it is specifically for VISTA then it is not for VISTA.. Even if it does show up on the computer ,that just shows that some driver for that model printer is installed. Not necessary one that will work. Go to the weblink that I gave you. Download the VISTA drive and update the driver, using the one you downloaded ,and that will most lkely fix the problem.
Mar 03, 2009 | Dell 924 All-in-One InkJet Printer
Only prints one document
I would start by reinstalling the software and updating the driver. That will norrow down the problem to being hardware if it does not fix it.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Jan 24, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer not printing documents in que
my printer hp psc1315xi all in one printer copier, scanner will not print any documents, not even a test print, there is also a doucument in it that am not able to delet from the printer
Jan 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printing problem
To delete the file from printer cue, unplug printer, restart computer with printer unplugged, and delete file.
If it still does not work after deleting files, reinstall all printer software using software CD provided with the printer.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Sep 12, 2008 | Lexmark X4550 InkJet Printer
Will not print more than 1 page
HI there change the data cable or set the driver bi-directional printing off try this should work let me know.
Thanks J
Jan 21, 2008 | HP LaserJet 1000 Printer
Lexmark X1290 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
