Question about Palm Tungsten T5 - Multilingual Handheld
Expansion card content is not backed up during HotSync process.
How do I back up content on expansion cards?
    Master:
  • 903 Answers
Through the use of an SD or MMC expansion card reader, which connects to your desktop computer, you can copy the contents of your expansion card to your hard drive. Where can you get an SD card reader? Try your local electronics or computer store, or look online.
Posted on Sep 07, 2005
Installing additional memory into my Jitterbug smartphone--How do I do it?
Per the Jitterbug Smartphone manual, on page 124:
https://www.greatcall.com/docs/default-source/pdfs/jitterbug-smart-user-guide.pdf
Adding more Memory Your Jitterbug features a microSD expansion slot to add up to an additional 32 GB of memory. The following is how to add more memory:
1. Remove the Back Cover using the Back Cover Release notch found on the bottom corner.
2. Locate the microSD expansion slot, which is below the External Speaker, and carefully insert the microSD card into the expansion slot until it clicks into place.
3. Replace the Back Cover.
IMPORTANT! Do not remove the SIM Card located opposite of the microSD expansion slot. Tampering of the SIM Card may cause issues with connectivity to the GreatCall network.
May 19, 2017 | Cell Phones
Where can i buy a onchip usb2?
FIC FR33E motherboard?
http://www.ebay.com/itm/FIC-FR33E-L-MOTHERBOARD-CPU-LOT-10-/170633274365
Reference: Photo
To the far left side of the motherboard, is actually the Bottom of the motherboard, when installed in your computer case.
The two White long expansion slots you see, are PCI expansion slots.
If one is available, (Open), you can use a PCI USB adapter card.
This is but one example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4143850&CatId=511
Seem cheap? Nope. Good quality also. (You can also check the reviews)
Need guidance in installing?
1) Follow Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside the computer.
Computer on a table, computer unplugged from power, computer case open.
[Note* Always unplug the power to a computer AT the surge protector. NOT at the back of the computer. (Power Supply)
You can cause a power surge ]
2) TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
3) Finding an open PCI slot look at the back of the computer. In the metal frame you will see slots going horizontally.
These are Expansion Slots.
You may have an add-on adapter card already installed, in one of the PCI slots.
The expansion slot cover for it is removed.
You should see expansion slot covers however, in the remaining expansion slots on the back of the computer metal framework.
Remove the one that corresponds with the PCI slot you wish to use.
Be aware that the PCI slot will not be directly in line, with the expansion slot.
When installing an add-on adapter card, you will see when the card is inserted in the PCI slot, the metal bracket on the add-on card, lines up with an adjacent expansion slot.
This will make more sense to you once you go to install the card.
[PCI USB adapter card is an add-on adapter card ]
Line the card up in the PCI slot. Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Also, at the same time line up the metal bracket of the PCI USB adapter card, with the metal framework of the computer case at the back.
Gently push the PCI USB adapter card down into the PCI slot.
Fasten the card's metal bracket to the computer's metal framework.
Post the computer manufacturer name, and model number, if you need guidance in opening the computer case. Post in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 13, 2012 | FIC Computers & Internet
I need to get my sound card back to working
  1. Determine if the sound card is integrated or an expansion card (Usually a Soundblaster) If using an expansion card, the integrated audio must be disabled in the BIOS F2 at boot) If no expansion card, then in integrated audio must be enabled.
  2. Once the sound card has been determined, make sure that the master volume control is not MUTED and the WAVE audio is not MUTED
  3. Download and install the latest sound driver from support.dell.com
Oct 03, 2009 | Dell Dimension 3100 PC Desktop
Where do u go to buy memory cards for the tungsten
Palm Expansion Slot - Expansion cards can be added for extra memory, data back up or slot content such as reference and language translators, sold separately.
You can use SD, SDIO or MMC memory cards. Take your unit to Office Depot, or Best Buys and purchase one. You can probavbly try it in the store before purchasing.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 28, 2009 | Palm Tungsten E2 Handheld
Not recognize the PC Card Expansion Jacket after a soft reset
Make sure the P300 has completed the boot process before attaching the PC Card Expansion Jacket. This will ensure proper detection.
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
Can't run applications from an expansion card
In some cases, applications developed before Palm OS® 4.0 that are loaded to an expansion card may encounter errors when launched. However, these applications generally run properly when installed directly to your handheld's internal memory. Here's how to do that: 1. Access the Applications launcher. 2. Open the Menus. 3. From the App menu, select Copy. 4. In the Copy To: pulldown menu at the top of the screen, select your expansion card. 5. In the list of applications, locate the file you want to copy to your handheld's internal memory. Highlight the file. 6. At the bottom of the screen, select Copy. Then select Done. 7. Go back to the Applications launcher. At the top right of the screen, there's a pulldown menu with different application categories. Choose All (this is a category that's on your handheld, not on your expansion card). 8. Locate the application you copied, and launch it from this screen. 9. Contact the developer of the application for more information on application compatibility with expansion cards.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Expansion card doesn't stay in.
Problems inserting expansion cards, or keeping them in your device, may have a simple solution. Try these first: * Make sure the expansion card is facing the correct way. See the handbook for your device for illustrations. * Expansion cards do not fit into the slot if not oriented properly. If a MultiMediaCard (MMC) slides all the way through, it does not operate correctly. Make sure to fit cards carefully in the slot. * The mechanism of the expansion slot is called "push-push." Much like a glass cabinet door, you push to insert the card, and then push it in again to get the mechanism to release. Expansion cards do not need to be forced out of the expansion slot. * Though most expansion cards are notched at the top for removal with a fingernail or other such object, removing the card this away may damage the mechanism. Use an object only when a push fails to release the card. Please be aware that you could damage your handheld if you remove a card improperly, or insert objects other than expansion cards into the slot. * Expansion slots damaged by forced removal of the card do not release the card when pushed, and could refuse to ?lock? the card in the slot. Expansion slot damage can only be repaired by having the entire handheld serviced. * Some expansion cards labeled as SD or MMC do not actually conform to the SD or MMC specification.
Installing audio or image files on an expansion card
You can transfer audio and image files to an expansion card in your handheld. It's easy; just perform a HotSync operation after placing the files into the Install Tool. Here's how: 1. Insert an SD expansion card into your device. 2. On your desktop computer, launch Palm Desktop (even if you normally synchronize with another application). 3. Click the Install button. 4. At the top of the Install Tool window, make sure the correct user name is chosen from the pulldown menu. 5. Drag and drop the audio or image files from your hard drive into the Install Tool window. 6. You'll notice that the destination for the audio files will always be "Secure Digital card." You can install audio files only to an expansion card, and not to the device's internal memory. 7. Perform a HotSync operation. 8. Launch your handheld's third-party audio player and open songs from your expansion card, or launch your handheld's image viewer and open images from the card. Please refer to the audio player's or image viewer's documentation to learn how to do this (it varies from application to application).
Installing files directly to an SD card
You can use the HotSync process to install files directly to an SD card, rather than having install first to your devices internal memory then the SD card. 1. Insert an SD expansion card into device. 2. Launch the Install Tool on your desktop computer: from the Windows Start menu, choose Programs, then Palm or Handspring (dependin on your device), then Install Tool. 3. Make sure the correct user name is chosen from the pulldown menu at the top of the Install Tool window. 4. Drag and drop files from your hard drive into the Install Tool window. File types supported on all devices: * Palm OS applications (.prc) * Palm OS database (.pdb) Additional file types supported on certain devices: * MP3 music (.mp3) * Pictures (.jpg or .jpeg) Please refer to your device's documentation to learn how to use these additional file types on your device, if applicable. 5. In the Install Tool, click on the file. Then click on the "Change destination" button at the bottom of the Install Tool window. 6. Move the file to the column for the SD card. Click OK. 7. Perform a HotSync operation.
Finding data on SD or MMC
The Palm OS "Find" application does not look at the content in SD or MMC expansion cards inserted in your handheld. It only searches through data stored in the internal memory of your handheld. There are many third-party searching utilities available.
Palm Tungsten T5 - Multilingual Handheld Logo
174 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
